TMS320F28054M: TMS320F28054M
Part Number: TMS320F28054M
Other Parts Discussed in Thread: UNIFLASH, MOTORWARE
I have developed a motor controller using TMS320F28054M instaspin enabled dsp. I can program it via a XDS100v2 debugger. Th motor controller can be programmed from CCS studio, but when I try uniflash, following warning occurs:
 [WARNING] C28xx: Loader: One or more sections of your program falls into a memory region that is not writable. These regions will not actually be written to the target. Check your linker configuration and/or memory map.
[3/18/2023, 4:03:42 PM] [SUCCESS] Program Load completed successfully.
Can somebody please guide as to what might be happening?
  • Hi Milind,
    Generally this happens when the gel file's memory map is not in sync with the memory used in the applications' linker command file.   Hope you are using the latest version of CCS and Uniflash.
    We asked our F28054 expert to review this for you.
    Please expect a reply in a day or two.
    Thanks and regards,
    Vamsi
  • Milind,
    Checking back to see if you have verified that the target selected in Uniflash matches the physical target.
    Matthew
  • Hi Matthew,
    I am using selecting TMS320F28054M specifically from uniflash drop down box to ensure that it is picking up instaspin enabled processor
  • Milind,
    Could you upload the .map file that is generated when you build the project?  This should be located in the same directory as the .out file you are loading.
    Matthew
  • Mathew,
    I am trying to upload file as I can't see upload option link, for last few days, now I have tried drag and drop. Can pl. confirm if file is uploaded?
  • Milind,
    I do not see it.  When you reply if you click the "Insert" drop down you will see an option for Image/Video/File.  This should bring up a dialog box; click the "upload' button to bring up your windows explorer file menu and then pick the file.  A
    Alternatively you can C/P the contents of the map file directly into the reply window and I can read it from there.  Sorry about this problem with the attachment.
    Matthew
  • Some issue while uploading file from my PC, guess, firewall or something. Anyway, please find attached below the map file. Let me know if this is sufficient
                 TMS320C2000 Linker PC v20.2.5
    >> Linked Sun Mar 12 16:23:46 2023
    OUTPUT FILE NAME:   <Pilot_E2PROM_HVDTC230VACR4_230312.out>
    ENTRY POINT SYMBOL: "_c_int00"  address: 003f2bb9
    MEMORY CONFIGURATION
             name            origin    length      used     unused   attr    fill
    PAGE 0:
      RAML1L2               00008800   00000800  000007e8  00000018  RWIX
      DCSM_OTP_Z2_P0        003d7800   00000004  00000000  00000004  RWIX
      DCSM_ZSEL_Z2_P0       003d7810   00000010  00000000  00000010  RWIX
      Z2_DCSM_RSVD          003d7820   000001e0  00000000  000001e0  RWIX
      DCSM_OTP_Z1_P0        003d7a00   00000006  00000000  00000006  RWIX
      DCSM_ZSEL_Z1_P0       003d7a10   00000010  00000000  00000010  RWIX
      Z1_DCSM_RSVD          003d7a20   000001e0  00000000  000001e0  RWIX
      FLASHJ                003e8000   00001000  00000000  00001000  RWIX
      FLASHI                003e9000   00001000  00000000  00001000  RWIX
      FLASHH                003ea000   00002000  00000000  00002000  RWIX
      FLASHG                003ec000   00002000  00000000  00002000  RWIX
      FLASHC_F              003ee000   00008000  00005466  00002b9a  RWIX
      FLASHA                003f7000   00000ffe  000007e8  00000816  RWIX
      BEGIN                 003f7ffe   00000002  00000002  00000000  RWIX
      Z1_SCC_ROM            003f8000   00000400  00000000  00000400  RWIX
      Z2_SCC_ROM            003f8400   00000400  00000000  00000400  RWIX
      Z1_SECURE_ROM         003f8808   000044f8  00000000  000044f8  RWIX
      IQTABLES              003fdb52   00000b50  00000000  00000b50  RWIX
      IQTABLES2             003fe6a2   0000008c  00000000  0000008c  RWIX
      IQTABLES3             003fe72e   000000aa  00000000  000000aa  RWIX
      ROM                   003ff27c   00000d44  00000000  00000d44  RWIX
      RESET                 003fffc0   00000002  00000000  00000002  RWIX
      VECTORS               003fffc2   0000003e  00000000  0000003e  RWIX
    PAGE 1:
      BOOT_RSVD             00000000   00000050  00000000  00000050  RWIX
      RAMM0                 00000050   000003b0  000003b0  00000000  RWIX
      RAMM1                 00000400   00000400  00000000  00000400  RWIX
      RAML3                 00009000   00001000  0000093c  000006c4  RWIX
      FLASHB                003f6000   00001000  00000000  00001000  RWIX
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    .cinit     0    003f3001    00000229
                      003f3001    0000018e     lab5f_1.obj (.cinit)
                      003f318f    00000053     lab5f_1.obj (.cinit:_gqSet)
                      003f31e2    00000013     lab5f_1.obj (.cinit:_gqAdArray)
                      003f31f5    00000013     lab5f_1.obj (.cinit:_gqTempArray)
                      003f3208    0000000e     rts2800_ml.lib : exit.c.obj (.cinit)
                      003f3216    00000008     modbus.obj (.cinit)
                      003f321e    00000005     rts2800_ml.lib : _lock.c.obj (.cinit:__lock)
                      003f3223    00000005                    : _lock.c.obj (.cinit:__unlock)
                      003f3228    00000002     --HOLE-- [fill = 0]
    .pinit     0    003ee000    00000000     UNINITIALIZED
    .text      0    003ee000    00005001
                      003ee000    0000104c     lab5f_1.obj (.text)
                      003ef04c    00000c4e     hal1_2.obj (.text)
                      003efc9a    00000ae8     user1.obj (.text)
                      003f0782    000008c7     modbus.obj (.text)
                      003f1049    0000045b     ctrl.obj (.text)
                      003f14a4    00000452     SpinTAC.lib : spintac_vel_move.obj (.text:_STVELMOVE_run)
                      003f18f6    00000327                 : spintac_vel_id.obj (.text:_STVELID_run)
                      003f1c1d    000002aa     pwm.obj (.text)
                      003f1ec7    00000238     SpinTAC.lib : spintac_vel_ctl.obj (.text:_STVELCTL_run)
                      003f20ff    000001ee     adc.obj (.text)
                      003f22ed    000001c4     Fault_Brake.obj (.text)
                      003f24b1    00000185     clk.obj (.text)
                      003f2636    00000160     i2c.obj (.text)
