TMDSCNCD280039C: ePWM generating a short pulse at the start
Part Number: TMDSCNCD280039C
I'm using ePWM in complimentary mode. At the start of the program, I'm getting an undesired short pulse on channel B. Below is my configuration. It is generated by sysconfig. Can you kindly see what am I doing wrong?
void EPWM_init(){
    EPWM_setClockPrescaler(GATE_HB1_BASE, EPWM_CLOCK_DIVIDER_1, EPWM_HSCLOCK_DIVIDER_1);
    EPWM_setTimeBasePeriod(GATE_HB1_BASE, 0);
    EPWM_setTimeBaseCounter(GATE_HB1_BASE, 0);
    EPWM_setTimeBaseCounterMode(GATE_HB1_BASE, EPWM_COUNTER_MODE_UP_DOWN);
    EPWM_disablePhaseShiftLoad(GATE_HB1_BASE);
    EPWM_setPhaseShift(GATE_HB1_BASE, 0);
    EPWM_setCounterCompareValue(GATE_HB1_BASE, EPWM_COUNTER_COMPARE_A, 0);
    EPWM_setCounterCompareShadowLoadMode(GATE_HB1_BASE, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setCounterCompareValue(GATE_HB1_BASE, EPWM_COUNTER_COMPARE_B, 0);
    EPWM_setCounterCompareShadowLoadMode(GATE_HB1_BASE, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
    EPWM_setActionQualifierContSWForceAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_SW_OUTPUT_LOW);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setActionQualifierContSWForceAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_SW_OUTPUT_HIGH);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
    EPWM_setActionQualifierAction(GATE_HB1_BASE, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
    EPWM_setFallingEdgeDeadBandDelayInput(GATE_HB1_BASE, EPWM_DB_INPUT_EPWMB);
    EPWM_setDeadBandDelayPolarity(GATE_HB1_BASE, EPWM_DB_FED, EPWM_DB_POLARITY_ACTIVE_LOW);
    EPWM_setDeadBandDelayMode(GATE_HB1_BASE, EPWM_DB_RED, true);
    EPWM_setDeadBandDelayMode(GATE_HB1_BASE, EPWM_DB_FED, true);
    EPWM_enableInterrupt(GATE_HB1_BASE);
    EPWM_setInterruptSource(GATE_HB1_BASE, EPWM_INT_TBCTR_D_CMPA);
    EPWM_setInterruptEventCount(GATE_HB1_BASE, 1);
    EPWM_enableInterruptEventCountInit(GATE_HB1_BASE);
    EPWM_forceInterruptEventCountInit(GATE_HB1_BASE);
