TMS320F28388D: IDDKv2.2.1_UserGuide.pdf
Part Number: TMS320F28388D
Other Parts Discussed in Thread: TMDXIDDK379D, , MOTORWARE, C2000WARE, CONTROLSUITE
I want to evaluate the TMS320F28388D with the TMDXIDDK379D dev kit.
I have installed C2000Ware_4_03_00_00, motorWare_1_01_00_18 and controlSUITE v3.4.9.
I am trying to follow the IDDKv2.2.1_UserGuide.pdf but I didn't find the following project:
C:\ti\c2000\C2000Ware_MotorControl_SDK_1_00_00_00\solutions\tmdxiddk379d\fcl_qep_f2837x_tmdxiddk
I found two quite similar projects:
 - C:\ti\controlSUITE\development_kits\TMDSIDDK_v2.0\IDDK_PM_Servo_F2837x_v2_00_00_00, but it has no the fcl (fast current loop) feature
 - C:\ti\controlSUITE\libs\app_libs\motor_control\libs\FCL\v02_00_00_00\Examples\IDDKv2_PM_Servo_F2837x_FCL_Example01, but it has no the Build_level_1 to check PWM
Could you tell me where I can find the appropriate project according to the IDDKv2.2.1_UserGuide.pdfplease?
Best regards
David
  • I think that guide is referring to the project in <MotorControl SDK>\solutions\tmdxiddk379d\f2837x\ccs\sensored_foc\fcl_f2837x_tmdxiddk.projectspec. We must have changed the name at some point, but it should be equivalent.
    Edit: I see you actually are using F2838x. Note there's a similar project for F2838x in solutions\tmdxiddk379d\f2838x\
    Whitney
