Need support to resolve above issue.
Sid C
I assume you are attempting a project debug session on an F28379D target. On multi-core targets with multiple CPUs of the same type, the debugger will typically ask you which core to load the program to:
Do you recall once seeing that prompt? You would only be asked once, then the debugger will "remember" that setting. You can try resetting this by going to "Run -> Debug Configurations" and deleting the entry for your project. Then you should get prompted again.
Please let me know if this helps resolve the issue.
ki
