TMS320F28069: Serial Flash Programming bootup SCI mode Require Reset?
Part Number: TMS320F28069
Other Parts Discussed in Thread: LAUNCHXL-F28069M, C2000WARE
Hi helpers,
I tried using the C2000ware example to build serial_flash_programming.txt and the flash_2806x.txt. Tried on LAUNCHXL-F28069M. The terminal wait at "start downloading example to device". When I pressed the reset button on board. Then the terminal move on and application load successful after some echo. My question is on the need for reset as I already bootup using SCI boot mode.
Setting the bootup pin to SCI mode. I suppose once the board is powered up. The controller run the bootrom and stop at waiting SCI boot after reading the SCI bootmode pin. Then when PC software run the flash kernel. It will program to flash right away. Why is there a reset needed? Because this may affect the product design adding one button for this firmware upgrade.
Besides: In the example project given, the download process automatically branch to the new codeStart location and flash the LED. Is this auto branch be disable? So that I can make sure bootmode pin needs to change back to flash mode after someone update the firmware.
Albert
  • Hi Albert,
    Will need some more time to look into the specifics, but from what I've read the reason the device performs a reset is to go to flash boot mode (entry point for application code). If the device reset to SCI boot mode, it would not be able to get out of SCI and run the application in Flash.
    Will look at the example and get back to you within the next day.
    Charles
  • Hi Charles,
    I am also suspecting the bootmode. But all I did is switch the pin, then power on. Try press command on PC side. Unsuccessful few times. Then press the restart. Then Try again the command on PC side. Then it immediately works.
    So I wonder why not bootup as SCI mode at first. Please help and see if you repeat the same case on your launchpad perhaps? As this really change the way in design. Thanks
  • Hi Albert,
    Currently am also getting stuck at downloading flash_f2806.txt to the device. Is your device configured in this way?
    Yes, what should happen is that the bootrom detects the boot pins to be SCI mode, then it will download the kernel, which in turn will program the flash memory for the application file. It is strange that a reset is needed to continue operation. Is it possible the kernel code is not erasing all sectors?
    Could you share here your version of flash_f2806.txt from the example?