                      003f2796    0000015c     gpio.obj (.text)
                      003f28f2    00000108     pie5f.obj (.text)
                      003f29fa    000000fb     sci.obj (.text)
                      003f2af5    00000069     rts2800_ml.lib : s_ceilf.c.obj (.text)
                      003f2b5e    0000005b     pll.obj (.text)
                      003f2bb9    00000054     rts2800_ml.lib : boot28.asm.obj (.text)
                      003f2c0d    00000047     offset.obj (.text)
                      003f2c54    00000046     wdog.obj (.text)
                      003f2c9a    00000044     pwr.obj (.text)
                      003f2cde    0000003e     lab5f_1.obj (.text:retain)
                      003f2d1c    00000035     SpinTAC.lib : spintac_pos_conv.obj (.text:_STPOSCONV_init)
                      003f2d51    00000032     timer.obj (.text)
                      003f2d83    00000031     SpinTAC.lib : spintac_version.obj (.text:_ST_initVersion)
                      003f2db4    0000002d     osc.obj (.text)
                      003f2de1    0000002b     SpinTAC.lib : spintac_vel_id.obj (.text:_STVELID_init)
                      003f2e0c    0000002b                 : spintac_vel_move.obj (.text:_STVELMOVE_init)
                      003f2e37    0000002a                 : spintac_vel_ctl.obj (.text:_STVELCTL_init)
                      003f2e61    00000029     rts2800_ml.lib : exit.c.obj (.text)
                      003f2e8a    00000026     SpinTAC.lib : spintac_vel_plan.obj (.text:_STVELPLAN_init)
                      003f2eb0    00000025     cpu.obj (.text)
                      003f2ed5    00000024     rts2800_ml.lib : cpy_tbl.c.obj (.text)
                      003f2ef9    00000021     filter_fo.obj (.text)
                      003f2f1a    00000021     rts2800_ml.lib : fs_toul28.asm.obj (.text)
                      003f2f3b    00000020     flash.obj (.text)
                      003f2f5b    0000001d     rts2800_ml.lib : fs_tou28.asm.obj (.text)
                      003f2f78    0000001d                    : memcpy.c.obj (.text)
                      003f2f95    00000017                    : u_tofd28.asm.obj (.text)
                      003f2fac    00000016                    : ul_tofd28.asm.obj (.text)
                      003f2fc2    00000011                    : args_main.c.obj (.text)
                      003f2fd3    0000000f     memCopy.obj (.text)
                      003f2fe2    00000009     rts2800_ml.lib : _lock.c.obj (.text)
                      003f2feb    00000008     CodeStartBranch.obj (.text)
                      003f2ff3    00000006     afe5f.obj (.text)
                      003f2ff9    00000005     pie5f.obj (.text:retain)
                      003f2ffe    00000002     rts2800_ml.lib : pre_init.c.obj (.text)
                      003f3000    00000001                    : startup.c.obj (.text)
    .switch    0    003f322a    000001e4
                      003f322a    00000112     modbus.obj (.switch:_iReply0304)
                      003f333c    000000d2     modbus.obj (.switch:_iReply16)
    ramfuncs   0    003f7000    000007e8     RUN ADDR = 00008800
                      003f7000    00000539     ctrl.obj (ramfuncs)
                      003f7539    0000025b     lab5f_1.obj (ramfuncs:retain)
                      003f7794    00000032     flash.obj (ramfuncs)
                      003f77c6    0000001e     hal1_2.obj (ramfuncs)
                      003f77e4    00000004     usDelay.obj (ramfuncs)
    codestart
    *          0    003f7ffe    00000002
                      003f7ffe    00000002     CodeStartBranch.obj (codestart)
    .stack     1    00000050    000003b0     UNINITIALIZED
                      00000050    000003b0     --HOLE--
    .ebss      1    00009000    0000093c     UNINITIALIZED
                      00009000    0000049a     lab5f_1.obj (.ebss)
                      0000949a    00000010     lab5f_1.obj (.ebss:_gqAdArray)
                      000094aa    00000010     lab5f_1.obj (.ebss:_gqTempArray)
                      000094ba    00000006     rts2800_ml.lib : exit.c.obj (.ebss)
                      000094c0    0000012c     lab5f_1.obj (.ebss:_giReplyData)
                      000095ec    00000002     rts2800_ml.lib : _lock.c.obj (.ebss:__lock)
                      000095ee    00000002                    : _lock.c.obj (.ebss:__unlock)
                      000095f0    00000002     modbus.obj (.ebss)
                      000095f2    00000001     cpu.obj (.ebss)
                      000095f3    0000000d     --HOLE--
                      00009600    0000012c     lab5f_1.obj (.ebss:_giSerialModData)
                      0000972c    00000014     --HOLE--
                      00009740    000000de     hal1_2.obj (.ebss)
                      0000981e    00000022     --HOLE--
                      00009840    00000050     lab5f_1.obj (.ebss:_gqSet)
                      00009890    00000030     --HOLE--
                      000098c0    0000003c     lab5f_1.obj (.ebss:_Graph_Data2)
                      000098fc    00000004     --HOLE--
                      00009900    0000003c     lab5f_1.obj (.ebss:_Graph_Data)
    .econst    0    003f340e    0000003e
                      003f340e    0000000c     lab5f_1.obj (.econst)
                      003f341a    00000008     modbus.obj (.econst)
                      003f3422    00000008     user1.obj (.econst)
                      003f342a    00000004     ctrl.obj (.econst:_$P$T0$1)
                      003f342e    00000004     ctrl.obj (.econst:_$P$T1$2)
                      003f3432    00000004     ctrl.obj (.econst:_$P$T2$3)
                      003f3436    00000004     ctrl.obj (.econst:_$P$T3$4)
                      003f343a    00000004     ctrl.obj (.econst:_$P$T4$5)
                      003f343e    00000004     ctrl.obj (.econst:_$P$T5$6)
                      003f3442    00000004     ctrl.obj (.econst)
                      003f3446    00000004     hal1_2.obj (.econst)
                      003f344a    00000002     rts2800_ml.lib : s_ceilf.c.obj (.econst)
    IQmath     0    003f344c    0000001a
                      003f344c    00000011     IQmath.lib : IQ30mpyI32int.obj (IQmath)
                      003f345d    00000009                : IQ24int.obj (IQmath)
    .reset     0    003fffc0    00000002     DSECT
                      003fffc0    00000002     rts2800_ml.lib : boot28.asm.obj (.reset)
    vectors    0    003fffc2    00000000     DSECT
    MODULE SUMMARY
           Module                 code    initialized data   uninitialized data
