// FILE: device.h
// TITLE: Device setup for examples.
// $Release Date: $
// $Copyright:
// Copyright (C) 2013-2022 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#if (!defined(CPU1) && !defined(CPU2))
#error "You must define CPU1 or CPU2 in your project properties. Otherwise, \
the offsets in your header files will be inaccurate."
#endif
#if (defined(CPU1) && defined(CPU2))
#error "You have defined both CPU1 and CPU2 in your project properties. Only \
a single CPU should be defined."
#endif
// Defines for pin numbers and other GPIO configuration
// LEDs
#ifdef _LAUNCHXL_F28379D
#define DEVICE_GPIO_PIN_LED1 31U // GPIO number for LD10
#define DEVICE_GPIO_PIN_LED2 34U // GPIO number for LD9
#define DEVICE_GPIO_CFG_LED1 GPIO_31_GPIO31 // "pinConfig" for LD10
#define DEVICE_GPIO_CFG_LED2 GPIO_34_GPIO34 // "pinConfig" for LD9
#else
#define DEVICE_GPIO_PIN_LED1 31U // GPIO number for LD2
#define DEVICE_GPIO_PIN_LED2 34U // GPIO number for LD3
#define DEVICE_GPIO_CFG_LED1 GPIO_31_GPIO31 // "pinConfig" for LD2
#define DEVICE_GPIO_CFG_LED2 GPIO_34_GPIO34 // "pinConfig" for LD3
#endif
// SCI for USB-to-UART adapter on FTDI chip
#define DEVICE_GPIO_PIN_SCIRXDA 19U // GPIO number for SCI RX
#define DEVICE_GPIO_PIN_SCITXDA 18U // GPIO number for SCI TX
#define DEVICE_GPIO_CFG_SCIRXDA GPIO_19_SCIRXDB // "pinConfig" for SCI RX
#define DEVICE_GPIO_CFG_SCITXDA GPIO_18_SCITXDB // "pinConfig" for SCI TX
#else
#define DEVICE_GPIO_PIN_SCIRXDA 139U // GPIO number for SCI RX
#define DEVICE_GPIO_PIN_SCITXDA 56U // GPIO number for SCI TX
#define DEVICE_GPIO_CFG_SCIRXDA GPIO_139_SCIRXDC // "pinConfig" for SCI RX
#define DEVICE_GPIO_CFG_SCITXDA GPIO_56_SCITXDC // "pinConfig" for SCI TX
#endif
// GPIO assignment for CAN-A and CAN-B
#define DEVICE_GPIO_CFG_CANRXA GPIO_36_CANRXA // "pinConfig" for CANA RX
#define DEVICE_GPIO_CFG_CANTXA GPIO_37_CANTXA // "pinConfig" for CANA TX
#define DEVICE_GPIO_CFG_CANRXB GPIO_17_CANRXB // "pinConfig" for CANB RX
#define DEVICE_GPIO_CFG_CANTXB GPIO_12_CANTXB // "pinConfig" for CANB TX
#else
#define DEVICE_GPIO_CFG_CANRXA GPIO_30_CANRXA // "pinConfig" for CANA RX
#define DEVICE_GPIO_CFG_CANTXA GPIO_31_CANTXA // "pinConfig" for CANA TX
#define DEVICE_GPIO_CFG_CANRXB GPIO_10_CANRXB // "pinConfig" for CANB RX
#define DEVICE_GPIO_CFG_CANTXB GPIO_8_CANTXB // "pinConfig" for CANB TX
//I2CA GPIO pins
#define DEVICE_GPIO_PIN_SDAA 104
#define DEVICE_GPIO_PIN_SCLA 105
#define DEVICE_GPIO_CFG_SDAA GPIO_104_SDAA
#define DEVICE_GPIO_CFG_SCLA GPIO_105_SCLA
//I2CB GPIO pins
#define DEVICE_GPIO_PIN_SDAB 40
#define DEVICE_GPIO_PIN_SCLB 41
#define DEVICE_GPIO_CFG_SDAB GPIO_40_SDAB
#define DEVICE_GPIO_CFG_SCLB GPIO_41_SCLB
#endif
// Defines related to clock configuration
// Launchpad Configuration
// 10MHz XTAL on LaunchPad. For use with SysCtl_getClock().
