TMS320F280045: GPIO22_VFBSW not working
Part Number: TMS320F280045
Other Parts Discussed in Thread: TMDSCNCD280049C
Dear Sirs
I'm using GPIO22_VFBSW to generate a pulse interrupt on another PCA.  Please see schematic below.  I used the .syscfg GUI to setup the IO.  I'm using a modified blinky example to make the debugging easier.  Please see code below.  The .syscfg GUI seems to have configured the GPIO22_VFBSW and GPIO28 correctly.  However, when I run the program, the GPIO22_VFBSW stays low all the time and the GPIO28 toggles with an amplitude of only 1.75V.  When I run this program on the TMDSCNCD280049C control card, it works correctly.  Do you have any suggestions?
// FILE:   led_ex1_blinky.c
// TITLE:  LED Blinky Example
//! \addtogroup driver_example_list
//! <h1> LED Blinky Example </h1>
//! This example demonstrates how to blink a LED.
//! If using LaunchPad, select build configuration for LAUNCHXL.
//! \b External \b Connections \n
//!  - None.
//! \b Watch \b Variables \n
//!  - None.
// $Copyright:
// Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
#include "board.h"
// Main
void main(void)
    // Initialize device clock and peripherals
    Device_init();
    // Initialize GPIO and configure the GPIO pin as a push-pull output
    Device_initGPIO();
//    GPIO_setPadConfig(DEVICE_GPIO_PIN_LED1, GPIO_PIN_TYPE_STD);
//    GPIO_setDirectionMode(DEVICE_GPIO_PIN_LED1, GPIO_DIR_MODE_OUT);
    Board_init();
    // Initialize PIE and clear PIE registers. Disables CPU interrupts.
    Interrupt_initModule();
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    Interrupt_initVectorTable();
    // Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
    EINT;
    ERTM;
    // Loop Forever
    for(;;)
        // Turn on LED
//        GPIO_writePin(DEVICE_GPIO_PIN_LED1, 0);
        GPIO_writePin(myGPIO1, 0);
        GPIO_writePin(myGPIO0, 0);
        // Delay for a bit.
        DEVICE_DELAY_US(50000);
        // Turn off LED
//        GPIO_writePin(DEVICE_GPIO_PIN_LED1, 1);
        GPIO_writePin(myGPIO1, 1);
        GPIO_writePin(myGPIO0, 1);
        // Delay for a bit.
// End of File
// FILE:   device.c
// TITLE:  Device setup for examples.
// $Copyright:
// are met:
//   distribution.
// Included Files
#include "device.h"
#ifdef __cplusplus
using std::memcpy;
#endif
#define PASS 0
#define FAIL 1
uint32_t Example_PassCount = 0;
uint32_t Example_Fail = 0;
// Function to initialize the device. Primarily initializes system control to a
// known state by disabling the watchdog, setting up the SYSCLKOUT frequency,
// and enabling the clocks to the peripherals.
// The function also configures the GPIO pins 22 and 23 in digital mode.
// To configure these pins as analog pins, use the function GPIO_setAnalogMode
void Device_init(void)
    // Disable the watchdog
    SysCtl_disableWatchdog();
#ifdef _FLASH
    // Copy time critical code and flash setup code to RAM. This includes the
    // following functions: InitFlash();
    // The RamfuncsLoadStart, RamfuncsLoadSize, and RamfuncsRunStart symbols
    // are created by the linker. Refer to the device .cmd file.
    memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
    // Call Flash Initialization to setup flash waitstates. This function must
    // reside in RAM.
    Flash_initModule(FLASH0CTRL_BASE, FLASH0ECC_BASE, DEVICE_FLASH_WAITSTATES);
#endif
    // Set up PLL control and clock dividers
//    SysCtl_setClock(DEVICE_SETCLOCK_CFG);
    SysCtl_setClock(DEVISE_SETCLOCK_OSC2);
    // Make sure the LSPCLK divider is set to the default (divide by 4)
    SysCtl_setLowSpeedClock(SYSCTL_LSPCLK_PRESCALE_4);
    // These asserts will check that the #defines for the clock rates in
    // device.h match the actual rates that have been configured. If they do
    // not match, check that the calculations of DEVICE_SYSCLK_FREQ and
    // DEVICE_LSPCLK_FREQ are accurate. Some examples will not perform as
    // expected if these are not correct.
