Part Number: TMS320F28333
I am having an error in running the simple ePWM block in the console window using CCS10.2. Community members, please suggest this to resolve.
**** Build of configuration Release for project PWM_ADC_rough ****
"C:\\ti\\ccs1020\\ccs\\utils\\bin\\gmake" -k all
subdir_rules.mk:9: recipe for target 'DSP2833x_ADC_cal.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-1.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-1.bat, ...) failed.
gmake: *** [DSP2833x_ADC_cal.obj] Error 2
subdir_rules.mk:16: recipe for target 'DSP2833x_CodeStartBranch.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-2.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-2.bat, ...) failed.
gmake: *** [DSP2833x_CodeStartBranch.obj] Error 2
subdir_rules.mk:23: recipe for target 'DSP2833x_CpuTimers.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-3.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-3.bat, ...) failed.
gmake: *** [DSP2833x_CpuTimers.obj] Error 2
subdir_rules.mk:30: recipe for target 'DSP2833x_DMA.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-4.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-4.bat, ...) failed.
gmake: *** [DSP2833x_DMA.obj] Error 2
subdir_rules.mk:37: recipe for target 'DSP2833x_DefaultIsr.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-5.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-5.bat, ...) failed.
gmake: *** [DSP2833x_DefaultIsr.obj] Error 2
subdir_rules.mk:44: recipe for target 'DSP2833x_GlobalVariableDefs.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-6.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-6.bat, ...) failed.
gmake: *** [DSP2833x_GlobalVariableDefs.obj] Error 2
subdir_rules.mk:51: recipe for target 'DSP2833x_MemCopy.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-7.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-7.bat, ...) failed.
gmake: *** [DSP2833x_MemCopy.obj] Error 2
subdir_rules.mk:58: recipe for target 'DSP2833x_PieCtrl.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-8.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-8.bat, ...) failed.
gmake: *** [DSP2833x_PieCtrl.obj] Error 2
subdir_rules.mk:65: recipe for target 'DSP2833x_PieVect.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-9.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-9.bat, ...) failed.
gmake: *** [DSP2833x_PieVect.obj] Error 2
subdir_rules.mk:72: recipe for target 'DSP2833x_SysCtrl.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-a.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-a.bat, ...) failed.
gmake: *** [DSP2833x_SysCtrl.obj] Error 2
subdir_rules.mk:79: recipe for target 'DSP2833x_usDelay.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-b.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-b.bat, ...) failed.
gmake: *** [DSP2833x_usDelay.obj] Error 2
subdir_rules.mk:86: recipe for target 'MW_c28xGPIO.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-c.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-c.bat, ...) failed.
gmake: *** [MW_c28xGPIO.obj] Error 2
subdir_rules.mk:93: recipe for target 'MW_c28xGlobalInterrupts.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-d.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-d.bat, ...) failed.
gmake: *** [MW_c28xGlobalInterrupts.obj] Error 2
subdir_rules.mk:100: recipe for target 'MW_c28xx_board.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-e.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-e.bat, ...) failed.
gmake: *** [MW_c28xx_board.obj] Error 2
subdir_rules.mk:107: recipe for target 'MW_c28xx_csl.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-f.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-f.bat, ...) failed.
gmake: *** [MW_c28xx_csl.obj] Error 2
subdir_rules.mk:114: recipe for target 'MW_c28xx_pwm.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-10.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-10.bat, ...) failed.
gmake: *** [MW_c28xx_pwm.obj] Error 2
subdir_rules.mk:121: recipe for target 'PWM_ADC_rough.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-11.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-11.bat, ...) failed.
gmake: *** [PWM_ADC_rough.obj] Error 2
subdir_rules.mk:128: recipe for target 'c2833xBoard_Realtime_Support.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-12.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-12.bat, ...) failed.
gmake: *** [c2833xBoard_Realtime_Support.obj] Error 2
subdir_rules.mk:135: recipe for target 'c2833xSchedulerTimer0.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-13.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-13.bat, ...) failed.
gmake: *** [c2833xSchedulerTimer0.obj] Error 2
subdir_rules.mk:142: recipe for target 'ert_main.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-14.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-14.bat, ...) failed.
gmake: *** [ert_main.obj] Error 2
subdir_rules.mk:149: recipe for target 'profiler_Support.obj' failed
process_begin: CreateProcess(C:\Users\ARSALAN\AppData\Local\Temp\make23284-15.bat, C:\Users\ARSALAN\AppData\Local\Temp\make23284-15.bat, ...) failed.
gmake: *** [profiler_Support.obj] Error 2
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
