Hi there,
I am executing some code from flash in my own design utilizing f280023 and the code was executing totally fine up until today.
I had been debugging some SPI issue and made some minor code changes and suddenly I am getting this ""Break at address "0x3f8165" message during debug.
1. I tried to undo my code changes but I am still getting the "Break at address "0x3f8165" with no debug information available, or outside of program code. " message.
2. To check it is not damaged hardware I tried it on another board and I am still getting the above message, hardware should not be damaged.
3. I reverted to a MUCH older version of my code and the code executes okay, again confirming that the hardware should not be damaged.
What is weird is that I cannot seem to figure out what is causing this issue in my recent code, I have tried to delete some lines I recently added, and commented out large sections of code but this makes no difference.
I seem to think it may be interrupt related as this issue does not occur without enabling interrupts as per:
//enable interrupts
EINT;
ERTM;
When I click on "view dissasembly" I get the following info for instruction line "0x3f8165" not sure how to figure out what this line of code is doing:
Any ideas what the cause is and what I can try to fix this issue? Much thanks in advance for your help,