    ASSERT(SysCtl_getClock(DEVICE_OSCSRC_FREQ) == DEVICE_SYSCLK_FREQ);
    ASSERT(SysCtl_getLowSpeedClock(DEVICE_OSCSRC_FREQ) == DEVICE_LSPCLK_FREQ);
#ifndef _FLASH
    // Call Device_cal function when run using debugger
    // This function is called as part of the Boot code. The function is called
    // in the Device_init function since during debug time resets, the boot code
    // will not be executed and the gel script will reinitialize all the
    // registers and the calibrated values will be lost.
    // Sysctl_deviceCal is a wrapper function for Device_Cal
    SysCtl_deviceCal();
#endif
    // Turn on all peripherals
    Device_enableAllPeripherals();
    //Disable DC DC in Analog block
    ASysCtl_disableDCDC();
    //Configure GPIO in Push Pull,Output Mode
    GPIO_setPadConfig(22U, GPIO_PIN_TYPE_STD);
    GPIO_setPadConfig(23U, GPIO_PIN_TYPE_STD);
    GPIO_setDirectionMode(22U, GPIO_DIR_MODE_OUT);
    GPIO_setDirectionMode(23U, GPIO_DIR_MODE_OUT);
    // Configure GPIO22 and GPIO23 as digital pins
    GPIO_setAnalogMode(22U, GPIO_ANALOG_DISABLED);
    GPIO_setAnalogMode(23U, GPIO_ANALOG_DISABLED);
// Function to turn on all peripherals, enabling reads and writes to the
// peripherals' registers.
// Note that to reduce power, unused peripherals should be disabled.
void Device_enableAllPeripherals(void)
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CLA1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_DMA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TIMER0);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TIMER1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TIMER2);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_HRPWM);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM2);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM3);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM4);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM5);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM6);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM7);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM8);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP2);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP3);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP4);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP5);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP6);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP7);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EQEP1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EQEP2);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SD1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SCIA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SCIB);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SPIA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SPIB);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_I2CA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CANA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CANB);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ADCA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ADCB);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ADCC);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS2);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS3);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS4);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS5);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS6);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS7);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