    Will continue looking into this later today.
    Charles
  • i) Mine is a LaunchPad, the Red one. Only with min USB connection. No Docking needed.
    ii)Sure. Here attached the converted sci_flash_kernel.txt and LED_blink.txt
    f28069_sci_flash_kernel.txt
    AA 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 62 83 02 00
    00 00 00 00 40 00 57 83
    B6 00 00 00 50 00 0C FE 40 76 05 81 22 76 BC 9A A8 28 20 01 1F 76 34 00
    04 1E 1F 76 34 00 00 02 02 1E 1A 76 69 FF 0F 9A 00 8F 04 E4 7F 76 BD FE
    4A 96 00 52 E0 FF 99 00 40 76 AA 82 1F 76 90 03 02 C5 67 3E 48 96 EF FF
    8D 00 A9 1B 00 04 5E 69 40 76 88 82 46 1E 4C 2B 2E 6F 00 8F 00 E0 44 A8
    BF 56 4B 01 4B 1B 00 04 10 66 1F 76 90 03 02 C5 67 3E 49 96 44 C5 A7 06
    01 09 44 1E 49 92 C7 96 4B 0A 4B 1B 00 04 F2 69 00 8F 04 E4 80 76 00 04
    42 A8 40 8F 00 E0 A6 06 46 8A 7F 76 BB FE 4A 96 00 52 62 60 00 8F 00 04
    A9 A8 46 07 46 1E 40 76 AA 82 4C 0A 48 92 C9 FF 4C 54 D0 66 00 8F 00 E0
    44 A8 BF 56 4B 01 0D 6F 1F 76 90 03 02 C5 67 3E 49 96 44 C5 A7 06 01 09
    44 1E 49 92 C7 96 4B 0A 48 CC FF 03 4B 54 F1 67 00 8F 04 E4 42 A8 40 8F
    00 E0 48 CC FF 03 46 8A A9 0E 7F 76 BB FE 4A 96 00 52 32 60 40 76 AA 82
    27 6F 40 76 88 82 46 1E 00 8F 00 E0 44 A8 BF 56 4B 01 0D 6F 1F 76 90 03
    02 C5 67 3E 49 96 44 C5 A7 06 01 09 44 1E 49 92 C7 96 4B 0A 48 92 4B 54
    F2 67 00 8F 04 E4 42 A8 40 8F 00 E0 48 0E 46 8A 7F 76 BB FE 4A 96 00 52
    0B 60 40 76 AA 82 1F 76 90 03 02 C5 67 3E 48 96 00 52 E0 FF 74 FF 8C FE
    06 00 01 19 C3 56 FF FF 06 00
    62 03 00 00 00 80 40 76 24 80 22 76 1F 76 C0 01 1C 1A 08 00 FD 76 80 7C
    69 FF 67 3E 1F 76 C0 01 1C 18 F7 FF 1A 76 69 FF 40 76 36 81 12 9A 02 9B
    40 76 2C 80 40 76 AF 80 06 00 22 76 1F 76 C0 01 BF 56 25 55 BF 56 25 AA
    1A 76 69 FF 06 00 22 76 1F 76 C0 01 BF 56 29 68 1A 76 69 FF 06 00 02 FE
    42 97 41 96 1F 76 C0 01 11 43 06 6C 22 76 11 1A 10 00 1A 76 25 76 11 CC
    80 01 C6 FF 05 61 22 76 11 18 7F FE 1A 76 41 0E A6 1E 21 92 1F 90 A9 80
    A6 06 A7 0F 16 61 22 76 11 1A 40 00 41 92 21 CD E0 FF 1F 90 A8 CA 21 96
    1A 76 69 FF 40 76 24 80 11 92 01 90 01 52 FD 60 22 76 11 18 BF FF 1A 76
    42 92 01 52 03 61 02 52 09 60 22 76 03 90 11 CD 7F FE 86 FF A8 CA 11 96
    1A 76 42 92 03 52 12 60 22 76 11 CC 7F FE A9 1A 00 01 11 96 00 8F 82 03
    69 FF A9 A8 40 76 02 01 1F 76 C0 01 11 1A 80 01 1A 76 82 FE 69 FF 06 00
    04 FE 43 7C 42 97 41 96 22 76 1F 76 22 00 01 4E 03 6C 01 18 FF BF 1F 76
    C0 01 30 1A 04 00 03 90 30 CD FC FF A8 CA 30 96 42 92 0F 90 32 CD F0 FF
