Hi Team,
In this reference design, what voltage range is sampled? How many bits of precision are used by the on-chip ADC?
Thanks & Regards
Yale
Hi Team,
Thanks & Regards
Yale
Hi Yale,
we are currently sampling with 12 bit the voltages. The range for the voltage A for example is +- 450 V. This measurement is centered with respect to 1V65.
Best Regards
Riccardo
Hi Team,
Thank you very much for your answer. The voltage collection range has solved my doubts. But I found in your reference design that the ADC pin in 28379Dx is connected to a 22uf capacitor. According to the chip manual, it is a 16 bit A/D precision conversion.
Thanks&Regards
LIU
Hi Riccardo,
Thanks for your reply!
lcdreamsky <-- This is the customer who asked these questions. We very much look forward to your further answer.
Thanks & Regards
Yale
Hi Liu,
I was trying to look to the pins that you mention for voltage measurement and I have not found any charging bucket having 22 uF. I have looked in available schematic on TI.com and the caps is 100 nF. Is it kindly possible to provide me the number of the cap (e.g. C63)? So I can identify this big cap.
I have looked down at the code level and currently we are using a 12 bit conversion which is more than enough for this application. The error that you are going to do in the voltage measurement is 0.22 V which is negligible if you consider that these voltages are just used for feed foward in current loops and PLL.
In general, the ADC of 28379D can be configured as a 12 bit.
Best Regards
Riccardo
