TMS320F280025C: How to Implement control suite digital power library in TMS320F280025C
Part Number: TMS320F280025C
Other Parts Discussed in Thread: TMS320F28027, , CONTROLSUITE, C2000WARE, PMP23126, TIDM-02000, C2000WARE-DIGITALPOWER-SDK
Dear sir,
I am migrating from TMS320F28027 to TMS320F280025C, and the old program uses the control suite digital power library like "PWMDRV_PSFB : PWM Driver for Phase Shifted Full Bridge Stage" .
Please suggest implementing  procedure of the digital power library (C:\ti\controlSUITE\libs\app_libs\digital_power) in microcontroller TMS320F280025C. Where can found these libraries for TMS320F280025C? I searched these libraries in C:\ti\c2000\C2000Ware_4_02_00_00\libraries but no such library was found.
List of library are below in (C:\ti\controlSUITE\libs\app_libs\digital_power)
5.1. Controllers ..................................................................................................................... 18
5.1.1 CNTL_2P2Z : Two Pole Two Zero Controller.......................................................... 18
5.1.2 CNTL_3P3Z : Three Pole Three Zero Controller .................................................... 23
5.2. Peripheral Configuration ............................................................................................. 28
5.2.1 ADC_SOC_Cnf : ADC Configuration ..................................................................... 28
5.2.2 PWM_PSFB_PCMC_Cnf : PWM for PCMC controlled PSFB Stage ...................... 30
5.2.3 PWM_1ch_UpCntDB_ActivHIC_Cnf : ..................................................................... 31
5.3. Peripheral Drivers ........................................................................................................ 32
5.3.1 ADCDRV_1ch : ADC Driver Single Channel ........................................................... 32
5.3.2 ADCDRV_4ch : ADC Driver Four Channel ............................................................. 35
5.3.3 ADCDRV_8ch : 8 channel ADC Driver .................................................................... 38
5.3.4 PWMDRV_1ch : PWM Driver Single Channel ........................................................ 42
5.3.5 PWMDRV_1chHiRes : PWM Driver Single Channel Hi Res ................................... 48
5.3.6 PWMDRV_1chHiResUpDwnCnt : PWM Driver 1ch Hi Res Up Down Count Mode 54
5.3.7 PWMDRV_PFC2PHIL : PWM Driver for Two Phase Interleaved PFC Stage ........ 59
5.3.8 PWMDRV_PSFB : PWM Driver for Phase Shifted Full Bridge Stage ..................... 63
5.3.9 PWMDRV_ComplPairDB : PWM Driver with complementary chA & chB PWM ..... 67
5.3.10 PWMDRV_DualUpDwnCnt : Dual PWM Driver , independent Duty on chA & ChB  72
5.3.11 PWMDRV_BuckBoost : Dual PWM Driver, independent Duty on chA & chB ....... 76
5.3.12 PWMDRV_2ch_UpCnt : Dual PWM Driver, independent Duty on chA and chB .. 81
5.3.13 PWMDRV_1ch_UpDwnCnt : PWM Driver, Duty on chA centered at zero ........... 85
5.3.14 PWMDRV_1ch_UpDwnCntCompl : PWM Driver, Duty chA centered at period ... 89
5.3.15 PWMDRV_PSFB_VMC_SR : PWM Driver for VMC PSFB Stage with SR .......... 93
5.3.16 PWMDRV_LLC_ComplPairDB : PWMDriver for compl. PWM period modulation 97
5.3.17 PWMDRV_LLC_1ch_UpCntDB : PWM Driver for chA PWM edge shift, period mode . 102
5.3.18 PWMDRV_LLC_1ch_upCntDB_Compl : Driver, chA PWM, edge shift period mode .. 107
  • Hi Ajeet,
    Our Subject Matter Expert is out of office. Please expect the response by Wednesday. Thank you for your patience.
    Srikanth
  • HI Ajeet,
    Please note that we have updated our DigitalPower support for C2000. We now have and SDK named C2000Ware-DigitalPower-SDK that has our latest digitalpower support for reference designs and libraries. Note that these PWM drivers were not carried forward. However, they've been implemented as part of our reference designs. I'll recommend you check out the the PMP23126 and TIDM-02000 PSFB examples in the SDK to understand how we are implementing these PWM drivers. Note the DCL library in C2000Ware has support for the controllers.
    Ozino
