Other Parts Discussed in Thread: LAUNCHXL-F280025C
Actually i was testing a grid tied inverter with the custom board (TMS320F280025) using XDS100V2 debugger. When I test resistive load it was creating the below issue but not frequently. But when I started using the board with grid then it was continuously popping the below error in console window, after 30 secs of launching the debug session. So, I would kindly request to suggest me a solution to fix this problem. Thanks in advance.
Console Window Report:
C28xx_CPU1: Error: (Error -1044 @ 0x0) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.0.00002)
C28xx_CPU1: Trouble Halting Target CPU: (Error -1135 @ 0xA6D9) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.2.0.00002)
C28xx_CPU1: Unable to determine target status after 20 attempts
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
