TMS320F280037C: Open loop control not working (Universal Motor Control lab, DMC_BUILDLEVEL = 2)
Part Number: TMS320F280037C
Other Parts Discussed in Thread: LAUNCHXL-F280049C, BOOSTXL-DRV8320RS
I am trying to verify proper current sensing and gate driving.
I have already verified the ADC is measuring the current it is receiving, which is to say on a resistive load if the shunt sees 1 ampere, the F280037C sees feedback from an opamp that correlates to 1 amp.
I have verified the offset calibration stage, so it centers the current on zero (though it is a bit noisy, +/- 0.4 A, seems to be buck converter switching noise).
I have verified the PWMs are switching to precisely what is commanded with 'HAL_writePWMData', and I have configured the dead band on the gates to be a bit longer than the sum of the on/off switch times for the MOSFETs.
I have verified the motor on an evaluation kit (LAUNCHXL-F280049C) to use open loop control, and it spins slowly and quietly. I exported the motor variables identified by the InstaSPIN lab to the Universal Motor Control lab parameters, especially the open loop control variables:
#define USER_MOTOR_FREQ_MIN_HZ (10.0) // Hz
#define USER_MOTOR_FREQ_MAX_HZ (500.0) // Hz
#define USER_MOTOR_FREQ_LOW_HZ (20.0) // Hz
#define USER_MOTOR_FREQ_HIGH_HZ (450.0) // Hz
#define USER_MOTOR_VOLT_MIN_V (2.0) // Volt
#define USER_MOTOR_VOLT_MAX_V (24.0) // Volt
Setting the system to build level 2, I am expecting the system to behave similarly, yet the motor screeches loudly, jitters/rotates a bit, then the system throws an overcurrent fault and halts.
Yesterday I set up the datalog to get a better look at the system. (edit: clarified) The datalog seems to be correctly displaying the ADC readings, but possibly not the open loop angle generator..
From my custom board (this is with the motor sitting still, flag to run set to 0, since it will not spin)
Top left: phase A current feedback.
Top right: phase B current feedback.
Bottom left: phase C current feedback.
Bottom right: angleGen_rad
The angle generator graph looks like garbage, except it is correctly within the bounds of -pi to +pi
Compared to the evaluation kit (similar setup, flag to run set to 0 to compare):
What could be going on?
How do I get my motor spinning on my board?
  • Hey, I am still stuck on this issue. Trying to figure out how the 'vs_freq' system works. Documentation appears to be just comments only. So far the issue still seems to be that pure noise phase angle generator. The 'freq' variable also is jumping between 0 and 600, seemingly at random:
    edit: code for changing 'freq' is here, called 'speed_int_Hz', and passed to the ANGLE_GEN_run() method to change 'freq'
    edit again: I am using 'MOTOR1_FAST' sensorless-FOC mode
    motor1_drive.c
    // $Copyright:
    // Copyright (C) 2017-2023 Texas Instruments Incorporated - http://www.ti.com/
    // Redistribution and use in source and binary forms, with or without
    // modification, are permitted provided that the following conditions
    // are met:
    //   Redistributions of source code must retain the above copyright
    //   notice, this list of conditions and the following disclaimer.
    //   Redistributions in binary form must reproduce the above copyright
    //   notice, this list of conditions and the following disclaimer in the
    //   documentation and/or other materials provided with the
    //   distribution.
    //   Neither the name of Texas Instruments Incorporated nor the names of
    //   its contributors may be used to endorse or promote products derived
    //   from this software without specific prior written permission.
    // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    //! \file   /solutions/universal_motorcontrol_lab/common/source/motor1_drive.c
    //! \brief  This project is used to implement motor control with FAST, eSMO
    //!         Encoder, and Hall sensors based sensored/sensorless-FOC.