    A8 CA 32 96 69 FF 40 76 24 80 34 92 01 90 01 52 FD 60 1F 76 22 00 43 92
    01 CD FF BF 01 90 8D FF A8 CA 01 96 1A 76 69 FF 84 FE 06 00 22 76 1F 76
    C0 01 BF 56 1B 02 10 CC FC FF 02 50 10 96 1D 1A 01 00 1D 1A 02 00 1D 1A
    04 00 1D 1A 08 00 1D 1A 10 00 1D 1A 20 00 1D 1A 40 00 1D 1A 80 00 1C 1A
    01 00 1C 1A 04 00 1D 1A 00 40 1D 1A 00 80 1D 1A 00 01 1D 1A 00 02 1D 1A
    00 04 19 1A 00 01 19 1A 00 02 19 1A 00 04 19 1A 00 08 1C 1A 08 00 20 1A
    01 00 20 1A 02 00 20 1A 04 00 20 1A 00 01 20 1A 00 02 20 1A 00 04 20 1A
    00 08 20 1A 00 40 20 1A 00 80 1C 1A 10 00 1C 1A 00 01 1C 1A 00 02 1C 1A
    00 04 1C 1A 00 08 1C 1A 00 10 1C 1A 00 40 1C 1A 04 00 1A 76 69 FF 06 00
    02 FE 22 76 1F 76 2B 00 20 28 FF FF 21 28 FF FF 22 28 FF FF 23 28 FF FF
    24 28 FF FF 25 28 FF FF 26 28 FF FF 27 28 FF FF 1A 76 1F 76 FF FD 38 92
    41 96 39 92 41 96 3A 92 41 96 3B 92 41 96 3C 92 41 96 3D 92 41 96 3E 92
    41 96 3F 92 41 96 1F 76 2B 00 2F 40 03 6D 01 9A 02 6F 00 9A 82 FE 69 FF
    06 00 22 76 1F 76 C0 01 12 18 FF FE 12 18 FE FF 12 1A 00 20 12 1A 00 40
    12 1A 00 04 1A 76 69 FF 06 00 22 76 1F 76 C0 01 12 1A 00 60 12 18 FF 9F
    12 1A 00 60 12 18 FF 9F 12 1A 00 60 12 18 FF FB 12 1A 02 00 12 1A 01 00
    12 18 FB FF 12 18 FF FE 1A 76 69 FF 06 00 22 76 1F 76 C0 01 12 18 FF BF
    00 8F 4E 46 69 FF A9 A8 40 76 02 01 1F 76 C0 01 12 1A 00 20 12 18 FD FF
    12 1A 01 00 12 18 FB FF 12 1A 00 04 12 18 FF FE 1A 76 69 FF 06 00 22 76
    1F 76 C0 01 10 1A 40 00 12 1A 00 40 12 18 FF DF 12 18 FD FF 12 1A 01 00
    12 18 FB FF 12 1A 00 04 12 18 FF FE 1A 76 69 FF 06 00 22 76 1F 76 C0 01
    1C 1A 00 04 BF 56 1B 02 1F 76 C1 01 1A 28 00 80 BF 56 10 07 BF 56 11 03
    14 2B BF 56 11 23 1F 76 BE 01 0C 06 A8 18 FF CF 0C 1E 08 06 A8 1A 00 05
    08 1E 05 1A 00 03 1A 76 69 FF 06 00 02 FE 1F 76 C1 01 BF 56 13 01 1C 1A
    00 20 1C 1A 00 40 1C CC 00 80 CE FF 01 52 FC 60 1C 1A 00 40 1C 18 FF DF
    15 CC 40 00 C5 FF 01 52 FC 60 17 C6 41 96 19 96 82 FE 06 00 02 FE 00 8F
    13 82 1F 76 90 03 02 A8 40 76 92 81 40 76 B3 81 1F 76 90 03 00 2B 40 76
    13 82 A9 88 00 8F AA 08 A9 A8 A6 0F 04 61 3F 8F F6 7F 09 6F 40 76 9A 82
    40 76 88 82 42 1E 40 76 50 00 42 8A 82 FE A9 A8 06 00 02 FE 41 2B 42 2B
    1F 76 C1 01 15 CC 40 00 C5 FF 01 52 FA 60 17 C6 41 96 19 96 15 CC 40 00
    C5 FF 01 52 FC 60 17 C6 42 96 19 96 1F 76 90 03 41 92 00 94 42 94 00 96
    03 56 42 08 41 98 41 92 82 FE 06 00 02 FE 41 2B 42 2B 1F 76 C1 01 15 CC
    40 00 C5 FF 01 52 FA 60 17 C6 41 96 15 CC 40 00 C5 FF 01 52 FC 60 17 C6
    42 96 1F 76 90 03 41 92 00 94 42 94 00 96 03 56 42 08 41 98 41 92 82 FE
