Part Number: TMS320F280049C
i in the development of the SDFM and I'm a bit stuck.
I generate PWM signal of 5 MHz for the filter module, and SOCA of PWM7 in 16 KHz for the interrupt.
I get data, but the scale is wrong. I am working on OSR of 64 and from my calculation the exchange value needed to be 6E-6. In practice the value is around 25E-5
The data readings look very linear. i.e. after translation, the value that I get from the SDFM are very close to my current supplier.
did i do something wrong or miss something?
i have attached my code below:
// FILE: sdfm_ex4_pwm_sync_cpuread.c
// TITLE: SDFM PWM Sync Example
//! \addtogroup driver_example_list
//! <h1> SDFM PWM Sync </h1>
//! In this example, SDFM filter data is read by CPU in SDFM ISR routine. The
//! SDFM configuration is shown below:
//! - SDFM1 is used in this example.
//! - MODE0 Input control mode selected
//! - Comparator settings
//! - Sinc3 filter selected
//! - OSR = 32
//! - hlt = 0x7FFF (Higher threshold setting)
//! - llt = 0x0000(Lower threshold setting)
//! - Data filter settings
//! - All the 4 filter modules enabled
//! - OSR = 256
//! - All the 4 filters are synchronized by using PWM
//! (Master Filter enable bit)
//! - Filter output represented in 16 bit format
//! - In order to convert 25 bit Data filter
//! into 16 bit format user needs to right shift by 10 bits for
//! Sinc3 filter with OSR = 256
//! - Interrupt module settings for SDFM filter
//! - All the 4 higher threshold comparator interrupts disabled
//! - All the 4 lower threshold comparator interrupts disabled
//! - All the 4 modulator failure interrupts disabled
//! - All the 4 filter will generate interrupt when a new filter data
//! is available
//! \b External \b Connections \n
//! Connect Sigma-Delta streams to (SD-D1, SD-C1 to SD-D4,SD-C4)
//! on GPIO24-GPIO31
//! \b Watch \b Variables \n
//! - \b filter1Result - Output of filter 1
//! - \b filter2Result - Output of filter 2
//! - \b filter3Result - Output of filter 3
//! - \b filter4Result - Output of filter 4
// $Copyright:
// Copyright (C) 2022 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
#include <stdio.h>
// Defines
#define MAX_SAMPLES 256
#define EPWM_TIMER_TBPRD 10 // ePWM Period register
// Globals
uint32_t sdfmInstance;
uint32_t pwmInstance = EPWM8_BASE; // ePWM 8 for synchronizing SDFM1 filters
//int16_t filter1Result[MAX_SAMPLES];
int16_t filter2Result[MAX_SAMPLES];
int16_t filter3Result[MAX_SAMPLES];
//int16_t filter4Result[MAX_SAMPLES];
float32_t TrueResult[MAX_SAMPLES];
float32_t AvgData = 0;
float32_t TrancFactor = 0.000242;
#pragma DATA_SECTION(filter2Result, "Filter2_RegsFile");
#pragma DATA_SECTION(filter3Result, "Filter3_RegsFile");
// Function Prototypes
void configureSDFM_CLK_Pins(void);
void configureSDFMPins(void);
void initEPWM(uint32_t epwmInstance);
__interrupt void sdfm1ErrorISR(void);
__interrupt void sdfmDR1ISR(void);
void AnalizeData();
void CalcAvg();
// Main
void main(void)
uint16_t hlt, llt;
// Initialize device clock and peripherals
Device_init();
// Setup GPIO by disabling pin locks and enabling pullups
Device_initGPIO();