PGA1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PGA2);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PGA3);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PGA4);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PGA5);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PGA6);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PGA7);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_DACA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_DACB);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_LINA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PMBUSA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_FSITXA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_FSIRXA);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CLB1);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CLB2);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CLB3);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CLB4);
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_DCC0);
// Function to disable pin locks and enable pullups on GPIOs.
void Device_initGPIO(void)
    // Disable pin locks.
    GPIO_unlockPortConfig(GPIO_PORT_A, 0xFFFFFFFF);
    GPIO_unlockPortConfig(GPIO_PORT_B, 0xFFFFFFFF);
    GPIO_unlockPortConfig(GPIO_PORT_H, 0xFFFFFFFF);
// Error handling function to be called when an ASSERT is violated
void __error__(char *filename, uint32_t line)
    // An ASSERT condition was evaluated as false. You can use the filename and
    // line parameters to determine what went wrong.
    ESTOP0;
// FILE:   device.h
// $Copyright:
// are met:
//   distribution.
#ifndef __DEVICE_H__
#define __DEVICE_H__
// Included Files
// Defines for pin numbers and other GPIO configuration
#ifdef _LAUNCHXL_F280049C
// LaunchPad
// LEDs
#define DEVICE_GPIO_PIN_LED1        23U  // GPIO number for LD4
#define DEVICE_GPIO_PIN_LED2        34U  // GPIO number for LD5
#define DEVICE_GPIO_CFG_LED1        GPIO_23_GPIO23  // "pinConfig" for LD4
#define DEVICE_GPIO_CFG_LED2        GPIO_34_GPIO34  // "pinConfig" for LD5
// CANA
#define DEVICE_GPIO_PIN_CANTXA      32U  // GPIO number for CANTXA
#define DEVICE_GPIO_PIN_CANRXA      33U  // GPIO number for CANRXA
#define DEVICE_GPIO_CFG_CANRXA      GPIO_33_CANA_RX  // "pinConfig" for CANA RX
#define DEVICE_GPIO_CFG_CANTXA      GPIO_32_CANA_TX  // "pinConfig" for CANA TX
// CAN External Loopback
#define DEVICE_GPIO_CFG_CANRXB      GPIO_10_CANB_RX  // "pinConfig" for CANB RX
#define DEVICE_GPIO_CFG_CANTXB      GPIO_8_CANB_TX   // "pinConfig" for CANB TX
// LINA
#define DEVICE_GPIO_CFG_LINTXA      GPIO_37_LINA_TX  // "pinConfig" for LINA TX
#define DEVICE_GPIO_CFG_LINRXA      GPIO_35_LINA_RX  // "pinConfig" for LINA RX
// FSI
#define DEVICE_GPIO_PIN_FSI_RXCLK   33U  // GPIO number for FSI RXCLK
#define DEVICE_GPIO_PIN_FSI_RX0     12U  // GPIO number for FSI RX0
#define DEVICE_GPIO_PIN_FSI_RX1      2U  // GPIO number for FSI RX1
#define DEVICE_GPIO_CFG_FSI_TXCLK   GPIO_7_FSITXA_CLK  // "pinConfig" for FSI TXCLK
#define DEVICE_GPIO_CFG_FSI_TX0     GPIO_6_FSITXA_D0  // "pinConfig" for FSI TX0
#define DEVICE_GPIO_CFG_FSI_TX1     GPIO_25_FSITXA_D1  // "pinConfig" for FSI TX1
#define DEVICE_GPIO_CFG_FSI_RXCLK   GPIO_33_FSIRXA_CLK  // "pinConfig" for FSI RXCLK
#define DEVICE_GPIO_CFG_FSI_RX0     GPIO_12_FSIRXA_D0  // "pinConfig" for FSI RX0
#define DEVICE_GPIO_CFG_FSI_RX1     GPIO_2_FSIRXA_D1  // "pinConfig" for FSI RX1
// SPI
#define DEVICE_GPIO_PIN_SPICLKA     56U  // GPIO number for SPI CLKA
#define DEVICE_GPIO_PIN_SPISIMOA    16U  // GPIO number for SPI SIMOA