#define DEVICE_OSCSRC_FREQ 10000000U
// Define to pass to SysCtl_setClock(). Will configure the clock as follows:
// PLLSYSCLK = 10MHz (XTAL_OSC) * 40 (IMULT) * 1 (FMULT) / 2 (PLLCLK_BY_2)
#define DEVICE_SETCLOCK_CFG (SYSCTL_OSCSRC_XTAL | SYSCTL_IMULT(40) | \
SYSCTL_FMULT_NONE | SYSCTL_SYSDIV(2) | \
SYSCTL_PLL_ENABLE)
// 200MHz SYSCLK frequency based on the above DEVICE_SETCLOCK_CFG. Update the
// code below if a different clock configuration is used!
#define DEVICE_SYSCLK_FREQ ((DEVICE_OSCSRC_FREQ * 40 * 1) / 2)
// ControlCARD Configuration
#else
// 20MHz XTAL on controlCARD. For use with SysCtl_getClock().
#define DEVICE_OSCSRC_FREQ 20000000U
// PLLSYSCLK = 20MHz (XTAL_OSC) * 20 (IMULT) * 1 (FMULT) / 2 (PLLCLK_BY_2)
#define DEVICE_SETCLOCK_CFG (SYSCTL_OSCSRC_XTAL | SYSCTL_IMULT(20) | \
SYSCTL_PLL_ENABLE)
#define DEVICE_SYSCLK_FREQ ((DEVICE_OSCSRC_FREQ * 20 * 1) / 2)
#endif
// 50MHz LSPCLK frequency based on the above DEVICE_SYSCLK_FREQ and a default
// low speed peripheral clock divider of 4. Update the code below if a
// different LSPCLK divider is used!
#define DEVICE_LSPCLK_FREQ (DEVICE_SYSCLK_FREQ / 4)
// Macro to call SysCtl_delay() to achieve a delay in microseconds. The macro
// will convert the desired delay in microseconds to the count value expected
// by the function. \b x is the number of microseconds to delay.
#define DEVICE_DELAY_US(x) SysCtl_delay(((((long double)(x)) / (1000000.0L / \
(long double)DEVICE_SYSCLK_FREQ)) - 9.0L) / 5.0L)
// The macros that can be used as parameter to the function Device_bootCPU2
#define C1C2_BROM_BOOTMODE_BOOT_FROM_PARALLEL 0x00000000U
#define C1C2_BROM_BOOTMODE_BOOT_FROM_SCI 0x00000001U
#define C1C2_BROM_BOOTMODE_BOOT_FROM_SPI 0x00000004U
#define C1C2_BROM_BOOTMODE_BOOT_FROM_I2C 0x00000005U
#define C1C2_BROM_BOOTMODE_BOOT_FROM_CAN 0x00000007U
#define C1C2_BROM_BOOTMODE_BOOT_FROM_RAM 0x0000000AU
#define C1C2_BROM_BOOTMODE_BOOT_FROM_FLASH 0x0000000BU
// Other macros that are needed for the Device_bootCPU2 function
#define BROM_IPC_EXECUTE_BOOTMODE_CMD 0x00000013U
#define C1C2_BROM_BOOTMODE_BOOT_COMMAND_MAX_SUPPORT_VALUE 0x0000000CU
#define C2_BOOTROM_BOOTSTS_C2TOC1_IGNORE 0x00000000U
#define C2_BOOTROM_BOOTSTS_SYSTEM_START_BOOT 0x00000001U
#define C2_BOOTROM_BOOTSTS_SYSTEM_READY 0x00000002U
#define C2_BOOTROM_BOOTSTS_C2TOC1_BOOT_CMD_ACK 0x00000003U
#define C2_BOOTROM_BOOTSTS_C2TOC1_BOOT_CMD_NAK_STATUS_NOT_SUPPORTED 0x00000004U
#define C2_BOOTROM_BOOTSTS_C2TOC1_BOOT_CMD_NAK_STATUS_BUSY_WITH_BOOT 0x00000005U
// Macros used as return value by the Device_bootCPU2 function
#define STATUS_FAIL 0x0001
#define STATUS_PASS 0x0000
// Defines, Globals, and Header Includes related to Flash Support
#ifdef _FLASH
#include <stddef.h>
extern uint16_t RamfuncsLoadStart;
extern uint16_t RamfuncsLoadEnd;
extern uint16_t RamfuncsLoadSize;
extern uint16_t RamfuncsRunStart;
extern uint16_t RamfuncsRunEnd;
extern uint16_t RamfuncsRunSize;
#define DEVICE_FLASH_WAITSTATES 3
#endif
extern uint32_t Example_PassCount;
extern uint32_t Example_Fail;
// Function Prototypes
//! \addtogroup device_api
//! @brief Function to initialize the device. Primarily initializes system control to a
//! known state by disabling the watchdog, setting up the SYSCLKOUT frequency,
//! and enabling the clocks to the peripherals.
