Hello C2000 forum,
I migrated an existing COFF project to ELF. However, when I attempt to run it, it crashes during the initialization process. I have configured the debugger to halt at the entry point symbol (_c_int00) as indicated in the map file, and I have stepped through the assembler code. After executing the line 'LCR #__TI_auto_init' (which is marked in green), the program crashes and the debugger jumps to ESTOP0. I'm uncertain about the cause of this issue. Can anyone provide insight into what might be causing the problem?
I attached screenshots of my config.
Paul
