SPRU357B(TMS320LF/LC240xA)
I wonder if someone could help me with this DSP controller(TMS320LF/LC240xA).I am new with DSPs and I dont know how to start working and programming with them.
I want to know if I have to write codes by assembly or I can use C codes too?
I also found "TMS320C6000 Code Composer Studio" here and I don't know whether I could use this composer for my DSP or not!
would be grateful for any answer;)
regards,
Sara.
  • Sara,
    A couple of things.  TI has a number of difference DSP families, each of which has different strengths based on the type of application.  The C2000 family is primarily designed for motor control operations, the C5000 family is a low power DSP, and the C6x is a high performance procesor.
    The TMS320LF/LC240xA is a member of the C2000 family.  The latest Code Composer Studio supports all 3 of those families, but I am not quite sure about the specific device that you are referring to (a 24x) device.  I will move this thread to the C2000 forum.
    Incidentally, regardless of which TI DSP you are using, there is a C compiler for each.
    Dan
  • Dear Dan,
    First of all thanks for your good explanation. Actually I want to use this DSP for programming and commanding a robot's arm and its caliper and I don’t know how to start. Do you think I could use any other document except the DSP's manual to find out how I can work with it ?(because all the explanations are given in assembly language)
    Sara
