Part Number: TMS320F280037
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
I miss the ecap module in the 003x sysconfig. Will it be included in future? Should I use a GPIO today?
Regards, Holger
Regards, Holger
Hi Holger,
Which version of C2000Ware are you using? Also what release of SysConfig are you using? Could you send a screenshot of what modules you're seeing?
Make sure to select a C2000Ware Software Product. When this is unselected ECAP module is not there for 003x.
Ryan Ma
Hi Holger,
Great glad to know you can see it. For future reference this is what I did for the setup:
1. At https://dev.ti.com/sysconfig/ select the software product to be C2000 SysConfig
2. Select your device as shown below in screenshot
Hello Ryan,
I have another question to the Analog Block in the Sysconfig tool. I see that I can choose the analog pins for the Analog Block. Is it possible to assign to each of the 3 ADCs (ADCA, ADCB, ADCC) the dedicated pins (eg ADCA to A0, A5, A8, A9, A10)? In this case customer needed 10x ADC input, 2x DAC, 1x CMP and each needs an own pin.
Also it would be great if the pin in the configuration view window would light up in the package view window. Then you would directly see when you change anything.
Regards, Holger
Hi Holger,
Could you create a new thread for this question so I can refer you the correct subject matter expert for this and close this current thread.
Ryan Ma
