Hi Team,
There's an issue from the customer need your help:
I plan to use the TMS320F28379D development board for digital control, and use the differential sampling inside the DSP to sample the AC voltage. Now I have a problem that the positive half-cycle and negative half-cycle sampling calibration curves of the AC are inconsistent. How to deal with this?
Could you help check this case?
Thanks & Regards,
Ben
in this picture, the top is Input Voltage Sampling Calibration, the left is Output voltage analog, the right is output voltage digital.
the x and y axis are output voltage analog and output voltage digital, the Chinese doesn't matter.