#define DEVICE_GPIO_PIN_SPISOMIA    17U  // GPIO number for SPI SOMIA
#define DEVICE_GPIO_PIN_SPISTEA     57U  // GPIO number for SPI STEA
#define DEVICE_GPIO_CFG_SPICLKA     GPIO_56_SPIA_CLK   // "pinConfig" for SPI CLKA
#define DEVICE_GPIO_CFG_SPISIMOA    GPIO_16_SPIA_SIMO  // "pinConfig" for SPI SIMOA
#define DEVICE_GPIO_CFG_SPISOMIA    GPIO_17_SPIA_SOMI  // "pinConfig" for SPI SOMIA
#define DEVICE_GPIO_CFG_SPISTEA     GPIO_57_SPIA_STE   // "pinConfig" for SPI STEA
#define DEVICE_GPIO_PIN_SPICLKB     22U  // GPIO number for SPI CLKB
#define DEVICE_GPIO_PIN_SPISIMOB    24U  // GPIO number for SPI SIMOB
#define DEVICE_GPIO_PIN_SPISOMIB    31U  // GPIO number for SPI SOMIB
#define DEVICE_GPIO_PIN_SPISTEB     27U  // GPIO number for SPI STEB
#define DEVICE_GPIO_CFG_SPICLKB     GPIO_22_SPIB_CLK   // "pinConfig" for SPI CLKB
#define DEVICE_GPIO_CFG_SPISIMOB    GPIO_24_SPIB_SIMO  // "pinConfig" for SPI SIMOB
#define DEVICE_GPIO_CFG_SPISOMIB    GPIO_31_SPIB_SOMI  // "pinConfig" for SPI SOMIB
#define DEVICE_GPIO_CFG_SPISTEB     GPIO_27_SPIB_STE   // "pinConfig" for SPI STEB
// I2C
#define DEVICE_GPIO_PIN_SDAA        35U  // GPIO number for I2C SDAA
#define DEVICE_GPIO_PIN_SCLA        37U  // GPIO number for I2C SCLA
#define DEVICE_GPIO_CFG_SDAA        GPIO_35_I2CA_SDA  // "pinConfig" for I2C SDAA
#define DEVICE_GPIO_CFG_SCLA        GPIO_37_I2CA_SCL  // "pinConfig" for I2C SCLA
// eQEP
#define DEVICE_GPIO_PIN_EQEP1A      35U  // GPIO number for EQEP 1A
#define DEVICE_GPIO_PIN_EQEP1B      37U  // GPIO number for EQEP 1B
#define DEVICE_GPIO_PIN_EQEP1I      59U  // GPIO number for EQEP 1I
#define DEVICE_GPIO_CFG_EQEP1A      GPIO_35_EQEP1_A  // "pinConfig" for EQEP 1A
#define DEVICE_GPIO_CFG_EQEP1B      GPIO_37_EQEP1_B  // "pinConfig" for EQEP 1B
#define DEVICE_GPIO_CFG_EQEP1I      GPIO_59_EQEP1_INDEX  // "pinConfig" for EQEP 1I
// EPWM
#define DEVICE_PERIPHERAL_BASE_EPWM EPWM6_BASE  // Base peripheral EPWM 6
#define DEVICE_PERIPHERAL_INT_EPWM  INT_EPWM6   // Base peripheral EPWM 6 interrupt
#define DEVICE_GPIO_PIN_EPWMxA      10U  // GPIO number for EPWM6A
#define DEVICE_GPIO_PIN_EPWMxB      11U  // GPIO number for EPWM6B
#define DEVICE_GPIO_PIN_IOINDEX     8U   // GPIO number for IO Index
#define DEVICE_GPIO_CFG_EPWMxA      GPIO_10_EPWM6_A  // "pinConfig" for EPWM6A
#define DEVICE_GPIO_CFG_EPWMxB      GPIO_11_EPWM6_B  // "pinConfig" for EPWM6B
#define DEVICE_GPIO_CFG_IOINDEX     GPIO_8_GPIO8    // "pinConfig" for IO Index
#else
// ControlCARD
// LEDs
#define DEVICE_GPIO_PIN_LED1        31U  // GPIO number for LD2
#define DEVICE_GPIO_PIN_LED2        34U  // GPIO number for LD3
#define DEVICE_GPIO_CFG_LED1        GPIO_31_GPIO31  // "pinConfig" for LD2
#define DEVICE_GPIO_CFG_LED2        GPIO_34_GPIO34  // "pinConfig" for LD3
// CANA
#define DEVICE_GPIO_PIN_CANTXA      31U  // GPIO number for CANTXA
#define DEVICE_GPIO_PIN_CANRXA      30U  // GPIO number for CANRXA
#define DEVICE_GPIO_CFG_CANRXA      GPIO_30_CANA_RX  // "pinConfig" for CANA RX
#define DEVICE_GPIO_CFG_CANTXA      GPIO_31_CANA_TX  // "pinConfig" for CANA TX
// LINA
#define DEVICE_GPIO_CFG_LINTXA      GPIO_58_LINA_TX  // "pinConfig" for LINA TX
#define DEVICE_GPIO_CFG_LINRXA      GPIO_59_LINA_RX  // "pinConfig" for LINA RX
// FSI
#define DEVICE_GPIO_PIN_FSI_RXCLK   13U  // GPIO number for FSI RXCLK
#define DEVICE_GPIO_PIN_FSI_RX1     11U  // GPIO number for FSI RX1
#define DEVICE_GPIO_CFG_FSI_TXCLK   GPIO_27_FSITXA_CLK  // "pinConfig" for FSI TXCLK
#define DEVICE_GPIO_CFG_FSI_TX0     GPIO_26_FSITXA_D0  // "pinConfig" for FSI TX0
#define DEVICE_GPIO_CFG_FSI_RXCLK   GPIO_13_FSIRXA_CLK  // "pinConfig" for FSI RXCLK