//! \param None.
//! \return None.
extern void Device_init(void);
//! @brief Function to turn on all peripherals, enabling reads and writes to the
//! peripherals' registers.
//! Note that to reduce power, unused peripherals should be disabled.
//! @param None
//! @return None
extern void Device_enableAllPeripherals(void);
//! @brief Function to disable pin locks on GPIOs.
//! @param None
//! @return None
extern void Device_initGPIO(void);
//! @brief Function to enable pullups for the unbonded GPIOs on the 176PTP package:
//! GPIOs Grp Bits
//! 95-132 C 31
//! D 31:0
//! E 4:0
//! 134-168 E 31:6
//! F 8:0
//! @param None
//! @return None
extern void Device_enableUnbondedGPIOPullupsFor176Pin(void);
//! @brief Function to enable pullups for the unbonded GPIOs on the 100PZ package:
//! GPIOs Grp Bits
//! 0-1 A 1:0
//! 5-9 A 9:5
//! 22-40 A 31:22
//! B 8:0
//! 44-57 B 25:12
//! 67-68 C 4:3
//! 74-77 C 13:10
//! 79-83 C 19:15
//! 93-168 C 31:29
//! D 31:0
//! E 31:0
//! F 8:0
//! @param None
//! @return None
extern void Device_enableUnbondedGPIOPullupsFor100Pin(void);
//! 176PTP package.
//! @param None
//! @return None
extern void Device_enableUnbondedGPIOPullups(void);
#ifdef CPU1
//! @brief Function to implement Analog trim of TMX devices
//! @param None
//! @return None
extern void Device_configureTMXAnalogTrim(void);
//! @brief Executes a CPU02 control system bootloader.
//! \param bootMode specifies which CPU02 control system boot mode to execute.
//! This function will allow the CPU01 master system to boot the CPU02 control
//! system via the following modes: Boot to RAM, Boot to Flash, Boot via SPI,
//! SCI, I2C, or parallel I/O. This function blocks and waits until the
//! control system boot ROM is configured and ready to receive CPU01 to CPU02
//! IPC INT0 interrupts. It then blocks and waits until IPC INT0 and
//! IPC FLAG31 are available in the CPU02 boot ROM prior to sending the
//! command to execute the selected bootloader.
//! The \e bootMode parameter accepts one of the following values:
//! - \b C1C2_BROM_BOOTMODE_BOOT_FROM_PARALLEL
//! - \b C1C2_BROM_BOOTMODE_BOOT_FROM_SCI
//! - \b C1C2_BROM_BOOTMODE_BOOT_FROM_SPI
//! - \b C1C2_BROM_BOOTMODE_BOOT_FROM_I2C
//! - \b C1C2_BROM_BOOTMODE_BOOT_FROM_CAN
//! - \b C1C2_BROM_BOOTMODE_BOOT_FROM_RAM
//! - \b C1C2_BROM_BOOTMODE_BOOT_FROM_FLASH
//! \return 0 (success) if command is sent, or 1 (failure) if boot mode is
//! invalid and command was not sent.
extern uint16_t Device_bootCPU2(uint32_t ulBootMode);
#endif
//! @brief Error handling function to be called when an ASSERT is violated
//! @param *filename File name in which the error has occurred
//! @param line Line number within the file
//! @return None
extern void __error__(const char *filename, uint32_t line);
extern void Example_setResultPass(void);
extern void Example_setResultFail(void);
extern void Example_done(void);
// End of file
// FILE: sci_ex3_echoback.c
// TITLE: SCI echoback example.
//! \addtogroup driver_example_list
//! <h1>SCI Echoback</h1>
//! This test receives and echo-backs data through the SCI-A port.
//! A terminal such as 'putty' can be used to view the data from
//! the SCI and to send information to the SCI. Characters received
//! by the SCI port are sent back to the host.
//! \b Running \b the \b Application
//! Open a COM port with the following settings using a terminal:
//! - Find correct COM port
//! - Bits per second = 9600
//! - Data Bits = 8
//! - Parity = None
//! - Stop Bits = 1
//! - Hardware Control = None
//! The program will print out a greeting and then ask you to
//! enter a character which it will echo back to the terminal.
