I'm using the evaluation board TMS320F28388D connected on a 180-pin docking station TMDSHSECDOCK.
Is there an example for USB Device MSC for the above mentioned baord to make it work as a device?
You can take a look at the examples provided within C2000Ware in folder <C2000Ware>driverlib\f2838x\examples\c28x\usb.
There is an example for host MSC where it reads the file system on an external flash driver connected over USB.
What is the intended application that you are using it for?
Best Regards
Siddharth
Hi Siddharth,
Thank you for your prompt reply.
I've gone through the example usb_ex7_host_msc if you are talking about the same.
In my case, I'm looking for USB Device MSC example where C28 works in a Device mode and MSC integrated in it.
Looking forward to your reply or any insight on the topic.
Shreyas
Shreyas,
There is no such example for USB Device MSC. There are examples for other device classes (CDC, HID, Bulk) which you can refer.
Best Regards
Siddharth
