Part Number: TMS320F28388D
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
I'm having troubles to work the CLB module of the 28388. The CLB modules are not always working as expected, counters can have erratic behavior (count not incrementing when expected, reset when not supposed to, ...), etc.
I sometime have a working configuration, but a slight change in this configuration breaks everything again:
- removing/adding a CLB module can impact the other CLBs
- changing a LUT table config is affecting the global behavior of that CLB.
I am working with CCSv12, Sysconfig 1.13, all the CLB config is done graphically in SysConfig and then I call Board_init() from my main file after clocks and peripherals are properly activated.
Is there any obvious reason why I can't have a stable CLB behavior? The worst part is to see a counter return to 0 when the reset input is forced to 0 and the mode1 input to 1...
Stephane
