TMS320F280049: Adding CLA support in existing CCS project
Part Number: TMS320F280049
We have a working CCS project without using CLA on F280049 MCU. In order to increase bandwidth, we wish to add CLA functionality in the existing project. Is there a step by step process on converting an existing non-CLA CCS project to include CLA functionality?
With regards,
Vijay
  • Hello Vijay,
    I don't know of a step-by-step for this. It is a good question. A few things you will need to do:
    • Update the linker command file to include memory sections for the CLA. There are examples in C2000Ware device_support/<device>common/cmd
    • Update the initialization to enable the CLA, and give memory ownership to the CLA.
    • Decide what part of your code you want to move to a CLA Task. The CLA does best as a floating-point helper to the main CPU.
    • Decide on, and setup, the trigger(s) for your cla task(s)
    • Create a shared .h file - our examples do this - with shared header file information. Shared globals should be defined in the .c file (not .cla).
    You may find https://software-dl.ti.com/C2000/docs/cla_software_dev_guide/index.html helpful. I would suggest starting out with a blank CLA project and test out your code first, then integrate it into your other project.
    Lori
  • Hello Lori,
    Thanks for your help. We will follow the steps you suggested and refer the related online documentation on the subject for additional information and details.
    With regards,
    Vijay