    //!         Supports multiple TI EVM boards
    // include the related header files
    #include "sys_settings.h"
    #include "sys_main.h"
    #include "motor1_drive.h"
    #pragma CODE_SECTION(motor1CtrlISR, ".TI.ramfunc");
    #pragma INTERRUPT(motor1CtrlISR, {HP});
    // the globals
    //!< the hardware abstraction layer object to motor control
    volatile MOTOR_Handle motorHandle_M1;
    #pragma DATA_SECTION(motorHandle_M1,"foc_data");
    volatile MOTOR_Vars_t motorVars_M1;
    #pragma DATA_SECTION(motorVars_M1, "foc_data");
    MOTOR_SetVars_t motorSetVars_M1;
    #pragma DATA_SECTION(motorSetVars_M1, "foc_data");
    HAL_MTR_Obj    halMtr_M1;
    #pragma DATA_SECTION(halMtr_M1, "foc_data");
    #if defined(MOTOR1_FAST)
    //!< the voltage Clarke transform object
    CLARKE_Obj    clarke_V_M1;
    #pragma DATA_SECTION(clarke_V_M1, "foc_data");
    #endif  // MOTOR1_FAST
    //!< the current Clarke transform object
    CLARKE_Obj    clarke_I_M1;
    #pragma DATA_SECTION(clarke_I_M1, "foc_data");
    //!< the inverse Park transform object
    IPARK_Obj     ipark_V_M1;
    #pragma DATA_SECTION(ipark_V_M1, "foc_data");
    //!< the Park transform object
    PARK_Obj      park_I_M1;
    #pragma DATA_SECTION(park_I_M1, "foc_data");
    PARK_Obj      park_V_M1;
    #pragma DATA_SECTION(park_V_M1, "foc_data");
    //!< the Id PI controller object
    PI_Obj        pi_Id_M1;
    #pragma DATA_SECTION(pi_Id_M1, "foc_data");
    //!< the Iq PI controller object
    PI_Obj        pi_Iq_M1;
    #pragma DATA_SECTION(pi_Iq_M1, "foc_data");
    //!< the speed PI controller object
    PI_Obj        pi_spd_M1;
    #pragma DATA_SECTION(pi_spd_M1, "foc_data");
    //!< the space vector generator object
    SVGEN_Obj     svgen_M1;
    #pragma DATA_SECTION(svgen_M1, "foc_data");
    #if defined(MOTOR1_OVM)
    //!< the handle for the space vector generator current
    SVGENCURRENT_Obj svgencurrent_M1;
    #pragma DATA_SECTION(svgencurrent_M1, "foc_data");
    #endif  // MOTOR1_OVM
    //!< the speed reference trajectory object
    TRAJ_Obj     traj_spd_M1;
    #pragma DATA_SECTION(traj_spd_M1, "foc_data");
    #if defined(MOTOR1_FWC)
    //!< the fwc PI controller object
    PI_Obj       pi_fwc_M1;
    #pragma DATA_SECTION(pi_fwc_M1, "foc_data");
    #endif  // MOTOR1_FWC
    #if defined(MOTOR1_ISBLDC)
    //!< the isbldc object
    ISBLDC_Obj isbldc_M1;
    #pragma DATA_SECTION(isbldc_M1, "foc_data");
    //!< the rimpulse object
    RIMPULSE_Obj rimpulse_M1;
    #pragma DATA_SECTION(rimpulse_M1, "foc_data");
    //!< the mod6cnt object
    MOD6CNT_Obj mod6cnt_M1;
    #pragma DATA_SECTION(mod6cnt_M1, "foc_data");
    //!< the bldc object
    BLDC_Obj bldc_M1;
    #pragma DATA_SECTION(bldc_M1, "foc_data");
    #else // !MOTOR1_ISBLDC
    #if (DMC_BUILDLEVEL <= DMC_LEVEL_3) || defined(MOTOR1_VOLRECT) || \
                   defined(MOTOR1_ESMO) || defined(MOTOR1_ENC)
    //!< the Angle Generate onject for open loop control
    ANGLE_GEN_Obj    angleGen_M1;
    #pragma DATA_SECTION(angleGen_M1, "foc_data");