           lab5f_1.obj            5440    531                2010
           ctrl.obj               3789    28                 0
           hal1_2.obj             3210    4                  222
           user1.obj              2792    8                  0
           modbus.obj             2247    500                2
           pwm.obj                682     0                  0
           adc.obj                494     0                  0
           Fault_Brake.obj        452     0                  0
           clk.obj                389     0                  0
           i2c.obj                352     0                  0
           gpio.obj               348     0                  0
           pie5f.obj              269     0                  0
           sci.obj                251     0                  0
           flash.obj              132     0                  0
           pll.obj                91      0                  0
           offset.obj             71      0                  0
           wdog.obj               70      0                  0
           pwr.obj                68      0                  0
           timer.obj              50      0                  0
           osc.obj                45      0                  0
           cpu.obj                37      0                  1
           filter_fo.obj          33      0                  0
           memCopy.obj            15      0                  0
           CodeStartBranch.obj    10      0                  0
           usDelay.obj            8       0                  0
           afe5f.obj              6       0                  0
           Total:                 21351   1071               2235
        C:/ti/ccs1040/ccs/tools/compiler/ti-cgt-c2000_20.2.5.LTS/lib/rts2800_ml.lib
           s_ceilf.c.obj          105     2                  0
           boot28.asm.obj         84      0                  0
           exit.c.obj             41      14                 6
           cpy_tbl.c.obj          36      0                  0
           fs_toul28.asm.obj      33      0                  0
           fs_tou28.asm.obj       29      0                  0
           memcpy.c.obj           29      0                  0
           _lock.c.obj            9       10                 4
           u_tofd28.asm.obj       23      0                  0
           ul_tofd28.asm.obj      22      0                  0
           args_main.c.obj        17      0                  0
           pre_init.c.obj         2       0                  0
           startup.c.obj          1       0                  0
           Total:                 431     26                 10
        C:/ti/motorware/motorware_1_01_00_18/sw/modules/iqmath/lib/f28x/32b/IQmath.lib
           IQ30mpyI32int.obj      0       17                 0
           IQ24int.obj            0       9                  0
           Total:                 0       26                 0
        C:/ti/motorware/motorware_1_01_00_18/sw/modules/spintac/lib/32b/SpinTAC.lib
           spintac_vel_move.obj   1149    0                  0
           spintac_vel_id.obj     850     0                  0
           spintac_vel_ctl.obj    610     0                  0
           spintac_pos_conv.obj   53      0                  0
           spintac_version.obj    49      0                  0
           spintac_vel_plan.obj   38      0                  0
           Total:                 2749    0                  0
           Stack:                 0       0                  944
           Grand Total:           24531   1123               3189
    GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
    address     data page           name
    00000050       1 (00000040)     __stack
    00009000     240 (00009000)     _gCounter_updateGlobals
    00009001     240 (00009000)     _Flag_Latch_softwareUpdate
    00009002     240 (00009000)     _gLEDcnt
    00009003     240 (00009000)     _giI2CDelay
    00009004     240 (00009000)     _giSerialTimer
    00009005     240 (00009000)     _giLocate
    00009006     240 (00009000)     _giPendingQueryFlag
    00009007     240 (00009000)     _giMasterAddress
    00009008     240 (00009000)     _giChecksum
    00009009     240 (00009000)     _giCrc
    0000900a     240 (00009000)     _giReplyArrayIndex
    0000900b     240 (00009000)     _gDriveStatus
    0000900c     240 (00009000)     _gDriveMode
    0000900d     240 (00009000)     _gDriveSerialMode
    0000900e     240 (00009000)     _bActivateLR
    0000900f     240 (00009000)     _gbActivateMode
    00009010     240 (00009000)     _gbStartStopMotorSerial
    00009011     240 (00009000)     _gbStartStopMotorPin
    00009012     240 (00009000)     _gbStartStopMotor
    00009013     240 (00009000)     _bReset
    00009014     240 (00009000)     _gqAdArrayCounter
    00009015     240 (00009000)     _PeakCurrent
    00009016     240 (00009000)     _bProfile
    00009017     240 (00009000)     _bActiveReset
    00009018     240 (00009000)     _bWriteE2Prom
    00009019     240 (00009000)     _bReadE2Prom
    0000901a     240 (00009000)     _gBlink
    0000901b     240 (00009000)     _UVSTate
    0000901c     240 (00009000)     _gBrakeState
    0000901d     240 (00009000)     _gFanState
    0000901e     240 (00009000)     _uvLock
    0000901f     240 (00009000)     _Pilot
    00009020     240 (00009000)     _giPilotTimer
    00009021     240 (00009000)     _TUNE_OUTPUT
    00009022     240 (00009000)     _giStartUpDelay
    00009023     240 (00009000)     _PIN_DEBOUNCE
    00009024     240 (00009000)     _giDebounceTimer
    00009025     240 (00009000)     _Graph_Flag_Enable_update
    00009026     240 (00009000)     _Graph_Counter
    00009027     240 (00009000)     _Graph_Tick_Counter
    00009028     240 (00009000)     _Graph_Tick_Counter_Value
    00009029     240 (00009000)     _bInertiaCode
    0000902a     240 (00009000)     _bIdentifyInertia
    0000902b     240 (00009000)     _giIndex
    0000902c     240 (00009000)     _giInitInertia
    0000902d     240 (00009000)     _giExitInertia
    0000902e     240 (00009000)     _iSetE2Prom
    0000902f     240 (00009000)     _gctrlState
    00009036     240 (00009000)     _ctrlHandle
    00009038     240 (00009000)     _halHandle
    0000903a     240 (00009000)     _gMaxCurrentSlope
    0000903c     240 (00009000)     _stHandle
    0000903e     240 (00009000)     _glUpperData
    00009040     241 (00009040)     _glLowerData
    00009042     241 (00009040)     _gFinalData
