I am looking at TIDM-02009 from the Digital Power SDK for reference code for working with a resolver. Is there documentation or otherwise some guidance on what these parameters are and if and how some of the resolver parameters can be adjusted for a given application?
Thanks!
From trinv_settings.h:
#define RESOLVER_BIAS 2.40f // Bias between Resolver zero and Id
#define RESOLVER_OMEGA (200.0f * 2.0f * PI)
#define RESOLVER_ZETA 0.7f
#define RESOLVER_PHASE_COMP_GAIN - 4.6585E-5f
#define RESOLVER_LPF_SPD_BW 100.0
from trinv.c:
resolver_init(&resolver1);
resolver1.resolver_theta = &resolver_theta;
resolver1.resolver_omega = &resolver_omega;
resolver1.sample_time = 1.0f / (RESOLVER_EXC_FREQUENCY * 1000.0f);
resolver1.pll_gain_in = RESOLVER_OMEGA * RESOLVER_OMEGA;
resolver1.pll_gain_ff = 2.0f * RESOLVER_ZETA / RESOLVER_OMEGA;
resolver1.bias = RESOLVER_BIAS;
resolver1.phase_comp_gain = RESOLVER_PHASE_COMP_GAIN;
FILTER_FO_init(&resolver1.lpf_spd, RESOLVER_LPF_SPD_BW,
(RESOLVER_EXC_FREQUENCY * 1000.0f));
Hi Mark,
The RESOLVER_OMEGA and RESOLVER_ZETA are the bandwidth and damping ratio of the resolver position tracking PLL loop. RESOLVER_BIAS is the angle difference between your electric zero position and the resolver zero position. RESOLVER_PHASE_COMP_GAIN is the gain used to compensate for time difference between your resolver position output and your FOC feedback sampling. RESOLVER_LPF_SPD_BW is the bandwidth of the LPF for speed output.
Please let me know if you have further questions. Thanks.
Han
Thank you, Han.
Do you have any detail on how the values were chosen for these parameters in TIDM-02009?
Mark,
The parameters are chosen primarily from targeted electric speed of the motor and electrical characteristics of the signal chain on your control board.
Han