#define DEVICE_GPIO_CFG_FSI_RX1     GPIO_11_FSIRXA_D1  // "pinConfig" for FSI RX1
// SPI
#define DEVICE_GPIO_PIN_SPICLKA     9U  // GPIO number for SPI CLKA
#define DEVICE_GPIO_PIN_SPISIMOA    8U  // GPIO number for SPI SIMOA
#define DEVICE_GPIO_PIN_SPISOMIA    10U  // GPIO number for SPI SOMIA
#define DEVICE_GPIO_PIN_SPISTEA     11U  // GPIO number for SPI STEA
#define DEVICE_GPIO_CFG_SPICLKA     GPIO_9_SPIA_CLK   // "pinConfig" for SPI CLKA
#define DEVICE_GPIO_CFG_SPISIMOA    GPIO_8_SPIA_SIMO  // "pinConfig" for SPI SIMOA
#define DEVICE_GPIO_CFG_SPISOMIA    GPIO_10_SPIA_SOMI // "pinConfig" for SPI SOMIA
#define DEVICE_GPIO_CFG_SPISTEA     GPIO_11_SPIA_STE   // "pinConfig" for SPI STEA
#define DEVICE_GPIO_PIN_SPICLKB     26U  // GPIO number for SPI CLKB
#define DEVICE_GPIO_PIN_SPISOMIB    25U  // GPIO number for SPI SOMIB
#define DEVICE_GPIO_CFG_SPICLKB     GPIO_26_SPIB_CLK   // "pinConfig" for SPI CLKB
#define DEVICE_GPIO_CFG_SPISOMIB    GPIO_25_SPIB_SOMI  // "pinConfig" for SPI SOMIB
// I2C
#define DEVICE_GPIO_PIN_SDAA        32U  // GPIO number for I2C SDAA
#define DEVICE_GPIO_PIN_SCLA        33U  // GPIO number for I2C SCLA
#define DEVICE_GPIO_CFG_SDAA        GPIO_32_I2CA_SDA  // "pinConfig" for I2C SDAA
#define DEVICE_GPIO_CFG_SCLA        GPIO_33_I2CA_SCL  // "pinConfig" for I2C SCLA
// eQEP
#define DEVICE_GPIO_PIN_EQEP1A      6U  // GPIO number for EQEP 1A
#define DEVICE_GPIO_PIN_EQEP1B      7U  // GPIO number for EQEP 1B
#define DEVICE_GPIO_PIN_EQEP1I      9U  // GPIO number for EQEP 1I
#define DEVICE_GPIO_CFG_EQEP1A      GPIO_6_EQEP1_A  // "pinConfig" for EQEP 1A
#define DEVICE_GPIO_CFG_EQEP1B      GPIO_7_EQEP1_B  // "pinConfig" for EQEP 1B
#define DEVICE_GPIO_CFG_EQEP1I      GPIO_9_EQEP1_INDEX  // "pinConfig" for EQEP 1I
// EPWM
#define DEVICE_PERIPHERAL_BASE_EPWM EPWM1_BASE  // Base peripheral EPWM 1
#define DEVICE_PERIPHERAL_INT_EPWM  INT_EPWM1   // Base peripheral EPWM 1 interrupt
#define DEVICE_GPIO_PIN_EPWMxA      0U  // GPIO number for EPWM1A
#define DEVICE_GPIO_PIN_EPWMxB      1U  // GPIO number for EPWM1B
#define DEVICE_GPIO_PIN_IOINDEX     2U  // GPIO number for IO Index
#define DEVICE_GPIO_CFG_EPWMxA      GPIO_0_EPWM1_A  // "pinConfig" for EPWM1A
#define DEVICE_GPIO_CFG_EPWMxB      GPIO_1_EPWM1_B  // "pinConfig" for EPWM1B
#define DEVICE_GPIO_CFG_IOINDEX     GPIO_2_GPIO2   // "pinConfig" for IO Index
#endif
#define DEVICE_GPIO_CFG_EPWM1A      GPIO_0_EPWM1_A  // "pinConfig" for EPWM1A
#define DEVICE_GPIO_PIN_EPWM1A      0U              // GPIO number for EPWM1A
// SCI for USB-to-UART adapter on FTDI chip
#define DEVICE_GPIO_PIN_SCIRXDA     28U             // GPIO number for SCI RX
#define DEVICE_GPIO_PIN_SCITXDA     29U             // GPIO number for SCI TX
#define DEVICE_GPIO_CFG_SCIRXDA     GPIO_28_SCIA_RX // "pinConfig" for SCI RX
#define DEVICE_GPIO_CFG_SCITXDA     GPIO_29_SCIA_TX // "pinConfig" for SCI TX
// Defines related to clock configuration
// 20MHz XTAL on controlCARD and Launchpad. For use with SysCtl_getClock().
#define DEVICE_OSCSRC_FREQ          20000000U
// Define to pass to SysCtl_setClock(). Will configure the clock as follows:
// PLLSYSCLK = 20MHz (XTAL_OSC) * 10 (IMULT) * 1 (FMULT) / 2 (PLLCLK_BY_2)
#define DEVICE_SETCLOCK_CFG         (SYSCTL_OSCSRC_XTAL | SYSCTL_IMULT(10) |  \
                                     SYSCTL_FMULT_NONE | SYSCTL_SYSDIV(2) |   \
                                     SYSCTL_PLL_ENABLE)
// 100MHz SYSCLK frequency based on the above DEVICE_SETCLOCK_CFG. Update the
// code below if a different clock configuration is used!