    06 00 AD 28 00 04 69 FF 1F 56 16 56 1A 56 10 E6 00 02 40 29 1F 76 00 00
    02 29 1B 76 40 76 5F 83 00 52 42 61 22 76 A9 28 06 01 A8 28 00 00 01 09
    1B 61 C0 76 06 01 04 29 0F 6F 00 9B A9 24 01 DF 04 6C 04 29 A8 24 01 DF
    A6 1E A1 F7 86 24 A7 06 A1 81 01 09 A7 1E A9 24 03 63 5C FF 04 3B A9 59
    01 DF 09 00 EC FF A9 28 FF FF A8 28 FF FF 01 09 05 61 3F 8F FF FF 40 76
    EB 82 1A 76 40 76 61 83 A9 28 FF FF A8 28 FF FF 01 09 0E 61 FF 76 FF FF
    06 6F 01 DF BD C3 A7 1E 67 3E BE C5 A9 24 01 DF A8 24 58 FF F7 60 40 76
    2C 83 40 76 C4 82 02 FE 1F 76 90 03 02 C5 67 3E 01 29 A9 25 42 1E 1F 76
    90 03 02 C5 67 3E A9 0E 42 98 41 99 42 06 82 FE 06 00 02 FE BF 56 41 01
    41 92 08 52 09 66 1F 76 90 03 02 C5 67 3E 41 0A 41 92 08 52 F9 69 82 FE
    06 00 1F 76 C1 01 14 47 FD 6C 1F 76 90 03 00 C6 1F 76 C1 01 19 96 14 47
    FF 6C 1F 76 90 03 00 CC 00 FF 1F 76 C1 01 C7 FF 19 96 1F 76 90 03 00 2B
    06 00 00 77 00 6F BD B2 1F 76 90 03 A9 59 08 92 0D 61 AB 28 FF FF AA 28
    FF FF A9 28 FF FF A8 28 FF FF AB 0F 03 61 7F 76 FF FF 1F 76 90 03 0E C5
    67 3E 1F 76 90 03 0C 06 04 61 A7 1E A1 92 67 3E 1F 76 90 03 0A 06 03 61
    A7 1E 67 3E 40 76 C2 82 BE 8B 06 00 BD B2 BD AA BD A2 08 FE A4 82 00 D1
    CB 5A 15 6F AD 5C 01 29 03 56 A1 03 A3 07 88 DC 02 09 A4 5C A9 83 08 02
    40 76 0F 83 42 06 06 61 44 8A 46 83 40 76 0F 83 CB 5A 01 D9 A2 92 A1 54
    EA 66 88 FE BE 82 BE 86 BE 8B 06 00 00 52 AB A8 A4 C5 07 61 A9 88 81 DE
    85 5C 87 7C 0E 00 FE FF A9 88 A6 0F 0F 61 00 53 0D 61 FF 9D A8 5C BF 76
    FE FF 85 92 87 96 0E 00 FE FF 85 92 87 96 0C 00 F8 FF A4 A9 06 00 00 02
    AB 28 FF FF AA 28 FF FF 01 19 AB 0F 04 60 00 9A 00 D4 05 6F A4 A9 C4 92
    A4 A9 02 DC 40 76 3E 83 06 00 40 76 24 80 40 76 36 81 12 9A 02 9B 40 76
    2C 80 00 8F 06 07 A9 A8 40 76 02 01 40 76 CF 81 06 00 1F 76 90 03 10 A8
    06 00 1F 76 90 03 0E A8 06 00 06 00 1F 56 22 76 C0 B9 29 28 68 00 1A 76
    40 00 32 82 01 9A 06 00 06 00
    26 00 00 00 62 83 AD 28 00 04 1F 56 16 56 1A 56 40 29 1F 76 00 00 02 29
    69 FF 40 76 3E 83 CF 56 02 00 AD 28 00 04 BD 2B BD 2B BD 1E 07 00 33 56
    AC 1E A9 58 A9 59 A9 5A A9 5B A9 5C A9 5D A9 88 A9 80 1F 76 00 00 BD 2B
    BD 28 0B 0A 00 76 13 76 06 00
    1A 00 00 00 06 01 FF FF 08 E4 00 00 01 00 FE FF 0A E4 00 00 00 00 00 00
    FE FF 0C E4 00 00 00 00 00 00 FE FF 0E E4 00 00 56 83 00 00 FE FF 10 E4
    00 00 56 83 00 00 00 00 00 00
    00 00
    And this is the LED_
    @0000
    00 00 3F 00 F6 7F 26 07 3F 00 00 40 1B 76 F0 FF
    00 E2 BD 00 30 E6 00 06 42 29 16 56 25 76 00 6F
