Part Number: TMS320F28379D
1- I have build-up the following IHM in Gui Composer v3
2- The two radio-buttons interact, and when I select "Une seule pulse", I get the following view :
3- To achieve this interaction, I wrote the following "index.js" code :
import { GcUtils } from './components/@ti/gc-core-assets/lib/GcUtils';
import { GcConsole } from './components/@ti/gc-core-assets/lib/GcConsole';
import { bindingRegistry } from './components/@ti/gc-core-databind/lib/CoreDatabind';
import { GcWidget } from './components/@ti/gc-widget-base/lib/GcWidget';
import { ActionRegistry } from './components/@ti/gc-widget-menu/lib/ActionRegistry';
let console = new GcConsole('myapp'); // creates a console instance with name 'myapp'
GcConsole.setLevel('myapp', 5); // enable console output for myapp console instance
console.info('index.js is loaded...');
//write all code inside of this initializer function
const init = () => { //will run repeatedly while application window is open
// update topology
GcWidget.querySelector('#group').then(group => {
// update the topology input widget hidden attribute
const updateSelectInput = index => {
//Promise.all([GcWidget.querySelector('#select'), GcWidget.querySelector('#select_1')]).then(([nbrePulses, espPulses]) => {
Promise.all([GcWidget.querySelector('#select'), GcWidget.querySelector('#select_1'),
GcWidget.querySelector('#label_2'), GcWidget.querySelector('#label_3'),
GcWidget.querySelector('#label_4')]).then(([nbrePulses, espPulses, label_2, label_3, label_4]) => {
if (index === 0) { // Select
nbrePulses.hidden = true;
espPulses.hidden = true;
label_2.hidden = true;
label_3.hidden = true;
label_4.hidden = true;
} else { // fixed DC
nbrePulses.hidden = false;
espPulses.hidden = false;
label_2.hidden = false;
label_3.hidden = false;
label_4.hidden = false;
group.addEventListener('selected-index-changed', ({detail}) => updateSelectInput(detail.value));
updateSelectInput(group.selectedIndex);
//don't touch this. When page loaded, will run the init function above where all code is written
document.readyState === 'complete' ? init() : document.addEventListener('DOMContentLoaded', init);
4- And my question is :
HOW TO INITIALIZE THE PAGE AT LAUNCHING TO MAKE THE LAST VIEW APPEARING EVERYTIME AT FIRST
==> HOW SHOULD I MODIFY MY "INDEX.js" CODE TO ACHIEVE THAT ?
Many thanks in advance for your help