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
Interrupt_initModule();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP3);
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP5);
Interrupt_register(INT_SDFM1DR2, sdfmDR1ISR);
Interrupt_register(INT_SDFM1, sdfm1ErrorISR);
// Enable SDFM1 Error and DR interrupts
Interrupt_enable(INT_SDFM1);
Interrupt_enable(INT_SDFM1DR2);
Interrupt_enable(INT_SDFM1DR3);
Interrupt_enable(INT_EPWM8);
// Configure GPIO pins as SDFM pins
configureSDFMPins();
configureSDFM_CLK_Pins();
// Select SDFM1
sdfmInstance = SDFM1_BASE;
// Input Control Module:
// Configure Modulator Clock rate = Modulator data rate
SDFM_setupModulatorClock(sdfmInstance, SDFM_FILTER_2,
SDFM_MODULATOR_CLK_HALF_DATA_RATE);
SDFM_setupModulatorClock(sdfmInstance, SDFM_FILTER_3,
SDFM_MODULATOR_CLK_EQUAL_DATA_RATE);
// Comparator Module
hlt = 0x7FFF; //Over value threshold settings
llt = 0x0000; //Under value threshold settings
// Data filter Module
// Configure Data filter modules filter type, OSR value and
// enable / disable data filter
SDFM_configDataFilter(sdfmInstance, (SDFM_FILTER_2 | SDFM_FILTER_SINC_3 |
SDFM_SET_OSR(64)), (SDFM_DATA_FORMAT_16_BIT | SDFM_FILTER_ENABLE |
SDFM_SHIFT_VALUE(0x0004)));
SDFM_configDataFilter(sdfmInstance, (SDFM_FILTER_3 | SDFM_FILTER_SINC_3 |
// Enable Master filter bit: Unless this bit is set none of the filter modules
// can be enabled. All the filter modules are synchronized when master filter
// bit is enabled after individual filter modules are enabled.
SDFM_enableMasterFilter(sdfmInstance);
// PWM signals can synchronize SDFM1 filters. Enabling PWM sync for SDFM
// filters.
SDFM_enableExternalReset(sdfmInstance, SDFM_FILTER_2);
SDFM_enableExternalReset(sdfmInstance, SDFM_FILTER_3);
SDFM_setPWMSyncSource(sdfmInstance, SDFM_FILTER_2, SDFM_SYNC_PWM7_SOCA);
SDFM_setPWMSyncSource(sdfmInstance, SDFM_FILTER_3, SDFM_SYNC_PWM8_SOCA);
// Init EPWMs
initEPWM(pwmInstance);
// Enable interrupts
// Following SDFM interrupts can be enabled / disabled using this function.
// Enable / disable comparator high threshold
// Enable / disable comparator low threshold
// Enable / disable modulator clock failure
// Enable / disable filter acknowledge
SDFM_enableInterrupt(sdfmInstance, SDFM_FILTER_2,
( SDFM_DATA_FILTER_ACKNOWLEDGE_INTERRUPT));
SDFM_enableInterrupt(sdfmInstance, SDFM_FILTER_3,
SDFM_disableInterrupt(sdfmInstance, SDFM_FILTER_2,
(SDFM_HIGH_LEVEL_THRESHOLD_INTERRUPT |
SDFM_LOW_LEVEL_THRESHOLD_INTERRUPT));
SDFM_disableInterrupt(sdfmInstance, SDFM_FILTER_3,
while((HWREGH(pwmInstance + EPWM_O_TBCTR)) < EPWM_TIMER_TBPRD);
// Enable master interrupt so that any of the filter interrupts can trigger
// by SDFM interrupt to CPU
SDFM_enableMasterInterrupt(sdfmInstance);
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
while(1)
AnalizeData();
CalcAvg();
// sdfm1ErrorISR - SDFM1 Error ISR
// Clear SDFM flag register (SDIFLG)
SDFM_clearInterruptFlag(SDFM1_BASE, SDFM_MASTER_INTERRUPT_FLAG |
0xFFFF);
// Acknowledge this interrupt to receive more interrupts from group 5
// sdfmDR1ISR - SDFM DR1 ISR
static uint16_t loopCounter1 = 0;
