TMS320F280049C: Sync 2 EPWM modules using sysconfig
Part Number: TMS320F280049C
Other Parts Discussed in Thread: SYSCONFIG, C2000WARE
im currently writing my bachelor thesis and therefore I need to use the Board TMS320F280049C to create PWM signals to test my circuit board.
I need two different PWM signals with one serving as an enable signal. Therefore the one signal needs to have a frequency by a multiplier higher than the other one.
To configure the launchpad I used CSS in connection with sysconfig and followed the C2000 ePWM developers guide. Now everything works like I hope for, but its not possibel for me to get both signals in sync.
In order to check if I configured SYNCIN and SYNCOUT correctly I gave both signals the same frequency. It didn't work and looked like this instead:
Now I am uncertain what to do. I probably didn't implement the syncronization correctly, but I can't find the mistake.
Here are what I consider the important parts for this request of my sysconfig settings:
I hope you can help me and thank you very much for an answer in advance.
Kind regards,
Lucas Radon
