Part Number: TMS320F28388D
Other Parts Discussed in Thread: DP83640, DP83848J
We are currently using the DP83640 PHY with the F28388D Processor.
Due to supply chain issues we are designing in a different PHY. Our CPU and processor are on a custom SOM module that plug into a number of custom carrier boards used in a variety of our products. So our preference is to choose a PHY that is compatible with the (current mode) magnetics that is on those existing application carrier boards.
Our choice (based upon today's view of distribution and supply) is TI's DP83848J PHY. Before we purchase a large supply of these PHY's, we have a few questions:
- Has this PHY been used with the F2838X processors and if so, are there any known issues/concerns about a new design-in?
- If it has not been used, should it be compatible and again, any concerns?
- Any reason to expect FW changes and/or customization of the register set on our end when moving to this new PHY?
- We do see that DP83848 part differs from the DP83640 in that it does not have an interrupt output pin. Is this a concern from your perspective? We are thinking it is a no-issue as we use this as a power down functionality rather than an interrupt.
As always, we appreciate your help with this.
Mike
