Part Number: TMDSDOCKH52C1
Hello Team,
Posting on behalf of my customer:
I am looking to obtain a step file for the part TMDSDOCKH52C1.
I am designing a mounting scheme and need a CAD model of the microcontroller and its geometry to properly design housing, but I could not find a CAD model for TMDSDOCKH52C1 on the TI site. A simple STP file will do.
I actually do have two other questions regarding the board.
I have been looking but have been unable to find this microcontroller in another configuration. Are you aware of a different configuration of the same board, but designed for horizontal mounting instead of in a vertical daughter card set-up?
And then the second question follows up on that, in the current TMDSDOCKH52C1 configuration, or in the hypothetical horizontal mounting configuration, is there a list of connectors/adapters for this board?
To give you some background, we are designing with this card because it worked before in a mounted vertical daughter card configuration. But we need it to be no longer a vertical daughter card but instead, a horizontal separate card connected via a cable assembly. Hence needing the step model, and connectors and potentially find a more suitable configuration if it exits.
Renan
