No rule to make target --- error
I am working with F2808, and CCS 4.2.3.00004 - we recently merged some code, and when I did a build on merged code I received an error message:
No rule to make target '../zbb_V3_Hardware_Threads.c' needed by 'zbb_Hardware_Threads.obj'
When I renamed the file, shortening "Hardware" to "Hdwr", I still received the same mesage.
Todd Anderson
  • I managed to clean up the error.
    First, I excluded the particular file from build.
    Then, I deleted ALL contents from the project's Debug directory, including the subdirectories.
    I then worked to get an error-free compile by commenting out code that was dependent on the "excluded" file.
    After that, I included the file that had been excluded, and I was able to get back to a normal compile.
    I am still not sure why I received the "No rule to make target" error, but I am back to where I was.
    Hopefully, that helps...
    Todd Anderson