    1B 76 F0 FF 00 E2 BD 00 30 E6 00 06 42 29 16 56
    25 76 00 6F 1B 76 F0 FF 00 E2 BD 00 30 E6 00 06
    42 29 16 56 25 76 00 6F 1B 76 F0 FF 00 E2 BD 00
    30 E6 00 06 42 29 16 56 25 76 00 6F 1B 76 F0 FF
    80 E2 BE 00 F1 FF 17 76 02 76 1B 76 F0 FF 00 E2
    BD 00 30 E6 00 06 42 29 16 56 25 76 00 6F 1B 76
    F0 FF 00 E2 BD 00 30 E6 00 06 42 29 16 56 25 76
    00 6F 7F 76 BF 43 22 76 1F 76 C0 01 1C 1A 08 00
    FD 76 80 7C 69 FF 67 3E 1F 76 C0 01 1C 18 F7 FF
    1A 76 69 FF 7F 76 D1 44 12 9A 02 9B 7F 76 C7 43
    7F 76 4A 44 06 00 22 76 1F 76 C0 01 BF 56 25 55
    BF 56 25 AA 1A 76 69 FF 06 00 22 76 1F 76 C0 01
    BF 56 29 68 1A 76 69 FF 06 00 02 FE 42 97 41 96
    25 76 11 CC 80 01 C6 FF 05 61 22 76 11 18 7F FE
    1A 76 41 0E A6 1E 21 92 1F 90 A9 80 A6 06 A7 0F
    A8 CA 21 96 1A 76 69 FF 7F 76 BF 43 11 92 01 90
    01 52 FD 60 22 76 11 18 BF FF 1A 76 42 92 01 52
    A8 CA 11 96 1A 76 42 92 03 52 12 60 22 76 11 CC
    7F FE A9 1A 00 01 11 96 00 8F 82 03 69 FF A9 A8
    40 76 00 80 1F 76 C0 01 11 1A 80 01 1A 76 82 FE
    69 FF 06 00 04 FE 43 7C 42 97 41 96 22 76 1F 76
    22 00 01 4E 03 6C 01 18 FF BF 1F 76 C0 01 30 1A
    32 CD F0 FF A8 CA 32 96 69 FF 7F 76 BF 43 34 92
    01 90 01 52 FD 60 1F 76 22 00 43 92 01 CD FF BF
    22 76 1F 76 C0 01 BF 56 1B 02 10 CC FC FF 02 50
    10 96 1D 1A 01 00 1D 1A 02 00 1D 1A 04 00 1D 1A
    80 00 1C 1A 01 00 1C 1A 04 00 1D 1A 00 40 1D 1A
    00 80 1D 1A 00 01 1D 1A 00 02 1D 1A 00 04 19 1A
    08 00 20 1A 01 00 20 1A 02 00 20 1A 04 00 20 1A
    00 01 20 1A 00 02 20 1A 00 04 20 1A 00 08 20 1A
    00 02 1C 1A 00 04 1C 1A 00 08 1C 1A 00 10 1C 1A
    00 40 1C 1A 04 00 1A 76 69 FF 06 00 02 FE 22 76
    23 28 FF FF 24 28 FF FF 25 28 FF FF 26 28 FF FF
    27 28 FF FF 1A 76 1F 76 FF FD 38 92 41 96 39 92
    41 96 3E 92 41 96 3F 92 41 96 1F 76 2B 00 2F 40
    03 6D 01 9A 02 6F 00 9A 82 FE 69 FF 06 00 22 76
    12 1A 00 40 12 1A 00 04 1A 76 69 FF 06 00 22 76
    1F 76 C0 01 12 1A 00 60 12 18 FF 9F 12 1A 00 60
    12 1A 01 00 12 18 FB FF 12 18 FF FE 1A 76 69 FF
    06 00 22 76 1F 76 C0 01 12 18 FF BF 00 8F 4E 46
    69 FF A9 A8 40 76 00 80 1F 76 C0 01 12 1A 00 20
    12 18 FD FF 12 1A 01 00 12 18 FB FF 12 1A 00 04
    1A 76 69 FF 06 00 00 8F 00 0C 1F 76 84 02 00 A8
    00 02 1F 76 30 00 01 19 02 1E 06 2B 07 2B 04 1A
    10 00 04 1A 20 00 00 8F 08 0C 1F 76 84 02 08 A8
    00 8F 10 0C 10 A8 1F 76 30 00 00 02 01 19 0A 1E
    1F 76 30 00 00 02 01 19 12 1E 1F 76 30 00 0E 2B
    0F 2B 1F 76 30 00 16 2B 17 2B 1F 76 30 00 0C 1A
    10 00 1F 76 30 00 14 1A 10 00 1F 76 30 00 0C 1A