    00009044     241 (00009040)     _giqTriggerSpeedInertiaDetect
    00009046     241 (00009040)     _gPotentiometer
    00009048     241 (00009040)     _gTemperatureSum
    0000904a     241 (00009040)     _gTemperature
    0000904c     241 (00009040)     _gqInertia
    0000904e     241 (00009040)     _giBreakTimer
    00009050     241 (00009040)     _gqTunerValue
    00009052     241 (00009040)     _gqTunerGain
    00009054     241 (00009040)     _giActualIntegral
    00009056     241 (00009040)     _giI2TLimit
    00009058     241 (00009040)     _SpeedRef_krpm_previous
    0000905a     241 (00009040)     _gFlux_pu_to_Wb_sf
    0000905c     241 (00009040)     _gFlux_pu_to_VpHz_sf
    0000905e     241 (00009040)     _gTorque_Ls_Id_Iq_pu_to_Nm_sf
    00009060     241 (00009040)     _gTorque_Flux_Iq_pu_to_Nm_sf
    00009062     241 (00009040)     _gqMultiplier
    00009064     241 (00009040)     _giEntry
    00009066     241 (00009040)     _giExit
    00009068     241 (00009040)     _offset
    0000906a     241 (00009040)     _gain
    0000906e     241 (00009040)     _gPwmData
    00009080     242 (00009080)     _gAdcData
    0000908e     242 (00009080)     _DriveCondition
    000090c0     243 (000090c0)     _gMotorVars
    00009140     245 (00009140)     _gUserParams
    00009200     248 (00009200)     _ctrl
    00009340     24d (00009340)     _st_obj
    0000949a     252 (00009480)     _gqAdArray
    000094aa     252 (00009480)     _gqTempArray
    000094ba     252 (00009480)     ___TI_enable_exit_profile_output
    000094bc     252 (00009480)     ___TI_cleanup_ptr
    000094be     252 (00009480)     ___TI_dtors_ptr
    000094c0     253 (000094c0)     _giReplyData
    000095ec     257 (000095c0)     __lock
    000095ee     257 (000095c0)     __unlock
    000095f2     257 (000095c0)     _cpu
    00009600     258 (00009600)     _giSerialModData
    00009740     25d (00009740)     _hal
    00009840     261 (00009840)     _gqSet
    000098c0     263 (000098c0)     _Graph_Data2
    00009900     264 (00009900)     _Graph_Data
    003f344c    fcd1 (003f3440)     __IQ30mpyI32int
    003f345d    fcd1 (003f3440)     __IQ24int
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    page  address   name
    0     003ee000  .text
    0     003f2e61  C$$EXIT
    abs   003fc0ea  FD$$MPY
    abs   003fc451  FD$$TOL
    abs   003fc278  FS$$ADD
    abs   003fc4dd  FS$$CMP
    abs   003fc16d  FS$$DIV
    abs   003fc2eb  FS$$MPY
    abs   003fc52a  FS$$NEG
    abs   003fc273  FS$$SUB
    abs   003fc48d  FS$$TOFD
    abs   003fc40a  FS$$TOI
    abs   003fc3e1  FS$$TOL
    0     003f2f5b  FS$$TOU
    0     003f2f1a  FS$$TOUL
    abs   003fc4a9  I$$TOFS
    abs   003fc3b7  L$$DIV
    abs   003fc4c3  L$$TOFS
    0     003f2f95  U$$TOFD
    abs   003fc51a  U$$TOFS
    0     003f2fac  UL$$TOFD
    abs   003fc507  UL$$TOFS
    0     003f22e3  _ADC_disable
    0     003f22d9  _ADC_disableBandGap
    0     003f22c2  _ADC_disableInt
    0     003f22b8  _ADC_disableNoOverlapMode
    0     003f22ae  _ADC_disableRefBuffers
    0     003f22a4  _ADC_disableVoltRefLoConv
    0     003f229a  _ADC_enable
    0     003f2290  _ADC_enableBandGap
    0     003f227a  _ADC_enableInt
    0     003f2270  _ADC_enableNoOverlapMode
    0     003f2266  _ADC_enableRefBuffers
    0     003f225c  _ADC_enableVoltRefLoConv
    0     003f2254  _ADC_getDivideSelect
    0     003f224c  _ADC_init
    0     003f2242  _ADC_powerDown
    0     003f2238  _ADC_powerUp
    0     003f222e  _ADC_reset
    0     003f221d  _ADC_setDivideSelect
    0     003f21fc  _ADC_setIntMode
    0     003f21eb  _ADC_setIntPulseGenMode
    0     003f21ca  _ADC_setIntSrc
    0     003f21c3  _ADC_setOffTrim
    0     003f21ac  _ADC_setSampleMode
    0     003f2199  _ADC_setSampleOverlapMode
    0     003f2185  _ADC_setSocChanNumber
    0     003f217b  _ADC_setSocFrc
    0     003f2174  _ADC_setSocFrcWord
    0     003f2160  _ADC_setSocSampleDelay
    0     003f214c  _ADC_setSocTrigSrc
    0     003f213b  _ADC_setTempSensorSrc
    0     003f212a  _ADC_setVoltRefSrc
    0     003f20ff  _ADC_setupSocTrigSrc
    0     003f2ff3  _AFE_init
    0     003f262f  _CLK_disableAdcClock
    0     003f2628  _CLK_disableClaClock
    0     003f2622  _CLK_disableClkIn
    0     003f261e  _CLK_disableCompClock
    0     003f2617  _CLK_disableCpuTimerClock
    0     003f2611  _CLK_disableCrystalOsc
    0     003f260a  _CLK_disableEcanaClock
    0     003f2603  _CLK_disableEcap1Clock
    0     003f25fc  _CLK_disableEqep1Clock
    0     003f25f5  _CLK_disableGpioInputClock
    0     003f25ee  _CLK_disableHrPwmClock
    0     003f25e7  _CLK_disableI2cClock
    0     003f25e0  _CLK_disableLinAClock
    0     003f25da  _CLK_disableOsc1
    0     003f25d4  _CLK_disableOsc1HaltMode
    0     003f25ce  _CLK_disableOsc2
    0     003f25c8  _CLK_disableOsc2HaltMode
    0     003f25be  _CLK_disablePwmClock
    0     003f25b7  _CLK_disableSciaClock
    0     003f25b0  _CLK_disableScibClock
    0     003f25a9  _CLK_disableScicClock
    0     003f25a2  _CLK_disableSpiaClock
    0     003f259b  _CLK_disableTbClockSync
    0     003f2595  _CLK_disableWatchDogHaltMode
    0     003f258e  _CLK_enableAdcClock
    0     003f2588  _CLK_enableAfeCompClock
    0     003f2581  _CLK_enableClaClock
    0     003f257b  _CLK_enableClkIn
    0     003f2575  _CLK_enableCompClock
    0     003f256f  _CLK_enableCpuTimerClock
    0     003f2569  _CLK_enableCrystalOsc
    0     003f2562  _CLK_enableEcanaClock
    0     003f255b  _CLK_enableEcap1Clock
    0     003f2554  _CLK_enableEqep1Clock
    0     003f254d  _CLK_enableGpioInputClock
    0     003f2546  _CLK_enableHrPwmClock
    0     003f253f  _CLK_enableI2cClock
    0     003f2538  _CLK_enableLinAClock
    0     003f2532  _CLK_enableOsc1
    0     003f252c  _CLK_enableOsc1HaltMode
    0     003f2526  _CLK_enableOsc2
    0     003f2520  _CLK_enableOsc2HaltMode
    0     003f2517  _CLK_enablePwmClock
    0     003f2510  _CLK_enableSciaClock
    0     003f2509  _CLK_enableScibClock
    0     003f2502  _CLK_enableScicClock
    0     003f24fb  _CLK_enableSpiaClock
    0     003f24f4  _CLK_enableTbClockSync
    0     003f24ee  _CLK_enableWatchDogHaltMode
    0     003f24e8  _CLK_init
    0     003f24e1  _CLK_setClkOutPreScaler
    0     003f24db  _CLK_setLowSpdPreScaler
    0     003f24d4  _CLK_setOsc2Src
    0     003f24cd  _CLK_setOscSrc
    0     003f24c6  _CLK_setTimer2PreScale
    0     003f24bf  _CLK_setTimer2Src
    0     003f24b8  _CLK_setWatchDogSrc
    0     003f24b1  _CLK_setXClkInSrc
    0     003f2ed2  _CPU_clearIntFlags