SDFM_setOutputDataFormat(SDFM1_BASE, SDFM_FILTER_2,
SDFM_DATA_FORMAT_16_BIT);
// Read SDFM flag register (SDIFLG)
if(loopCounter1 >= MAX_SAMPLES)
loopCounter1 = 0;
filter2Result[loopCounter1] =
(int16_t)(SDFM_getFilterData(SDFM1_BASE, SDFM_FILTER_2) >> 16U);
filter3Result[loopCounter1++] =
(int16_t)(SDFM_getFilterData(SDFM1_BASE, SDFM_FILTER_3) >> 16U);
SDFM_FILTER_2_NEW_DATA_FLAG |
SDFM_FILTER_3_NEW_DATA_FLAG );
void AnalizeData()
int i = 0;
for (i = 0; i < MAX_SAMPLES; ++i)
TrueResult[i] = ((float32_t)filter2Result[i] * TrancFactor);
void CalcAvg()
int i = 0;
float32_t tmpAvg = 0.0;
tmpAvg += TrueResult[i];
AvgData = tmpAvg / MAX_SAMPLES;
// configureSDFMPins - Configure SDFM GPIOs
uint16_t pin;
for(pin = 24; pin <= 31; pin++)
GPIO_setDirectionMode(pin, GPIO_DIR_MODE_IN);
GPIO_setMasterCore(pin, GPIO_CORE_CPU1);
GPIO_setPadConfig(pin, GPIO_PIN_TYPE_STD);
GPIO_setQualificationMode(pin, GPIO_QUAL_ASYNC);
// Configure GPIO16-GPIO31 as SDFM pins
GPIO_setPinConfig(GPIO_26_SD1_D2);
GPIO_setPinConfig(GPIO_27_SD1_C2);
GPIO_setPinConfig(GPIO_28_SD1_D3);
GPIO_setPinConfig(GPIO_29_SD1_C3);
uint16_t pin = 14;
GPIO_setDirectionMode(pin, GPIO_DIR_MODE_OUT);
GPIO_setQualificationMode(pin, GPIO_QUAL_SYNC);
GPIO_setPinConfig(GPIO_14_EPWM8_A);
// done - Function to halt debugger and stop application
void done(void)
asm(" ESTOP0");
for(;;);
// initEPWM - Initialize specified EPWM settings
// Disable sync(Freeze clock to PWM as well)
SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// Setup TBCLK: Configure timer period = 801 TBCLKs, phase = 0 &
// clear counter
EPWM_setTimeBasePeriod(epwmInstance, EPWM_TIMER_TBPRD);
EPWM_setTimeBasePeriod(EPWM7_BASE, 3125);
EPWM_setPhaseShift(epwmInstance, 0U);
EPWM_setPhaseShift(EPWM7_BASE, 0U);
EPWM_setTimeBaseCounter(epwmInstance, 0U);
EPWM_setTimeBaseCounter(EPWM7_BASE, 0U);
// Set CMPA value
EPWM_setCounterCompareValue(epwmInstance, EPWM_COUNTER_COMPARE_A, 4U);
EPWM_setCounterCompareValue(epwmInstance, EPWM_COUNTER_COMPARE_B, 0U);
// EPWM_setCounterCompareValue(EPWM7_BASE, EPWM_COUNTER_COMPARE_A, 480U);
EPWM_setCounterCompareValue(EPWM7_BASE, EPWM_COUNTER_COMPARE_B, 2645U);
// Setup counter mode
EPWM_setTimeBaseCounterMode(epwmInstance, EPWM_COUNTER_MODE_UP);
EPWM_setClockPrescaler(epwmInstance, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
EPWM_setTimeBaseCounterMode(EPWM7_BASE, EPWM_COUNTER_MODE_UP);
EPWM_setClockPrescaler(EPWM7_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
// Set actions:
// Toggle PWMxA on event A, up-count
// Toggle PWMxB on event A, up-count
EPWM_setActionQualifierAction(EPWM8_BASE,
EPWM_AQ_OUTPUT_A,
EPWM_AQ_OUTPUT_TOGGLE,
EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_AQ_OUTPUT_B,
EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
EPWM_setActionQualifierAction(EPWM7_BASE,
EPWM_AQ_OUTPUT_A,
EPWM_AQ_OUTPUT_B,
EPWM_AQ_OUTPUT_NO_CHANGE,
// Configure SOCA signal
EPWM_setADCTriggerSource(EPWM7_BASE, EPWM_SOC_A, EPWM_SOC_TBCTR_U_CMPA);
EPWM_setADCTriggerEventPrescale(EPWM7_BASE, EPWM_SOC_A, 1);
// Enable sync and clock to PWM
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// End of file
Ofri