#define DEVICE_SYSCLK_FREQ          ((DEVICE_OSCSRC_FREQ * 10 * 1) / 2)
// 25MHz LSPCLK frequency based on the above DEVICE_SYSCLK_FREQ and a default
// low speed peripheral clock divider of 4. Update the code below if a
// different LSPCLK divider is used!
#define DEVICE_LSPCLK_FREQ          (DEVICE_SYSCLK_FREQ / 4)
// Configures the SYSCLK to 100MHz.
// Uses internal OSC2.
#define DEVISE_SETCLOCK_OSC2    (SYSCTL_OSCSRC_OSC2 | SYSCTL_IMULT(10) |  \
                                SYSCTL_FMULT_NONE | SYSCTL_SYSDIV(1) |   \
                                SYSCTL_PLL_ENABLE)
// Macro to call SysCtl_delay() to achieve a delay in microseconds. The macro
// will convert the desired delay in microseconds to the count value expected
// by the function. \b x is the number of microseconds to delay.
#define DEVICE_DELAY_US(x) SysCtl_delay(((((long double)(x)) / (1000000.0L /  \
                              (long double)DEVICE_SYSCLK_FREQ)) - 9.0L) / 5.0L)
//  Defines for setting FSI clock speeds in normal FSI mode (SPI_MODE == 0)
//  TXCLKIN = INPUT_CLOCK / PRESCALE_VAL
//  TXCLK (in FSI mode) = TXCLKIN / 2
//  TXCLK (in SPI mode) = TXCLKIN
//  Below assumes INPUT_CLOCK == 200 MHz (PLLRAWCLK, SEL_PLLCLK == 1)
#define FSI_PRESCALE_50MHZ          2U
#define FSI_PRESCALE_25MHZ          4U
#define FSI_PRESCALE_10MHZ          10U
#define FSI_PRESCALE_5MHZ           20U
// Defines, Globals, and Header Includes related to Flash Support
#ifdef _FLASH
#include <stddef.h>
extern uint16_t RamfuncsLoadStart;
extern uint16_t RamfuncsLoadEnd;
extern uint16_t RamfuncsLoadSize;
extern uint16_t RamfuncsRunStart;
extern uint16_t RamfuncsRunEnd;
extern uint16_t RamfuncsRunSize;
#endif
#define DEVICE_FLASH_WAITSTATES 4
extern uint32_t Example_PassCount;
extern uint32_t Example_Fail;
// Function Prototypes
//! \addtogroup device_api
//! @brief Function to initialize the device. Primarily initializes system control to a
//! known state by disabling the watchdog, setting up the SYSCLKOUT frequency,
//! and enabling the clocks to the peripherals.
//! The function also configures the GPIO pins 22 and 23 in digital mode.
//! To configure these pins as analog pins, use the function GPIO_setAnalogMode
//! \return None
extern void Device_init(void);
//! @brief Function to turn on all peripherals, enabling reads and writes to the
//! peripherals' registers.
//! Note that to reduce power, unused peripherals should be disabled.
//! \return None
extern void Device_enableAllPeripherals(void);
//! @brief Function to disable pin locks and enable pullups on GPIOs.
//! \return None
extern void Device_initGPIO(void);
//! @brief Error handling function to be called when an ASSERT is violated
//! \param *filename File name in which the error has occurred
//! \param line Line number within the file
//! \return None
extern void __error__(char *filename, uint32_t line);
// Close the Doxygen group.