    0     003f2ecf  _CPU_disableDebugInt
    0     003f2ecc  _CPU_disableGlobalInts
    0     003f2ec7  _CPU_disableInt
    0     003f2ec4  _CPU_disableInts
    0     003f2ec1  _CPU_disableProtectedRegisterWrite
    0     003f2ebe  _CPU_enableDebugInt
    0     003f2ebb  _CPU_enableGlobalInts
    0     003f2eb7  _CPU_enableInt
    0     003f2eb4  _CPU_enableProtectedRegisterWrite
    0     003f2eb0  _CPU_init
    0     003f1468  _CTRL_getGains
    0     003f1461  _CTRL_getIab_filt_pu
    0     003f145a  _CTRL_getIab_in_pu
    0     003f1453  _CTRL_getIdq_in_pu
    0     003f144c  _CTRL_getIdq_ref_pu
    0     003f14a1  _CTRL_getMagCurrent_pu
    0     003f149e  _CTRL_getMaximumSpeed_pu
    0     003f1445  _CTRL_getVab_in_pu
    0     003f143e  _CTRL_getVab_out_pu
    0     003f1437  _CTRL_getVdq_out_pu
    abs   003fa8fd  _CTRL_getVersion
    0     003f142e  _CTRL_getWaitTimes
    abs   003fa8e2  _CTRL_initCtrl
    0     0000880a  _CTRL_run
    abs   003fa7b7  _CTRL_runTraj
    abs   003fa051  _CTRL_setEstParams
    0     003f11a7  _CTRL_setGains
    0     003f149b  _CTRL_setMagCurrent_pu
    0     003f1498  _CTRL_setMaximumSpeed_pu
    0     003f11cf  _CTRL_setParams
    0     003f1194  _CTRL_setSpd_ref_krpm
    0     003f1191  _CTRL_setSpd_ref_pu
    abs   003f9f1e  _CTRL_setUserMotorParams
    0     003f1188  _CTRL_setWaitTimes
    0     00008800  _CTRL_setup
    0     003f116c  _CTRL_setupClarke_I
    0     003f1156  _CTRL_setupClarke_V
    abs   003f9d30  _CTRL_setupCtrl
    abs   003f9b92  _CTRL_setupEstIdleState
    abs   003f9b57  _CTRL_setupEstOnLineState
    abs   003f99f3  _CTRL_setupTraj
    0     003f10fc  _CTRL_setup_user
    0     003f1049  _CTRL_updateState
    1     0000908e  _DriveCondition
    abs   003f994d  _EST_doCurrentCtrl
    abs   003f9945  _EST_doSpeedCtrl
    abs   003f8dfa  _EST_getAngle_pu
    abs   003f98ab  _EST_getFlux_VpHz
    abs   003f9898  _EST_getFlux_pu
    abs   003f987b  _EST_getFm_pu
    abs   003f981f  _EST_getIdRated
    abs   003f97ec  _EST_getLs_coarse_max_pu
    abs   003f97e2  _EST_getLs_d_H
    abs   003f97dd  _EST_getLs_d_pu
    abs   003f97bb  _EST_getLs_q_H
    abs   003f97b6  _EST_getLs_q_pu
    abs   003f97aa  _EST_getMaxCurrentSlope_pu
    abs   003f97a0  _EST_getOneOverDcBus_pu
    abs   003f979a  _EST_getRr_Ohm
    abs   003f9700  _EST_getRs_Ohm
    abs   003f96b3  _EST_getSpeed_krpm
    abs   003f8808  _EST_getState
    abs   003f9645  _EST_get_krpm_to_pu_sf
    abs   003f9640  _EST_get_pu_to_krpm_sf
    abs   003f957a  _EST_isError
    abs   003f9573  _EST_isIdle
    abs   003f956c  _EST_isLockRotor
    abs   003f8866  _EST_isMotorIdentified
    abs   003f9565  _EST_isOnLine
    abs   003f9468  _EST_run
    abs   003f8dc8  _EST_setFlag_enableForceAngle
    abs   003f8dc0  _EST_setFlag_enableRsRecalc
    abs   003f8d6d  _EST_setId_ref_pu
    abs   003f8d67  _EST_setIdle
    abs   003f8d54  _EST_setIdle_all
    abs   003f8d50  _EST_setIq_ref_pu
    abs   003f8d32  _EST_setLs_d_pu
    abs   003f8cde  _EST_setLs_qFmt
    abs   003f8cd4  _EST_setLs_q_pu
    abs   003f8cc8  _EST_setMaxCurrentSlope_pu
    abs   003f8c05  _EST_setRs_pu
    abs   003f8be2  _EST_updateId_ref_pu
    abs   003f8900  _EST_updateState
    abs   003f880a  _EST_useZeroIq_ref
    0     003f2f17  _FILTER_FO_getDenCoeffs
    0     003f2f10  _FILTER_FO_getInitialConditions
    0     003f2f0a  _FILTER_FO_getNumCoeffs
    0     003f2f04  _FILTER_FO_init
    0     003f2f02  _FILTER_FO_setDenCoeffs
    0     003f2efd  _FILTER_FO_setInitialConditions
    0     003f2ef9  _FILTER_FO_setNumCoeffs
    0     003f2f55  _FLASH_clear3VStatus
    0     00008fc0  _FLASH_disablePipelineMode
    0     00008fba  _FLASH_enablePipelineMode
    0     003f2f52  _FLASH_get3VStatus
    0     003f2f4f  _FLASH_getActiveWaitCount
    0     003f2f4b  _FLASH_getActiveWaitStatus
    0     003f2f48  _FLASH_getPowerMode
    0     003f2f45  _FLASH_getStandbyWaitCount
    0     003f2f41  _FLASH_getStandbyWaitStatus
    0     003f2f3b  _FLASH_init
    0     00008fb5  _FLASH_setActiveWaitCount
    0     00008fae  _FLASH_setNumPagedReadWaitStates
    0     00008fa7  _FLASH_setNumRandomReadWaitStates
    0     00008fa0  _FLASH_setOtpWaitStates
    0     00008f99  _FLASH_setPowerMode
    0     00008f94  _FLASH_setStandbyWaitCount
    1     00009001  _Flag_Latch_softwareUpdate
    0     003f28e4  _GPIO_getData
    0     003f28d9  _GPIO_getPortData
    0     003f28d3  _GPIO_init
    0     003f28c9  _GPIO_lpmSelect
    0     003f28b6  _GPIO_read
    0     003f289c  _GPIO_setDirection
    0     003f2891  _GPIO_setExtInt
    0     003f2881  _GPIO_setHigh
    0     003f2871  _GPIO_setLow
    0     003f2844  _GPIO_setMode
    0     003f2836  _GPIO_setPortData
    0     003f281c  _GPIO_setPullup
    0     003f27e6  _GPIO_setQualification
    0     003f27a6  _GPIO_setQualificationPeriod
    0     003f2796  _GPIO_toggle
    1     00009026  _Graph_Counter
    1     00009900  _Graph_Data
    1     000098c0  _Graph_Data2
    1     00009025  _Graph_Flag_Enable_update
    1     00009027  _Graph_Tick_Counter
    1     00009028  _Graph_Tick_Counter_Value
    0     003ef75f  _HAL_AdcCalChanSelect
    0     003ef7b6  _HAL_AdcCalConversion
    0     003ef90e  _HAL_AdcOffsetSelfCal
    0     003efc45  _HAL_OscTempComp
    0     003ef93d  _HAL_cal
    0     003efc41  _HAL_disableGlobalInts
    0     003efb1f  _HAL_disableWdog
    0     003efc2f  _HAL_enableAdcInts
    0     003efc2b  _HAL_enableDebugInt
    0     003efc27  _HAL_enableGlobalInts
    0     003efc16  _HAL_enablePwmInt
    0     003efa8c  _HAL_getOscTrimValue
    0     003efb24  _HAL_init
    0     003efadf  _HAL_osc1Comp
    0     003efa9f  _HAL_osc2Comp
    0     003efa72  _HAL_setDacParameters
    0     003ef951  _HAL_setParams
    0     003ef68d  _HAL_setupAdcs
    0     003ef609  _HAL_setupAfe
    0     003ef5ed  _HAL_setupClks
    0     003ef5b7  _HAL_setupFaults
    0     00008fc6  _HAL_setupFlash
    0     003ef32c  _HAL_setupGpios
    0     003ef311  _HAL_setupI2c
    0     003ef2d5  _HAL_setupPeripheralClks
    0     003ef2b9  _HAL_setupPie
    0     003ef27a  _HAL_setupPll
    0     003ef1da  _HAL_setupPwmDacs
    0     003ef102  _HAL_setupPwms
    0     003ef0a5  _HAL_setupSciA
    0     003ef04c  _HAL_setupTimers
    0     003ee9d5  _HAL_writePwmDataUserB
    0     003f26c1  _I2C_GetRxFifoStatus
    0     003f264e  _I2C_GetTxFifoStatus
    0     003f2644  _I2C_MasterControl
    0     003f2793  _I2C_clearNoAckBit
    0     003f278f  _I2C_clearRunFree
    0     003f278b  _I2C_clearRxFifoInt