    #endif  // DMC_BUILDLEVEL <= DMC_LEVEL_3 || MOTOR1_ESMO || MOTOR1_ENC || MOTOR1_VOLRECT
    #if(DMC_BUILDLEVEL == DMC_LEVEL_2)
    //!< the Vs per Freq object for open loop control
    VS_FREQ_Obj    VsFreq_M1;
    #pragma DATA_SECTION(VsFreq_M1, "foc_data");
    #endif // (DMC_BUILDLEVEL == DMC_LEVEL_2)
    #endif  // !MOTOR1_ISBLDC
    #if defined(MOTOR1_ENC)
    //!< the handle for the enc object
    ENC_Obj enc_M1;
    #pragma DATA_SECTION(enc_M1, "foc_data");
    //!< the handle for the speedcalc object
    SPDCALC_Obj speedcalc_M1;
    #pragma DATA_SECTION(speedcalc_M1, "foc_data");
    #endif  // MOTOR1_ENC
    #if defined(MOTOR1_HALL)
    HALL_Obj hall_M1;
    #pragma DATA_SECTION(hall_M1, "foc_data");
    // Enable MOTOR1_HALL_CAL pre-defined symbols, run the motor with FAST for angle
    // calibration
    // Copy hall_M1.thetaCalBuf[] to hallAngleBuf[]
    // 1->1, 2->2, 3->3, 4->4, 5->5, 6->6, 6->0
    // Disable MOTOR1_HALL_CAL pre-defined symbols after calibration for normal operation
                                        // 6           1              2
                                        // 3           4              5
                                        // 6
    #if (USER_MOTOR1 == Teknic_M2310PLN04K)
    const float32_t hallAngleBuf[7] = { 2.60931063f,  -0.45987016f, -2.57219672f, \
                                        -1.50797582f, 1.59862518f , 0.580176473f,
                                        2.60931063f };
    #elif (USER_MOTOR1 == Anaheim_BLY172S_24V)
    const float32_t hallAngleBuf[7] = { -1.41421735f,  1.75656128f, -2.48391223f, \
                                        2.76515913f,  -0.460148782f, 0.606459916f,
                                        -1.41421735f };
    #elif (USER_MOTOR1 == Anaheim_BLWS235D)
    const float32_t hallAngleBuf[7] = { 1.64448488f,  -1.54361129f,  0.548367858f, \
                                       -0.390248626f,  2.67842388f, -2.52673817f,
                                        1.64448488f };
    #elif (USER_MOTOR1 == Tool_Makita_GFD01)
    const float32_t hallAngleBuf[7] = { -2.71645141f,  0.399317622f, 2.47442961f,  \
                                        1.47019732f, -1.67825437f, -0.643157125f, \
                                        -2.71645141f };
    #else   // !Teknic_M2310PLN04K | !Anaheim_BLY172S_24V | !Anaheim_BLWS235D | !Tool_Makita_GFD01
    #error Not a right hall angle buffer for this project, need to do hall calibration
    #endif  //
    #endif  // MOTOR1_HALL
    #if defined(MOTOR1_ESMO)
    //!< the speedfr object
    SPDFR_Obj spdfr_M1;
    #pragma DATA_SECTION(spdfr_M1, "foc_data");
    //!< the esmo object
    ESMO_Obj   esmo_M1;
    #pragma DATA_SECTION(esmo_M1, "foc_data");
    #endif  // MOTOR1_ESMO
    #if defined(MOTOR1_MTPA)
    //!< the Maximum torque per ampere (MTPA) object
    MTPA_Obj     mtpa_M1;
    #pragma DATA_SECTION(mtpa_M1, "foc_data");
    #endif  // MOTOR1_MTPA
    #if defined(MOTOR1_DCLINKSS)
    //!< the single-shunt current reconstruction object
    DCLINK_SS_Obj    dclink_M1;
    #pragma DATA_SECTION(dclink_M1, "foc_data");