    20 00 1F 76 30 00 14 1A 20 00 06 00 08 FE 03 E2
    46 01 03 E2 44 00 42 A8 44 06 E4 1E 42 8A 46 06
    F4 1E AF E2 44 00 AF E2 46 01 00 E7 08 00 00 77
    8A E6 00 00 00 77 03 E2 48 00 42 8A C4 8A 48 06
    01 19 D4 1E 42 8A C4 8A F4 2B 42 8A C4 8A FC 2B
    42 8A C4 8A E4 1A 10 00 42 8A C4 8A E4 1A 20 00
    42 8A C4 8A E4 18 FF FB 42 8A C4 8A E4 18 FF F7
    42 8A C4 8A E4 1A 00 40 42 8A 00 02 D4 1E 88 FE
    00 02 40 29 1F 76 00 00 02 29 1B 76 7F 76 23 47
    00 52 42 61 22 76 A9 28 26 47 A8 28 3F 00 01 09
    1B 61 FF 76 26 47 04 29 0F 6F 00 9B A9 24 01 DF
    04 6C 04 29 A8 24 01 DF A6 1E A1 F7 86 24 A7 06
    05 61 3F 8F FF FF 7F 76 A5 46 1A 76 7F 76 25 47
    A8 24 58 FF F7 60 7F 76 00 47 7F 76 30 46 7F 76
    9B 43 10 3B 69 FF 7F 76 57 46 26 76 00 00 2F 76
    00 00 7F 76 7F 46 22 76 1F 76 35 00 3F 8F E6 46
    0C A8 1A 76 69 FF 7F 76 2D 45 02 E8 A1 47 02 E8
    00 15 00 8F 00 A1 09 E8 01 20 7F 76 68 45 1F 76
    30 00 04 28 01 40 22 76 1F 76 BE 01 16 18 CF FF
    1A 1A 04 00 1A 76 23 76 01 00 1F 76 33 00 22 1A
    40 00 10 29 20 29 00 6F 00 77 00 6F BD B2 1F 76
    84 02 A9 59 18 92 0D 61 AB 28 FF FF AA 28 FF FF
    1F 76 84 02 1E C5 67 3E 1F 76 84 02 1C 06 04 61
    A7 1E A1 92 67 3E 1F 76 84 02 1A 06 03 61 A7 1E
    67 3E 7F 76 2E 46 BE 8B 06 00 10 3B 1F 76 33 00
    20 18 FE FF 22 2B 24 2B 26 2B 28 2B 2A 2B 2C 2B
    2E 2B 30 2B 32 2B 34 2B 36 2B 38 2B 23 2B 25 2B
    27 2B 29 2B 2B 2B 2D 2B 2F 2B 31 2B 33 2B 35 2B
    37 2B 39 2B 69 FF 06 00 1F 76 33 00 20 1A 01 00
    21 28 FF FF 10 29 69 FF 06 00 06 FE 00 8F 00 A0
    42 A8 00 8F 00 0D 44 A8 06 02 42 07 42 1E 06 02
    44 07 44 1E 22 76 45 2B 45 92 7D 52 0D 63 44 83
    42 8A A9 A0 84 C4 02 09 42 A8 44 1E C5 C2 45 0A
    45 92 7D 52 F5 64 1A 76 1F 76 33 00 20 1A 01 00
    69 FF 86 FE 06 00 BD B2 BD AA BD A2 08 FE A4 82
    00 D1 CB 5A 15 6F AD 5C 01 29 03 56 A1 03 A3 07
    88 DC 02 09 A4 5C A9 83 08 02 7F 76 C9 46 42 06
    06 61 44 8A 46 83 7F 76 C9 46 CB 5A 01 D9 A2 92
    A1 54 EA 66 88 FE BE 82 BE 86 BE 8B 06 00 00 52
    AB A8 A4 C5 07 61 A9 88 81 DE 85 5C 87 7C 0E 00
    BF 76 FE FF 85 92 87 96 0E 00 FE FF 85 92 87 96
    0C 00 F8 FF A4 A9 06 00 1B 76 F0 FF 00 E2 BD 00
    30 E6 00 06 42 29 16 56 01 02 1F 76 84 02 01 56
    02 00 1F 76 BF 01 0E 1A 04 00 1F 76 33 00 BF 56
    21 01 80 E2 BE 00 F1 FF 17 76 02 76 00 02 AB 28
    05 6F A4 A9 C4 92 A4 A9 02 DC 7F 76 F9 45 06 00
    1F 76 84 02 20 A8 06 00 1F 76 84 02 1E A8 06 00
    06 00 1F 56 22 76 C0 B9 29 28 68 00 1A 76 7F 00
    A3 45 01 9A 06 00 06 00 1A 00 3F 00 26 47 FF FF
