Part Number: TMS320F280039
Hi expert,
My customer use MCAN as normal CAN running with 500kbps.
recently they found the function need too long time to finish, I test using TI demo code.
it needs 854 clocks, about 7us. and customer is very busy on CPU loading. do you have an idea on optimizing the time?
I found the rxMsg support 64 data, if they only transmit 8 data, will it needs to dummy read the other 56 data?
if the answer is yes, can we edit the function to 8 data and speed up the function?
BR
Emma
