TMS320F28386D: TMS320F28386D
Expert 2480 points
Part Number: TMS320F28386D
Other Parts Discussed in Thread: C2000WARE, , C2000-SAFETI-DIAGNOSTICS-LIB
C2000Ware_1_00_01_00\libraries\diagnostic\compliance_support_package\software_safety_requirements_specification
SPRACC2.PDF, document below.
We are using TMS320F28386D, also want to refer the IPC Safety Mechanisms as below, but in the new C2000Ware_4_00_00_00 package, I cannot find the corresponding exmaple.
I want to know where I can get the example of IPC Safety Mechanisms for TMS320F28386D
  • We did not provide an IPC test as part of the F2838x SDL because it's a simple functional test as described by the F2838x safety manual that you should be able to implement as part of your own IPC code. However, if you're familiar with the F2837xD version of the code from C2000-SAFETI-DIAGNOSTICS-LIB and want to use that, I expect it should port to F2838x fairly easily.
    Whitney