//! \b Watch \b Variables \n
//! - loopCounter - the number of characters sent
//! \b External \b Connections \n
//! Connect the SCI-A port to a PC via a USB cable.
//! Refer to the hardware user guide for the UART/USB connector information.
// $Release Date: $
// $Copyright:
// are met:
// distribution.
// Included Files
#include "device.h"
// Defines
// Define AUTOBAUD to use the autobaud lock feature
//#define AUTOBAUD
// Globals
uint16_t loopCounter = 0;
// Main
uint16_t receivedChar;
unsigned char *msg;
uint16_t rxStatus = 0U;
void main(void)
// Configure PLL, disable WD, enable peripheral clocks.
Device_init();
// Disable pin locks and enable internal pullups.
Device_initGPIO();
// Configuration for the SCI Rx pin.
GPIO_setMasterCore(DEVICE_GPIO_PIN_SCIRXDA, GPIO_CORE_CPU1);
GPIO_setPinConfig(DEVICE_GPIO_CFG_SCIRXDA);
GPIO_setDirectionMode(DEVICE_GPIO_PIN_SCIRXDA, GPIO_DIR_MODE_IN);
GPIO_setPadConfig(DEVICE_GPIO_PIN_SCIRXDA, GPIO_PIN_TYPE_STD);
GPIO_setQualificationMode(DEVICE_GPIO_PIN_SCIRXDA, GPIO_QUAL_ASYNC);
// Configuration for the SCI Tx pin.
GPIO_setMasterCore(DEVICE_GPIO_PIN_SCITXDA, GPIO_CORE_CPU1);
GPIO_setPinConfig(DEVICE_GPIO_CFG_SCITXDA);
GPIO_setDirectionMode(DEVICE_GPIO_PIN_SCITXDA, GPIO_DIR_MODE_OUT);
GPIO_setPadConfig(DEVICE_GPIO_PIN_SCITXDA, GPIO_PIN_TYPE_STD);
GPIO_setQualificationMode(DEVICE_GPIO_PIN_SCITXDA, GPIO_QUAL_ASYNC);
// Initialize interrupt controller and vector table.
Interrupt_initModule();
Interrupt_initVectorTable();
// Initialize SCIB and its FIFO.
SCI_performSoftwareReset(SCIB_BASE);
// Configure SCIB for echoback.
SCI_setConfig(SCIB_BASE, DEVICE_LSPCLK_FREQ, 9600, (SCI_CONFIG_WLEN_8 |
SCI_CONFIG_STOP_ONE |
SCI_CONFIG_PAR_NONE));
SCI_resetChannels(SCIB_BASE);
SCI_resetRxFIFO(SCIB_BASE);
SCI_resetTxFIFO(SCIB_BASE);
SCI_clearInterruptStatus(SCIB_BASE, SCI_INT_TXFF | SCI_INT_RXFF);
SCI_enableFIFO(SCIB_BASE);
SCI_enableModule(SCIB_BASE);
#ifdef AUTOBAUD
// Perform an autobaud lock.
// SCI expects an 'a' or 'A' to lock the baud rate.
SCI_lockAutobaud(SCIB_BASE);
#endif
// Send starting message.
msg = "\r\n\n\nHello World!\0";
SCI_writeCharArray(SCIB_BASE, (uint16_t*)msg, 17);
msg = "\r\nYou will enter a character, and the DSP will echo it back!\n\0";
SCI_writeCharArray(SCIB_BASE, (uint16_t*)msg, 62);
for(;;)
msg = "\r\nEnter a character: \0";
SCI_writeCharArray(SCIB_BASE, (uint16_t*)msg, 22);
// Read a character from the FIFO.
receivedChar = SCI_readCharBlockingFIFO(SCIB_BASE);
rxStatus = SCI_getRxStatus(SCIB_BASE);
if((rxStatus & SCI_RXSTATUS_ERROR) != 0)
//If Execution stops here there is some error
//Analyze SCI_getRxStatus() API return value
ESTOP0;
// Echo back the character.
msg = " You sent: \0";
SCI_writeCharArray(SCIB_BASE, (uint16_t*)msg, 13);
SCI_writeCharBlockingFIFO(SCIB_BASE, receivedChar);
// Increment the loop count variable.
loopCounter++;
// End of File