#endif // __DEVICE_H__
 * Copyright (c) 2020 Texas Instruments Incorporated - http://www.ti.com
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "board.h"
void Board_init()
	EALLOW;
	PinMux_init();
	GPIO_init();
	EDIS;
void PinMux_init()
	// GPIO22_VFBSW -> myGPIO1 Pinmux
	GPIO_setPinConfig(GPIO_22_GPIO22);
	// GPIO28 -> myGPIO0 Pinmux
	GPIO_setPinConfig(GPIO_28_GPIO28);
void GPIO_init(){
	//myGPIO1 initialization
	GPIO_setDirectionMode(myGPIO1, GPIO_DIR_MODE_OUT);
	GPIO_setPadConfig(myGPIO1, GPIO_PIN_TYPE_STD);
	GPIO_setMasterCore(myGPIO1, GPIO_CORE_CPU1);
	GPIO_setQualificationMode(myGPIO1, GPIO_QUAL_ASYNC);
	//myGPIO0 initialization
	GPIO_setDirectionMode(myGPIO0, GPIO_DIR_MODE_OUT);
	GPIO_setPadConfig(myGPIO0, GPIO_PIN_TYPE_STD);
	GPIO_setMasterCore(myGPIO0, GPIO_CORE_CPU1);
	GPIO_setQualificationMode(myGPIO0, GPIO_QUAL_ASYNC);
 * are met:
#ifndef BOARD_H
#define BOARD_H
// Included Files
#include "device.h"
#define myGPIO1 22
#define myGPIO0 28
void	Board_init();
void	GPIO_init();
void	PinMux_init();
#endif  // end of BOARD_H definition
4572.10mm_Top-Hat_Alternate schematic 1-19-2022.pdf
  • GPIO28 toggles with an amplitude of only 1.75V
    This is a correction.  The GPIO28 does not toggle with an amplitude of 1.75V.  It toggles from 1.6V to 3.36V.  Sorry about that.
  • Another correction, I'm sorry about all this.  The GPIO28 does toggle with an amplitude of 1.75V, (0V to 1.75V).  GPIO29 toggles from 1.6V to 3.36V.
        for(;;)
            // Turn on LED
            GPIO_writePin(myGPIO2, 0);
            // Delay for a bit.
            // Turn off LED
            GPIO_writePin(myGPIO2, 1);
            // Delay for a bit.
    We have assigned to subject matter expert. Please expect response later today.
  • Hi Dennis,
    Thanks for your question.
    Debugging the two pins separately:
    GPIO22_VFBSW
    I believe this is likely due to the DC-DC not being disabled or the GPAAMSEL register not being cleared. See pin description for items that must be updated to use GPIO22 as a GPIO (it is not a GPIO by default):
    If this is not the reason, which it may not be considering you said the exact program works on the controlcard:
    Then it seems like from your description that whatever other board is connected to the GPIO22_VFBSW is actually 5V logic. It's acting like there's a 5V pull-up on the other board. It's floating between two intermediary values because it's either being driven or pulled-up to that 5V logic level. All IO pins on the F28004x are 3.3V logic level.
    GPIO28
    Similar to the above for GPIO22, I believe this looks like the SPI peripheral on the other board may be 5V logic levels, and the voltage attempting to be driven by F28004x GPIO28 is at 3.3V logic level. Thus you get an intermediary voltage level.
    Could you check the above and let me know what you find? I definitely do think this is board-related if you compiled the exact same program and it worked correctly on the control-card. Just make sure you were also running from RAM or FLASH on both boards (keep that consistent too to eliminate other variables).
    Vince
  • Dear Mr. Toledo
    Yes, I believe you're correct.  When I disconnect the tow PCAs and power the problem PCA separately with the signal wires floating, everything works as expected.  The SPI slave of the F280045 is connected to a TIVA TM4C1292.  I will make sure the TIVA is configured correctly.
    I have one more question.  It's a little off topic.  I'm trying to cut current draw as much as possible.  The only part of the F280045 that i'm using is the two SPI ports and the FP coprocessor.  Please take a look at the void Device_enableAllPeripherals(void) function.  See below.  Are there any other clocks that I can disable?
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_DMA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_HRPWM);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM1);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM2);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM3);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM4);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM5);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM6);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM7);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EPWM8);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ECAP1);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ECAP2);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ECAP3);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ECAP4);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ECAP5);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ECAP6);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ECAP7);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EQEP1);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_EQEP2);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_SCIA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_SCIB);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_I2CA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CANA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CANB);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ADCA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ADCB);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_ADCC);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CMPSS1);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CMPSS2);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CMPSS3);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CMPSS4);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CMPSS5);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CMPSS6);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CMPSS7);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_PGA1);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_PGA2);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_PGA3);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_PGA4);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_PGA5);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_PGA6);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_PGA7);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_DACA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_DACB);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_LINA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_FSITXA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_FSIRXA);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CLB1);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CLB2);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CLB3);
        SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_CLB4);
  • Hi Dennis,
    By default all peripherals are disabled on reset, but if you enabled any peripherals that are not needed in your system, you can the following peripherals for the associated current reduction below:
    You can also look to reduce the current by reducing frequency if that's an option for your system. We have some details on expected IDD/IDDIO/IDDA reduction based on frequency in the datasheet (screenshot here):
    Vince
  • Thank you for your help.
