Part Number: C2000WARE-DIGITALPOWER-SDK
Other Parts Discussed in Thread: C2000WARE, SYSCONFIG
Hi Team,
Can you help below?
The Solution Adapter Tool is mainly framed to the power topologies given by different TIDA's where is possible to change some power stage settings and the target DSP. Is it possible just to use some sort of "main.c" generic template that calls some code blocks already included in C2000Ware libraries like ABC_DQ0, SPLL, etc., in order to adapt/repurpose the solutions given by the TIDA's similar to ALTAIR's Embed.
It could be easy to adapt that to some PIL block (which generally contains the *.out file) at PSIM and simulate the circuit. Certainly use the TI codes directly inside PSIM.
Does the Solution Adapter IDE Tool is able to do this sort of solution (adding blocks and connecting them accordingly) or there is another kind of tool available?
Looking forward to your response.
Marvin