    0     003f2788  _I2C_clearStopConditionDetection
    0     003f2784  _I2C_clearTxFifoInt
    0     003f2780  _I2C_disable
    0     003f277c  _I2C_disableFifo
    0     003f2779  _I2C_disableInt
    0     003f2775  _I2C_enable
    0     003f2771  _I2C_enableFifo
    0     003f276f  _I2C_enableInt
    0     003f26c5  _I2C_getData
    0     003f276c  _I2C_getIntSource
    0     003f276a  _I2C_getStatus
    0     003f2764  _I2C_init
    0     003f2760  _I2C_isAllRegisterReady
    0     003f263d  _I2C_isMasterBusy
    0     003f2636  _I2C_isMasterStopBitSet
    0     003f275c  _I2C_isNoAck
    0     003f2758  _I2C_isStopConditionDetected
    0     003f2641  _I2C_putData
    0     003f2755  _I2C_resetAll
    0     003f2751  _I2C_resetRxFifo
    0     003f274d  _I2C_resetTxFifo
    0     003f2749  _I2C_setMaster
    0     003f263b  _I2C_setMasterSlaveAddr
    0     003f2745  _I2C_setMasterStopBit
    0     003f2741  _I2C_setRunFree
    0     003f273d  _I2C_setSlave
    0     003f273b  _I2C_setSlaveAddress
    0     003f2736  _I2C_setupClock
    0     003f2c45  _OFFSET_getBeta
    0     003f2c34  _OFFSET_init
    0     003f2c1e  _OFFSET_setBeta
    0     003f2c0f  _OFFSET_setInitCond
    0     003f2c0d  _OFFSET_setOffset
    0     003f2ddb  _OSC_init
    0     003f2dce  _OSC_setCoarseTrim
    0     003f2dbd  _OSC_setFineTrim
    0     003f2db4  _OSC_setTrim
    0     003f29f3  _PIE_clearAllFlags
    0     003f29f0  _PIE_clearAllInts
    0     003f29ed  _PIE_disable
    0     003f29e6  _PIE_disableAllInts
    0     003f29e2  _PIE_disableCaptureInt
    0     003f29d9  _PIE_disableExtInt
    0     003f29cf  _PIE_disableInt
    0     003f29cc  _PIE_enable
    0     003f29b0  _PIE_enableAdcInt
    0     003f29ac  _PIE_enableCaptureInt
    0     003f298f  _PIE_enableExtInt
    0     003f2986  _PIE_enableInt
    0     003f2981  _PIE_enablePwmInt
    0     003f297c  _PIE_enablePwmTzInt
    0     003f2976  _PIE_enableSciInt
    0     003f2973  _PIE_enableTimer0Int
    0     003f296a  _PIE_forceInt
    0     003f2962  _PIE_getExtIntCount
    0     003f295b  _PIE_getIntEnables
    0     003f2954  _PIE_getIntFlags
    0     003f2ff9  _PIE_illegalIsr
    0     003f294c  _PIE_init
    0     003f293a  _PIE_registerPieIntHandler
    0     003f292f  _PIE_registerSystemIntHandler
    0     003f2924  _PIE_setDefaultIntVectorTable
    0     003f2913  _PIE_setExtIntPolarity
    0     003f28ff  _PIE_unregisterPieIntHandler
    0     003f28f2  _PIE_unregisterSystemIntHandler
    1     00009023  _PIN_DEBOUNCE
    0     003f2bb3  _PLL_disable
    0     003f2bad  _PLL_disableClkDetect
    0     003f2ba7  _PLL_disableNormRdy
    0     003f2ba1  _PLL_disableOsc
    0     003f2b9b  _PLL_enable
    0     003f2b95  _PLL_enableClkDetect
    0     003f2b8f  _PLL_enableNormRdy
    0     003f2b89  _PLL_enableOsc
    0     003f2b85  _PLL_getClkFreq
    0     003f2b82  _PLL_getClkStatus
    0     003f2b7f  _PLL_getDivideSelect
    0     003f2b7c  _PLL_getLockStatus
    0     003f2b76  _PLL_init
    0     003f2b70  _PLL_resetClkDetect
    0     003f2b6a  _PLL_setClkFreq
    0     003f2b63  _PLL_setDivideSelect
    0     003f2b5e  _PLL_setLockPeriod
    0     003f1ec1  _PWM_clearTripZone
    0     003f1ebe  _PWM_decrementDeadBandFallingEdgeDelay
    0     003f1ebb  _PWM_decrementDeadBandRisingEdgeDelay
    0     003f1eb7  _PWM_disableChopping
    0     003f1eb4  _PWM_disableCounterLoad
    0     003f1eb1  _PWM_disableDeadBand
    0     003f1ead  _PWM_disableDeadBandHalfCycle
    0     003f1ea6  _PWM_disableDigitalCompareBlankingWindow
    0     003f1e9f  _PWM_disableDigitalCompareBlankingWindowInversion
    0     003f1e9b  _PWM_disableInt
    0     003f1e97  _PWM_disableSocAPulse
    0     003f1e93  _PWM_disableSocBPulse
    0     003f1e8c  _PWM_disableTripZoneInt
    0     003f1e85  _PWM_disableTripZoneSrc
    0     003f1e7f  _PWM_disableTripZones
    0     003f1e7b  _PWM_enableChopping
    0     003f1e78  _PWM_enableCounterLoad
    0     003f1e74  _PWM_enableDeadBandHalfCycle
    0     003f1e6d  _PWM_enableDigitalCompareBlankingWindow
    0     003f1e66  _PWM_enableDigitalCompareBlankingWindowInversion
    0     003f1e62  _PWM_enableInt
    0     003f1e5e  _PWM_enableSocAPulse
    0     003f1e5a  _PWM_enableSocBPulse
    0     003f1e54  _PWM_enableTripZoneInt
    0     003f1e4e  _PWM_enableTripZoneSrc
    0     003f1e4b  _PWM_getDeadBandFallingEdgeDelay
    0     003f1e48  _PWM_getDeadBandRisingEdgeDelay
    0     003f1e44  _PWM_getIntCount
    0     003f1e40  _PWM_getShadowStatus_CmpA
    0     003f1e3c  _PWM_getShadowStatus_CmpB
    0     003f1e37  _PWM_getSocACount
    0     003f1e32  _PWM_getSocBCount
    0     003f1e2f  _PWM_incrementDeadBandFallingEdgeDelay
    0     003f1e2c  _PWM_incrementDeadBandRisingEdgeDelay
    0     003f1e26  _PWM_init
    0     003f1e1f  _PWM_setActionQualContSWForce_PwmA
    0     003f1e16  _PWM_setActionQualContSWForce_PwmB
    0     003f1e0d  _PWM_setActionQual_CntDown_CmpA_PwmA
    0     003f1e04  _PWM_setActionQual_CntDown_CmpA_PwmB
    0     003f1dfb  _PWM_setActionQual_CntDown_CmpB_PwmA
    0     003f1df2  _PWM_setActionQual_CntDown_CmpB_PwmB
    0     003f1de9  _PWM_setActionQual_CntUp_CmpA_PwmA
    0     003f1de0  _PWM_setActionQual_CntUp_CmpA_PwmB
    0     003f1dd7  _PWM_setActionQual_CntUp_CmpB_PwmA
    0     003f1dce  _PWM_setActionQual_CntUp_CmpB_PwmB
    0     003f1dc5  _PWM_setActionQual_Period_PwmA
    0     003f1dbc  _PWM_setActionQual_Period_PwmB
    0     003f1db5  _PWM_setActionQual_Zero_PwmA
    0     003f1dae  _PWM_setActionQual_Zero_PwmB
    0     003f1da7  _PWM_setChoppingClkFreq
    0     003f1da0  _PWM_setChoppingDutyCycle
    0     003f1d99  _PWM_setChoppingPulseWidth
    0     003f1d95  _PWM_setClkDiv
    0     003f1d93  _PWM_setCount
    0     003f1d8f  _PWM_setCounterMode
    0     003f1d8c  _PWM_setDeadBandFallingEdgeDelay
    0     003f1d85  _PWM_setDeadBandInputMode
    0     003f1d7e  _PWM_setDeadBandOutputMode
    0     003f1d77  _PWM_setDeadBandPolarity
    0     003f1d74  _PWM_setDeadBandRisingEdgeDelay
    0     003f1d5a  _PWM_setDigitalCompareAEvent1
    0     003f1d4a  _PWM_setDigitalCompareAEvent2
    0     003f1d30  _PWM_setDigitalCompareBEvent1
    0     003f1d20  _PWM_setDigitalCompareBEvent2
    0     003f1d14  _PWM_setDigitalCompareBlankingPulse
    0     003f1d11  _PWM_setDigitalCompareFilterOffset
    0     003f1d07  _PWM_setDigitalCompareFilterSource
    0     003f1d04  _PWM_setDigitalCompareFilterWindow
    0     003f1cf5  _PWM_setDigitalCompareInput
    0     003f1cf1  _PWM_setHighSpeedClkDiv
