Part Number: TMS320F28377D
Hi Team,
Here is an issue from the customer may need your help:
When I define a variable at the RAM from CPU to CLA.
I have a problem about the configuration of CMD file .
The error of compiler is as bellow:
<a href="file:/C:/ti/ccs1020/ccs/tools/compiler/dmed/HTML/10099.html">#10099-D</a> program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. run placement with alignment/blocking fails for section "Cla1Prog" size 0x84e page 0. Available memory ranges:
I increase the FLASHD space,but it still has problems.
The following is my CMD files:
* Copyright (c) 2015-2020, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== TMS320F28377D.cmd ========
* Define the memory block start/length for the F28377D
// The user must define CLA_C in the project linker settings if using the
// CLA C compiler
// Project Properties -> C2000 Linker -> Advanced Options -> Command File
// Preprocessing -> --define
#ifdef CLA_C
// Define a size for the CLA scratchpad area that will be used
// by the CLA compiler for local symbols and temps
// Also force references to the special symbols that mark the
// scratchpad are.
CLA_SCRATCHPAD_SIZE = 0x100;
--undef_sym=__cla_scratchpad_end
--undef_sym=__cla_scratchpad_start
#endif //CLA_C
MEMORY
PAGE 0 : /* Program Memory */
/* BEGIN is used for the "boot to FLASH" bootloader mode */
D01SARAM : origin = 0x00B000, length = 0x001000
LS0SARAM : origin = 0x008000, length = 0x00800 /* on-chip RAM */
LS5SARAM : origin = 0x00A800, length = 0x000800 /* on-chip RAM */
/* Flash boot address */
BEGIN : origin = 0x080000, length = 0x000002
/* Flash sectors */
FLASHA : origin = 0x080002, length = 0x001FFE /* on-chip Flash */
FLASHB : origin = 0x082000, length = 0x002000 /* on-chip Flash */
FLASHC : origin = 0x084000, length = 0x002000 /* on-chip Flash */
#if 1
FLASHD : origin = 0x086000, length = 0x002000 /* on-chip Flash */
FLASHEF : origin = 0x088000, length = 0x010000 /* on-chip Flash */
#endif
//FLASHF : origin = 0x090000, length = 0x008000 /* on-chip Flash */
FLASHG : origin = 0x098000, length = 0x008000 /* on-chip Flash */
FLASHH : origin = 0x0A0000, length = 0x008000 /* on-chip Flash */
FLASHI : origin = 0x0A8000, length = 0x008000 /* on-chip Flash */
FLASHJ : origin = 0x0B0000, length = 0x008000 /* on-chip Flash */
FLASHK : origin = 0x0B8000, length = 0x002000 /* on-chip Flash */
FLASHL : origin = 0x0BA000, length = 0x002000 /* on-chip Flash */
FLASHM : origin = 0x0BC000, length = 0x002000 /* on-chip Flash */
FLASHN : origin = 0x0BE000, length = 0x002000 /* on-chip Flash */
RESET : origin = 0x3FFFC0, length = 0x000002
PAGE 1 : /* Data Memory */
BOOT_RSVD : origin = 0x000002, length = 0x000120 /* Part of M0, BOOT rom
will use this for
stack */
M01SARAM : origin = 0x000122, length = 0x0006DE /* on-chip RAM */
//LS0SARAM : origin = 0x008000, length = 0x00800 /* on-chip RAM */
LS14SARAM : origin = 0x008800, length = 0x002000 /* on-chip RAM */
/* on-chip Global shared RAMs */
//RAMGS0 : origin = 0x00C000, length = 0x001000
//RAMGS1 : origin = 0x00D000, length = 0x001000
//RAMGS2 : origin = 0x00E000, length = 0x001000
//RAMGS3 : origin = 0x00F000, length = 0x001000
//RAMGS4 : origin = 0x010000, length = 0x001000
//RAMGS5 : origin = 0x011000, length = 0x001000
//RAMGS6 : origin = 0x012000, length = 0x001000
//RAMGS7 : origin = 0x013000, length = 0x001000
RAMGS07 : origin = 0x00C000, length = 0x008000
RAMGS8 : origin = 0x014000, length = 0x001000
RAMGS9 : origin = 0x015000, length = 0x001000
RAMGS10 : origin = 0x016000, length = 0x001000
RAMGS11 : origin = 0x017000, length = 0x001000
