Part Number: TMS320F28335
Other Parts Discussed in Thread: C2000WARE, CONTROLSUITE
Hi Team,
The customer uses the attached program, and the development board debugging can read the AD value normally, but the AD value of the board we set is always 0.
ADC program:
void DriverDspAdcInit(void)
EALLOW;
SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1; //使能ADC的时钟
ADC_cal(); //调用ADC_cal汇编语言,它是TI官方提供的。
EDIS;
AdcRegs.ADCREFSEL.bit.REF_SEL = 0x0; // 选择内部参考电压
AdcRegs.ADCTRL3.all = 0x00E0; // Power up bandgap/reference/ADC circuits
DELAY_US(50000L); // Delay before converting ADC channels
// AdcRegs.ADCTRL3.bit.SMODE_SEL=0;//
AdcRegs.ADCTRL3.bit.SMODE_SEL=1;// 1 同步采样模式
AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // 0x0 Dual Sequencer Mode, 0x1 Cascaded Mode
AdcRegs.ADCTRL3.bit.ADCCLKPS = 0x04; // Fclk = HSPCLK/2 = 37.5MHz
AdcRegs.ADCTRL1.bit.CPS = 1; // ADCCLK = Fclk/2 = 18.75MHz
AdcRegs.ADCTRL1.bit.CONT_RUN=0;//0 非连续
AdcRegs.ADCTRL1.bit.ACQ_PS = 0x01; // 设置启动脉冲的宽度
AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 0x0; // 使能INT_SEQ1中断
AdcRegs.ADCTRL2.bit.RST_SEQ1 = 0x1; // Reset SEQ/SEQ1
AdcRegs.ADCTRL2.bit.RST_SEQ2 = 0x1; // Reset SEQ/SEQ2
AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1=0x1; // 允许SEQ/SEQ1被EPWMA_SOCA信号触发启动
// AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 6; // Dummy meas. avoid 1st sample issue Rev0 Picollo*/
// AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 1; // A1-> Phase A Current
// AdcRegs.ADCCHSELSEQ1.bit.CONV02 = 2; // B1-> Phase B Current
// AdcRegs.ADCCHSELSEQ1.bit.CONV03 = 3; // A3-> Phase C Current
// AdcRegs.ADCCHSELSEQ2.bit.CONV04 = 4; // B7-> Phase A Voltage TEMP
// AdcRegs.ADCCHSELSEQ2.bit.CONV05 = 5; // B6-> Phase B Voltage TEMP MOTOR
// AdcRegs.ADCCHSELSEQ2.bit.CONV06 = 12; // B4-> Phase C Voltage
// AdcRegs.ADCCHSELSEQ2.bit.CONV07 = 6; // A7-> DC Bus Voltage
AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0; // Dummy meas. avoid 1st sample issue Rev0 Picollo*/
AdcRegs.ADCCHSELSEQ2.bit.CONV06 = 6; // B4-> Phase C Voltage
AdcRegs.ADCCHSELSEQ2.bit.CONV07 = 7;
AdcRegs.ADCMAXCONV.bit.MAX_CONV1 = 7;
EDIS;
/* Set up Event Trigger with CNT_zero enable for Time-base of EPWM1 */
EPwm1Regs.ETSEL.bit.SOCAEN = 1; // 使能ADC启动脉冲ePWMxSOCA
EPwm1Regs.ETSEL.bit.SOCASEL = ET_CTR_PRD; // TBCTR = PEROID 时产生SOCA中断,因为IR2136反向的。
EPwm1Regs.ETPS.bit.SOCAPRD = ET_1ST; // 每发生一次事件,产生信号EPWM1SOCA
EPwm1Regs.ETCLR.bit.SOCA = 1; // Clear SOCA flag */
Hardware design: 5KW_Invertion.pdf
Could you help check this case?
Thanks & Regards,
Ben
, we tested development board using same routine and it and get results.
