Part Number: TMDSCNCD28388D
I have setup the test platform using TMDSCNCD28388D control card with my customized power board to run servo motor.
Step by step, I have completed the steps according to TI's document with build level 8 in spracm9b.pdf, finally established the connection between Twincat on PC and the control card successfully.
But I can not find any further available documents from TI website that can help me to run the motor simply in the TwinCat environment.
I have surveyed some Twincat documents from webs, but I find that the documents are complicated. I just want to run the motor simply in TwinCat environment to learn the EtherCat technology.
Is there any extended documents from TI or other sources available so as to help me to test the motor simply through TwinCat to the control card?
Thank you.
