Part Number: TMS320F28376S
Other Parts Discussed in Thread: DAC70501
Hi Expert,
My customer now is target to design a ANC (Active Noise Cancellation) system, and they are searching our ADC / DAC or MSU based total solution, need expert to provide the recommendation and technical topic reply here. Thanks for your support in advance!
Can you help to check does our TMS320F28376S can as a total solution and fulfill below requirement ? Does we have any experience before to check the latency estimate?
------- Requirement spec ---------------------
- Group delay: <120us @48Khz sampling rate (ADC+DAC only, SAR ADC is recommended)
- ADC/DAC bit resolution: >= 14bit(applying audio scope)
- Port #: ADC: 4 input (support dual channel sampling simutaneously, at least)
- Port #: DAC: 2 output
<audio path> as below
BR,
Kai