    0     003f1cea  _PWM_setIntMode
    0     003f1ce3  _PWM_setIntPeriod
    0     003f1cdf  _PWM_setLoadMode_CmpA
    0     003f1cd9  _PWM_setLoadMode_CmpB
    0     003f1cd7  _PWM_setPeriod
    0     003f1cd3  _PWM_setPeriodLoad
    0     003f1cd1  _PWM_setPhase
    0     003f1ccd  _PWM_setPhaseDir
    0     003f1cc9  _PWM_setRunMode
    0     003f1cc3  _PWM_setShadowMode_CmpA
    0     003f1cbd  _PWM_setShadowMode_CmpB
    0     003f1cb4  _PWM_setSocAPeriod
    0     003f1caa  _PWM_setSocAPulseSrc
    0     003f1ca1  _PWM_setSocBPeriod
    0     003f1c98  _PWM_setSocBPulseSrc
    0     003f1c95  _PWM_setSwSync
    0     003f1c91  _PWM_setSyncMode
    0     003f1c87  _PWM_setTripZoneDCEventSelect_DCAEVT1
    0     003f1c7b  _PWM_setTripZoneDCEventSelect_DCAEVT2
    0     003f1c6f  _PWM_setTripZoneDCEventSelect_DCBEVT1
    0     003f1c63  _PWM_setTripZoneDCEventSelect_DCBEVT2
    0     003f1c57  _PWM_setTripZoneState_DCAEVT1
    0     003f1c4b  _PWM_setTripZoneState_DCAEVT2
    0     003f1c3f  _PWM_setTripZoneState_DCBEVT1
    0     003f1c33  _PWM_setTripZoneState_DCBEVT2
    0     003f1c29  _PWM_setTripZoneState_TZA
    0     003f1c1d  _PWM_setTripZoneState_TZB
    0     003f2cdb  _PWR_disableBrownOutReset
    0     003f2cd1  _PWR_disableWatchDogInt
    0     003f2cce  _PWR_enableBrownOutReset
    0     003f2cc4  _PWR_enableWatchDogInt
    0     003f2cbc  _PWR_init
    0     003f2cab  _PWR_setLowPowerMode
    0     003f2c9a  _PWR_setNumStandByClocks
    1     00009015  _PeakCurrent
    1     0000901f  _Pilot
    0     003f77e8  _RamfuncsLoadEnd
    0     003f7000  _RamfuncsLoadStart
    0     00008800  _RamfuncsRunStart
    0     003f26c7  _ReadE2Prom
    0     003f1041  _Reset
    0     003f2cde  _SCI_RX_ISR
    0     003f2af1  _SCI_clearAutoBaudDetect
    0     003f2aed  _SCI_clearRxFifoInt
    0     003f2ae9  _SCI_clearRxFifoOvf
    0     003f2ae5  _SCI_clearTxFifoInt
    0     003f2ae2  _SCI_disable
    0     003f2ade  _SCI_disableAutoBaudAlign
    0     003f2adb  _SCI_disableLoopBack
    0     003f2ad8  _SCI_disableParity
    0     003f2ad5  _SCI_disableRx
    0     003f2ad2  _SCI_disableRxErrorInt
    0     003f2ace  _SCI_disableRxFifoInt
    0     003f2acb  _SCI_disableRxInt
    0     003f2ac8  _SCI_disableSleep
    0     003f2ac5  _SCI_disableTx
    0     003f2ac1  _SCI_disableTxFifoEnh
    0     003f2abd  _SCI_disableTxFifoInt
    0     003f2aba  _SCI_disableTxInt
    0     003f2ab7  _SCI_disableTxWake
    0     003f2ab4  _SCI_enable
    0     003f2ab0  _SCI_enableAutoBaudAlign
    0     003f2aac  _SCI_enableChannels
    0     003f2aa9  _SCI_enableLoopBack
    0     003f2aa6  _SCI_enableParity
    0     003f2aa3  _SCI_enableRx
    0     003f2aa0  _SCI_enableRxErrorInt
    0     003f2a9c  _SCI_enableRxFifo
    0     003f2a98  _SCI_enableRxFifoInt
    0     003f2a95  _SCI_enableRxInt
    0     003f2a92  _SCI_enableSleep
    0     003f2a8f  _SCI_enableTx
    0     003f2a8b  _SCI_enableTxFifo
    0     003f2a87  _SCI_enableTxFifoEnh
    0     003f2a83  _SCI_enableTxFifoInt
    0     003f2a80  _SCI_enableTxInt
    0     003f2a7d  _SCI_enableTxWake
    0     003f2a77  _SCI_getDataBlocking
    0     003f2a6e  _SCI_getDataNonBlocking
    0     003f2a6a  _SCI_getRxFifoStatus
    0     003f2a28  _SCI_getTxFifoStatus
    0     003f2a64  _SCI_init
    0     003f2a5d  _SCI_putDataBlocking
    0     003f2a55  _SCI_putDataNonBlocking
    0     003f2a52  _SCI_reset
    0     003f2a48  _SCI_resetChannels
    0     003f2a3e  _SCI_resetRxFifo
    0     003f2a34  _SCI_resetTxFifo
    0     003f2a2c  _SCI_send_char
    0     003f2a22  _SCI_setBaudRate
    0     003f2a1e  _SCI_setCharLength
    0     003f2a1a  _SCI_setMode
    0     003f2a16  _SCI_setNumStopBits
    0     003f2a12  _SCI_setParity
    0     003f2a0f  _SCI_setPriority
    0     003f2a08  _SCI_setRxFifoIntLevel
    0     003f2a01  _SCI_setTxDelay
    0     003f29fa  _SCI_setTxFifoIntLevel
    0     003f2d1c  _STPOSCONV_init
    0     003f2e37  _STVELCTL_init
    0     003f1ec7  _STVELCTL_run
    0     003f2de1  _STVELID_init
    0     003f18f6  _STVELID_run
    0     003f2e0c  _STVELMOVE_init
    0     003f14a4  _STVELMOVE_run
    0     003f2e8a  _STVELPLAN_init
    0     003f2d83  _ST_initVersion
    0     003ee83a  _ST_runVelCtl
    0     003ee89d  _ST_runVelId
    0     003ee70c  _ST_runVelMove
    1     00009058  _SpeedRef_krpm_previous
    0     003f2d80  _TIMER_clearFlag
    0     003f2d7d  _TIMER_disableInt
    0     003f2d7a  _TIMER_enableInt
    0     003f2d77  _TIMER_getStatus
    0     003f2d71  _TIMER_init
    0     003f2d63  _TIMER_setDecimationFactor
    0     003f2d5f  _TIMER_setEmulationMode
    0     003f2d51  _TIMER_setPreScaler
    1     00009021  _TUNE_OUTPUT
    0     003f06c1  _USER_calcPIgains
    0     003f00dd  _USER_checkForErrors
    0     003f00cf  _USER_computeFlux
    0     003f0081  _USER_computeFlux_pu_to_VpHz_sf
    0     003f0033  _USER_computeFlux_pu_to_Wb_sf
    0     003effd1  _USER_computeTorque_Flux_Iq_pu_to_Nm_sf
    0     003eff78  _USER_computeTorque_Ls_Id_Iq_pu_to_Nm_sf
    0     003eff2b  _USER_computeTorque_Nm
    0     003efed3  _USER_computeTorque_lbin
    0     003efed0  _USER_getErrorCode
    0     003efecd  _USER_setErrorCode
    0     003efd1d  _USER_setParams
    0     003efc9a  _USER_softwareUpdate1p6
    1     0000901b  _UVSTate
    0     003f2c92  _WDOG_clearCounter
    0     003f2c8a  _WDOG_disable
    0     003f2c84  _WDOG_disableInt
    0     003f2c7e  _WDOG_disableOverRide
    0     003f2c75  _WDOG_enable
    0     003f2c6f  _WDOG_enableInt
    0     003f2c69  _WDOG_enableOverRide
    0     003f2c66  _WDOG_getIntStatus
    0     003f2c60  _WDOG_init
    0     003f2c5e  _WDOG_setCount
    0     003f2c54  _WDOG_setPreScaler
    0     003f2652  _WriteE2Prom
    abs   003feb8e  __IQ20div
    abs   003ff0ce  __IQ24cosPU
    abs   003febd5  __IQ24div
    0     003f345d  __IQ24int
    abs   003ff131  __IQ24rsmpy
    abs   003ff07c  __IQ24sinPU
    abs   003fedfc  __IQ24sqrt
    abs   003ff170  __IQ24toF
    0     003f344c  __IQ30mpyI32int
    abs   003ff184  __IQ30toF
    1     00000400  __STACK_END
    abs   000003b0  __STACK_SIZE
    1     000094bc  ___TI_cleanup_ptr
    1     000094be  ___TI_dtors_ptr
    1     000094ba  ___TI_enable_exit_profile_output
    abs   ffffffff  ___TI_pprof_out_hndl
    abs   ffffffff  ___TI_prof_data_size
    abs   ffffffff  ___TI_prof_data_start
    abs   ffffffff  ___binit__
    abs   ffffffff  ___c_args__
    0     003f3001  ___cinit__
    0     003f3001  ___etext__
    abs   ffffffff  ___pinit__