    18 A1 00 00 01 00 FE FF 1A A1 00 00 00 00 00 00
    FE FF 1C A1 00 00 00 00 00 00 FE FF 1E A1 00 00
    1A 47 3F 00 FE FF 20 A1 00 00 1A 47 3F 00 00 00
    00 00 02 00 3F 00 F6 7F 7F 00 1B 47 04 00 3E 00
    00 80 01 19 C3 56 FF FF 06 00 00 01 00 00 00 A0
    87 43 3F 00 87 43 3F 00 87 43 3F 00 87 43 3F 00
    87 43 3F 00 00 40 3F 00 0A 40 3F 00 14 40 3F 00
    1E 40 3F 00 28 40 3F 00 32 40 3F 00 3C 40 3F 00
    46 40 3F 00 50 40 3F 00 5A 40 3F 00 64 40 3F 00
    6E 40 3F 00 78 40 3F 00 82 40 3F 00 8C 40 3F 00
    96 40 3F 00 A0 40 3F 00 AA 40 3F 00 B4 40 3F 00
    BE 40 3F 00 C8 40 3F 00 91 43 3F 00 D2 40 3F 00
    DC 40 3F 00 E6 40 3F 00 F0 40 3F 00 FA 40 3F 00
    04 41 3F 00 0E 41 3F 00 18 41 3F 00 22 41 3F 00
    2C 41 3F 00 36 41 3F 00 40 41 3F 00 4A 41 3F 00
    54 41 3F 00 5E 41 3F 00 68 41 3F 00 72 41 3F 00
    7C 41 3F 00 86 41 3F 00 90 41 3F 00 9A 41 3F 00
    A4 41 3F 00 AE 41 3F 00 B8 41 3F 00 91 43 3F 00
    91 43 3F 00 91 43 3F 00 C2 41 3F 00 CC 41 3F 00
    D6 41 3F 00 E0 41 3F 00 91 43 3F 00 EA 41 3F 00
    F4 41 3F 00 91 43 3F 00 91 43 3F 00 FE 41 3F 00
    08 42 3F 00 12 42 3F 00 1C 42 3F 00 12 42 3F 00
    30 42 3F 00 3A 42 3F 00 91 43 3F 00 91 43 3F 00
    44 42 3F 00 4E 42 3F 00 58 42 3F 00 62 42 3F 00
    6C 42 3F 00 76 42 3F 00 91 43 3F 00 91 43 3F 00
    80 42 3F 00 8A 42 3F 00 91 43 3F 00 91 43 3F 00
    91 43 3F 00 91 43 3F 00 91 43 3F 00 91 43 3F 00
    94 42 3F 00 9E 42 3F 00 A8 42 3F 00 B2 42 3F 00
    BC 42 3F 00 C6 42 3F 00 91 43 3F 00 91 43 3F 00
    91 43 3F 00 91 43 3F 00 D0 42 3F 00 DA 42 3F 00
    E4 42 3F 00 EE 42 3F 00 F8 42 3F 00 02 43 3F 00
    0C 43 3F 00 16 43 3F 00 20 43 3F 00 2A 43 3F 00
    34 43 3F 00 3E 43 3F 00 48 43 3F 00 52 43 3F 00
    5C 43 3F 00 91 43 3F 00 91 43 3F 00 91 43 3F 00
    91 43 3F 00 91 43 3F 00 66 43 3F 00 70 43 3F 00
    00 00
    q
  • Hi Albert,
    Thanks, I'll try these out and get back to you within the next day.
    Charles
  • Hi Charles,
    May I know if any update? Is it a must to add this reset button even bootup at SCI mode?
  • Hi Albert,
    Back from holiday, left this device at the office. From what I last tested, it required a reset, but I still don't believe it to be necessary. Will update you tomorrow.
    Charles
  • Hi Albert,
    I'll need to grab the LP version at the office to confirm, but testing the ISO controlCard I was able to load the blinky routine. Have you also been able to load the kernel via the CCS and program the blinky routine with the host programmer?
    Charles
