Part Number: TMS320F28067
How to upload the program in TMS320F28067 Microcontroller permanently(Non-Volatile Memory) using code composer studio instead of Debug Mode.
Hello Devershi,
You will need to modify your linker command file so that the program is allocated to Flash instead of RAM. You can look at an example like Example_2806xFlash provided in C2000Ware to see how to do this specifically (C2000Ware_5_00_00_00\device_support\f2806x\examples\c28\flash_f28069).
Omer Amir