    0     003ee000  ___text__
    0     003f2fc2  __args_main
    1     000095ec  __lock
    0     003f2fea  __nop
    0     003f2fe6  __register_lock
    0     003f2fe2  __register_unlock
    1     00000050  __stack
    0     003f3000  __system_post_cinit
    0     003f2ffe  __system_pre_init
    1     000095ee  __unlock
    0     003f2e61  _abort
    1     0000900e  _bActivateLR
    1     00009017  _bActiveReset
    1     0000902a  _bIdentifyInertia
    1     00009029  _bInertiaCode
    1     00009016  _bProfile
    1     00009019  _bReadE2Prom
    1     00009013  _bReset
    1     00009018  _bWriteE2Prom
    0     003f2bb9  _c_int00
    0     003f2af5  _ceil
    0     003f2af5  _ceilf
    0     003f2ed5  _copy_in
    1     000095f2  _cpu
    1     00009200  _ctrl
    1     00009036  _ctrlHandle
    0     003f2e63  _exit
    1     00009080  _gAdcData
    1     0000901a  _gBlink
    1     0000901c  _gBrakeState
    1     00009000  _gCounter_updateGlobals
    1     0000900c  _gDriveMode
    1     0000900d  _gDriveSerialMode
    1     0000900b  _gDriveStatus
    1     0000901d  _gFanState
    1     00009042  _gFinalData
    1     0000905c  _gFlux_pu_to_VpHz_sf
    1     0000905a  _gFlux_pu_to_Wb_sf
    1     00009002  _gLEDcnt
    1     0000903a  _gMaxCurrentSlope
    1     000090c0  _gMotorVars
    1     00009046  _gPotentiometer
    1     0000906e  _gPwmData
    1     0000904a  _gTemperature
    1     00009048  _gTemperatureSum
    1     00009060  _gTorque_Flux_Iq_pu_to_Nm_sf
    1     0000905e  _gTorque_Ls_Id_Iq_pu_to_Nm_sf
    1     00009140  _gUserParams
    1     0000906a  _gain
    1     0000900f  _gbActivateMode
    1     00009012  _gbStartStopMotor
    1     00009011  _gbStartStopMotorPin
    1     00009010  _gbStartStopMotorSerial
    1     0000902f  _gctrlState
    1     00009054  _giActualIntegral
    1     0000904e  _giBreakTimer
    1     00009008  _giChecksum
    1     00009009  _giCrc
    1     00009024  _giDebounceTimer
    1     00009064  _giEntry
    1     00009066  _giExit
    1     0000902d  _giExitInertia
    1     00009003  _giI2CDelay
    1     00009056  _giI2TLimit
    1     0000902b  _giIndex
    1     0000902c  _giInitInertia
    1     00009005  _giLocate
    1     00009007  _giMasterAddress
    1     00009006  _giPendingQueryFlag
    1     00009020  _giPilotTimer
    1     0000900a  _giReplyArrayIndex
    1     000094c0  _giReplyData
    1     00009600  _giSerialModData
    1     00009004  _giSerialTimer
    1     00009022  _giStartUpDelay
    1     00009044  _giqTriggerSpeedInertiaDetect
    1     00009040  _glLowerData
    1     0000903e  _glUpperData
    1     0000949a  _gqAdArray
    1     00009014  _gqAdArrayCounter
    1     0000904c  _gqInertia
    1     00009062  _gqMultiplier
    1     00009840  _gqSet
    1     000094aa  _gqTempArray
    1     00009052  _gqTunerGain
    1     00009050  _gqTunerValue
    1     00009740  _hal
    1     00009038  _halHandle
    0     003f07c9  _iCalcCRC
    0     003f0782  _iEndReply
    0     003f0fd5  _iPoll
    0     003f0bd9  _iReply0304
    0     003f07ed  _iReply16
    1     0000902e  _iSetE2Prom
    abs   003fbf13  _log
    0     003eea0c  _main
    0     00008d39  _mainISR
    0     003f2fd3  _memCopy
    0     003f2f78  _memcpy
    1     00009068  _offset
    abs   003fc1f0  _pow
    0     003ee694  _recalcKpKi
    abs   003fbba1  _s0_calc
    abs   003fbb71  _s0_conf
    abs   003fbcab  _s2_calc
    abs   003fbd49  _s4_calc
    abs   003fbdf8  _s4_conf
    abs   003fbe1c  _s4_reset
    abs   003fbe5f  _s8_calc
    abs   003fbe41  _s8_cfg
    abs   003fbefb  _s8_get
    abs   003fbe36  _s8_reset
    0     003f079e  _sendByte
    abs   003fbe31  _spintac_rom_ver
    1     0000903c  _stHandle
    1     00009340  _st_obj
    0     003ee4cb  _updateGlobalVariables_motor
    0     003ee4a3  _updateKpKiGains
    0     00008fe4  _usDelay
    1     0000901e  _uvLock
    0     003ee464  _vBaseRunCode
    0     003f2456  _vBrake
    0     003ee43e  _vChangeMode
    0     003f2429  _vFan
    0     003f22ed  _vFault
    0     003ee3cb  _vInitArray
    0     003ee3c1  _vInitVariables
    0     003f101f  _vModBus
    0     003ee0ce  _vModeEntryActions
    0     003ee02a  _vModeExitActions
    0     003f270f  _vReadBulkE2PROM
    0     003ee022  _vResetArray
    0     003ee000  _vSetFlags
    0     003f269a  _vWriteBulkE2PROM
    abs   ffffffff  binit
    0     003f3001  cinit
    0     003f7ffe  code_start
    0     003f3001  etext
    abs   ffffffff  pinit
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    page  address   name
    0     00008d39  _mainISR
    0     00008fe4  _usDelay
    0     003ee000  .text
    0     003eea0c  _main
    0     003ef93d  _HAL_cal
    0     003f0fd5  _iPoll
    0     003f101f  _vModBus
    0     003f1041  _Reset
    0     003f22ed  _vFault
    0     003f2429  _vFan
    0     003f2456  _vBrake
    0     003f2af5  _ceil
    0     003f2af5  _ceilf
    0     003f2bb9  _c_int00
    0     003f2e61  C$$EXIT
    0     003f2e61  _abort
    0     003f2e63  _exit
    0     003f2ed5  _copy_in
    0     003f2f1a  FS$$TOUL
    0     003f2f5b  FS$$TOU
    0     003f2f78  _memcpy
    0     003f2f95  U$$TOFD
    0     003f2fac  UL$$TOFD
    0     003f2fd3  _memCopy
    0     003f2fea  __nop
    0     003f3001  cinit
    0     003f3001  etext
    1     00000050  __stack
    1     00009002  _gLEDcnt
    1     00009009  _giCrc
    1     00009013  _bReset
    1     0000901a  _gBlink
    1     0000901b  _UVSTate
    1     0000901e  _uvLock
    1     0000901f  _Pilot
    1     0000902b  _giIndex
    1     00009064  _giEntry
    1     00009066  _giExit
    1     00009068  _offset
    1     0000906a  _gain
    1     00009200  _ctrl
    1     00009340  _st_obj
    1     000095ec  __lock
    1     000095ee  __unlock
    1     000095f2  _cpu
    1     00009740  _hal
    1     00009840  _gqSet
    abs   003fbf13  _log
    abs   003fc1f0  _pow
    abs   003fc3b7  L$$DIV
    abs   ffffffff  binit
    abs   ffffffff  pinit
    [742 symbols]
  • Thanks for posting the contents, I don't see any thing that is in violation of the memory map.  As an experiment, in Uniflash instead of picking the F28054 device, can you configure Uniflash as if you were using the F28055 device instead, to see if that gets rid of the error?  Both these devices have the same memory map, so I'm trying to see if the 28054 device definitions in uniflash might be incorrect.  The F28054 device does not have the CLA, but that shouldn't impact the Uniflash either way.
    Matthew