    #endif // MOTOR1_DCLINKSS
    #if defined(MOTOR1_VOLRECT)
    //!< the voltage reconstruct object
    VOLREC_Obj volrec_M1;
    #pragma DATA_SECTION(volrec_M1, "foc_data");
    #endif  // MOTOR1_VOLRECT
    #if defined(MOTOR1_FILTERIS)
    //!< first order current filter object
    FILTER_FO_Obj    filterIs_M1[3];
    #pragma DATA_SECTION(filterIs_M1, "foc_data");
    #endif  // MOTOR1_FILTERIS
    #if defined(MOTOR1_FILTERVS)
    //!< first order voltage filter object
    FILTER_FO_Obj    filterVs_M1[3];
    #pragma DATA_SECTION(filterVs_M1, "foc_data");
    #endif  // MOTOR1_FILTERVS
    #if defined(BSXL8316RT_REVA) && defined(OFFSET_CORRECTION)
    MATH_Vec3 I_correct_A;
    #pragma DATA_SECTION(I_correct_A, "foc_data");
    #endif  // BSXL8316RT_REVA & OFFSET_CORRECTION
    #if defined(BENCHMARK_TEST)
    BMTEST_Vars_t bmarkTestVars;
    #pragma DATA_SECTION(bmarkTestVars, "foc_data");
    #endif  // BENCHMARK_TEST
    // ARIC CODE some volatiles to add to watch expression
    volatile uint32_t build_level = 16;
    volatile float IU_OFFSET_SF_MAX = 1.0f;
    volatile float IU_OFFSET_SF_MIN = 1.0f;
    volatile float IV_OFFSET_SF_MAX = 1.0f;
    volatile float IV_OFFSET_SF_MIN = 1.0f;
    volatile float IW_OFFSET_SF_MAX = 1.0f;
    volatile float IW_OFFSET_SF_MIN = 1.0f;
    volatile float VU_OFFSET_SF_MIN = 1.0f;
    volatile float VU_OFFSET_SF_MAX = 1.0f;
    volatile float VV_OFFSET_SF_MIN = 1.0f;
    volatile float VV_OFFSET_SF_MAX = 1.0f;
    volatile float VW_OFFSET_SF_MIN = 1.0f;
    volatile float VW_OFFSET_SF_MAX = 1.0f;
    //volatile uint32_t build_level = 16;
    //build_level = DMC_BUILDLEVEL;
    // the control handles for motor 1
    void initMotor1Handles(MOTOR_Handle handle)
        MOTOR_Vars_t *obj = (MOTOR_Vars_t *)handle;
        obj->motorNum = MTR_1;
        // initialize the driver
        obj->halMtrHandle = HAL_MTR1_init(&halMtr_M1, sizeof(halMtr_M1));
        obj->motorSetsHandle = &motorSetVars_M1;
        obj->userParamsHandle = &userParams_M1;
        return;
    // initialize control parameters for motor 1
    void initMotor1CtrlParameters(MOTOR_Handle handle)
        MOTOR_SetVars_t *objSets = (MOTOR_SetVars_t *)(handle->motorSetsHandle);
        USER_Params *objUser = (USER_Params *)(handle->userParamsHandle);
        // initialize the user parameters
        USER_setParams_priv(obj->userParamsHandle);
        USER_setMotor1Params(obj->userParamsHandle);
        // set the driver parameters
        HAL_MTR_setParams(obj->halMtrHandle, obj->userParamsHandle);
        objSets->Kp_spd = 0.05f;
        objSets->Ki_spd = 0.005f;
        objSets->Kp_fwc = USER_M1_FWC_KP;
        objSets->Ki_fwc = USER_M1_FWC_KI;
        objSets->angleFWCMax_rad = USER_M1_FWC_MAX_ANGLE_RAD;
        objSets->overModulation = USER_M1_MAX_VS_MAG_PU;
        objSets->RsOnLineCurrent_A = 0.1f * USER_MOTOR1_MAX_CURRENT_A;
        objSets->lostPhaseSet_A = USER_M1_LOST_PHASE_CURRENT_A;
        objSets->unbalanceRatioSet = USER_M1_UNBALANCE_RATIO;
        objSets->overLoadSet_W = USER_M1_OVER_LOAD_POWER_W;