RAMGS12 : origin = 0x018000, length = 0x001000
RAMGS13 : origin = 0x019000, length = 0x001000
RAMGS14 : origin = 0x01A000, length = 0x001000
RAMGS15 : origin = 0x01B000, length = 0x001000
/* Shared MessageRam */
CPU2TOCPU1RAM : origin = 0x03F800, length = 0x000400
CPU1TOCPU2RAM : origin = 0x03FC00, length = 0x000400
CLA1_MSGRAMLOW : origin = 0x001480, length = 0x000080
CLA1_MSGRAMHIGH : origin = 0x001500, length = 0x000080
SECTIONS
/* Allocate program areas: */
.cinit : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
FLASHG | FLASHH | FLASHI | FLASHJ |
FLASHK | FLASHL | FLASHM | FLASHN PAGE = 0
.binit : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
#ifdef __TI_EABI__
.init_array : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
#else
.pinit : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
#endif
.text : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
codestart : > BEGIN PAGE = 0
ramfuncs : LOAD = FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
RUN = RAMGS07 PAGE = 1
LOAD_START(_RamfuncsLoadStart),
LOAD_SIZE(_RamfuncsLoadSize),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
RUN_SIZE(_RamfuncsRunSize),
RUN_END(_RamfuncsRunEnd)
#ifdef __TI_COMPILER_VERSION__
#if __TI_COMPILER_VERSION__ >= 15009000
.TI.ramfunc : {} LOAD = FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
FLASHK | FLASHL | FLASHM | FLASHN PAGE = 0,
RUN = LS14SARAM PAGE = 1,
table(BINIT)
#endif
#endif
/* Allocate uninitalized data sections: */
.stack : > M01SARAM | RAMGS07 PAGE = 1
#ifdef __TI_EABI__
.bss : > M01SARAM | LS14SARAM PAGE = 1
.sysmem : > RAMGS07 | M01SARAM PAGE = 1
#else
.ebss : > M01SARAM | LS14SARAM PAGE = 1
.esysmem : > RAMGS07 | M01SARAM PAGE = 1
#endif
.data : > M01SARAM | RAMGS07 PAGE = 1
.cio : > RAMGS07 | M01SARAM PAGE = 1
/* Initalized sections go in Flash */
#ifdef __TI_EABI__
.const : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
#else
.econst : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
#endif
.switch : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
.args : > FLASHA | FLASHB | FLASHC | FLASHD | FLASHEF |
Filter_RegsFile : > RAMGS07 | RAMGS8 | RAMGS9 |
RAMGS10 | RAMGS11 | RAMGS12 | RAMGS13 | RAMGS14 |
RAMGS15 PAGE = 1
User_RegsFile : > RAMGS07 | RAMGS8 | RAMGS9 |
RAMGS15 PAGE = 1
.Bios_Stack : > RAMGS07 | RAMGS8 | RAMGS9 |
RAMGS15 PAGE = 1
/* CLA specific sections */
#if defined(__TI_EABI__)
Cla1Prog : LOAD = FLASHD,
RUN = LS5SARAM,
LOAD_START(Cla1funcsLoadStart),
LOAD_END(Cla1funcsLoadEnd),
RUN_START(Cla1funcsRunStart),
LOAD_SIZE(Cla1funcsLoadSize),
PAGE = 0, ALIGN(8)
#else
RUN = LS5SARAM,
LOAD_START(_Cla1funcsLoadStart),
LOAD_END(_Cla1funcsLoadEnd),
RUN_START(_Cla1funcsRunStart),
LOAD_SIZE(_Cla1funcsLoadSize),
PAGE = 0, ALIGN(8)
#endif
CLADataLS0 : > LS0SARAM, PAGE = 0
CLADataLS1 : > LS0SARAM, PAGE = 0
Cla1ToCpuMsgRAM : > CLA1_MSGRAMLOW, PAGE = 1
CpuToCla1MsgRAM : > CLA1_MSGRAMHIGH, PAGE = 1
/* CLA C compiler sections */
// Must be allocated to memory the CLA has write access to
CLAscratch :
{ *.obj(CLAscratch)
. += CLA_SCRATCHPAD_SIZE;
*.obj(CLAscratch_end) } > LS0SARAM, PAGE = 0
.scratchpad : > LS0SARAM, PAGE = 0
.bss_cla : > LS0SARAM, PAGE = 0
.const_cla : LOAD = FLASHB,
RUN = LS0SARAM, PAGE = 0
RUN_START(Cla1ConstRunStart),
LOAD_START(Cla1ConstLoadStart),
LOAD_SIZE(Cla1ConstLoadSize)
/* The following section definitions are required when using the IPC API Drivers */
GROUP : > CPU1TOCPU2RAM, PAGE = 1
PUTBUFFER
PUTWRITEIDX
GETREADIDX
GROUP : > CPU2TOCPU1RAM, PAGE = 1
GETBUFFER : TYPE = DSECT
GETWRITEIDX : TYPE = DSECT
PUTREADIDX : TYPE = DSECT
Thanks & Regards
Yale
