Part Number: TMS320F280021
I was going through the TRM for TMS320F28002x to understand the FSI peripheral. I am unable to understand if the skew compensation is automatically done or should the delay values be manually calculated and then fed into the registers? Also, if it has to be manually calculated, should it be done after every power on/off cycle or only when the connections are changed?
Thank You,
Nikhil
