TMS320F28388D: When using EtherCAT, there was a data update failure at runtime in DC mode
Part Number: TMS320F28388D
I sent the TwincAT3 data to 28388D and then sent the data back. When comparing the two, I found that there were a few cases where the data was not updated, but when I checked TwincAT3, there was no lost frame
I'd like to ask  what the problem is
  • Hi Xu,
    The value on the right is the data sent back to TwinCAT by the F2838x? If so, it seems it sends previous data for some reason.
    Are you utilizing our example code available in C2000WARE?Can you elaborate on how you're testing?
    Is there anything specific that could be bringing about the condition?
    Kevin
  • HI,Kevin
    Your answer "It seems it sends previous data for some reason" helps me find the reason for the problem,this is because I use PC as the master and PLC frequency is too fast to data updating, so it send the previous data and show there is no lost frame.
    Thank you.Your answer is a great help to me
    Xu
