Part Number: TMS320F280039C-Q1
Dear team,
please can you provide a solution, how its possible to enable the time base phase shift? At the moment it was just succeed to enable the period and comparators.
Thanks Jens
Dear team,
Thanks Jens
Hi Jens,
Global load is not necessary to utilize the time base phase shift feature. You should only need to enable phase shift load, select your phase shift value, and select the sync in pulse source for each EPWM module. When the sync in source goes high, TBCTR will be loaded with the value of your phase shift value for that EPWM module. Let me know if this works for you, or if you have any other questions.
--Luke