        objSets->toqueFailMinSet_Nm = USER_M1_TORQUE_FAILED_SET;
        objSets->speedFailMaxSet_Hz = USER_M1_FAIL_SPEED_MAX_HZ;
        objSets->speedFailMinSet_Hz = USER_M1_FAIL_SPEED_MIN_HZ;
        objSets->stallCurrentSet_A = USER_M1_STALL_CURRENT_A;
        objSets->IsFailedChekSet_A = USER_M1_FAULT_CHECK_CURRENT_A;
        objSets->maxPeakCurrent_A = USER_M1_ADC_FULL_SCALE_CURRENT_A * 0.475f;
        objSets->overCurrent_A = USER_MOTOR1_OVER_CURRENT_A;
        objSets->currentInv_sf = USER_M1_CURRENT_INV_SF;
        objSets->overVoltageFault_V = USER_M1_OVER_VOLTAGE_FAULT_V;
        objSets->overVoltageNorm_V = USER_M1_OVER_VOLTAGE_NORM_V;
        objSets->underVoltageFault_V = USER_M1_UNDER_VOLTAGE_FAULT_V;
        objSets->underVoltageNorm_V = USER_M1_UNDER_VOLTAGE_NORM_V;
        objSets->overCurrentTimesSet = USER_M1_OVER_CURRENT_TIMES_SET;
        objSets->voltageFaultTimeSet = USER_M1_VOLTAGE_FAULT_TIME_SET;
        objSets->motorStallTimeSet = USER_M1_STALL_TIME_SET;
        objSets->startupFailTimeSet = USER_M1_STARTUP_FAIL_TIME_SET;
        objSets->overSpeedTimeSet = USER_M1_OVER_SPEED_TIME_SET;
        objSets->overLoadTimeSet = USER_M1_OVER_LOAD_TIME_SET;
        objSets->unbalanceTimeSet = USER_M1_UNBALANCE_TIME_SET;
        objSets->lostPhaseTimeSet = USER_M1_LOST_PHASE_TIME_SET;
        objSets->stopWaitTimeSet = USER_M1_STOP_WAIT_TIME_SET;
        objSets->restartWaitTimeSet = USER_M1_RESTART_WAIT_TIME_SET;
        objSets->restartTimesSet = USER_M1_START_TIMES_SET;
        objSets->dacCMPValH = 2048U + 1024U;    // set default positive peak value
        objSets->dacCMPValL = 2048U - 1024U;    // set default negative peak value
        obj->adcData.current_sf = objUser->current_sf * USER_M1_SIGN_CURRENT_SF;
    #if defined(POWERHEAD)
        obj->adcData.interlock_sf = objUser->interlock_sf;
    #endif
        obj->adcData.voltage_sf = objUser->voltage_sf;
        obj->adcData.dcBusvoltage_sf = objUser->voltage_sf;
        obj->speedStart_Hz = USER_MOTOR1_SPEED_START_Hz;
        obj->speedForce_Hz = USER_MOTOR1_SPEED_FORCE_Hz;
        obj->speedFlyingStart_Hz = USER_MOTOR1_SPEED_FS_Hz;
        obj->accelerationMax_Hzps = USER_MOTOR1_ACCEL_MAX_Hzps;
        obj->accelerationStart_Hzps = USER_MOTOR1_ACCEL_START_Hzps;
        obj->VsRef_pu = 0.98f * USER_M1_MAX_VS_MAG_PU;
        obj->VsRef_V =
                0.98f * USER_M1_MAX_VS_MAG_PU * USER_M1_NOMINAL_DC_BUS_VOLTAGE_V;
        obj->IsSet_A = USER_MOTOR1_TORQUE_CURRENT_A;
        obj->fluxCurrent_A = USER_MOTOR1_FLUX_CURRENT_A;
        obj->alignCurrent_A = USER_MOTOR1_ALIGN_CURRENT_A;
        obj->startCurrent_A = USER_MOTOR1_STARTUP_CURRENT_A;
        obj->maxCurrent_A = USER_MOTOR1_MAX_CURRENT_A;
        obj->angleDelayed_sf = 0.5f * MATH_TWO_PI * USER_M1_CTRL_PERIOD_sec;
        obj->anglePhaseAdj_rad = MATH_PI * 0.001f;
        obj->power_sf = MATH_TWO_PI / USER_MOTOR1_NUM_POLE_PAIRS;
        obj->VIrmsIsrScale = objUser->ctrlFreq_Hz;
        obj->stopWaitTimeCnt = 0;
        obj->flagEnableRestart = false;
        obj->faultMtrMask.all = MTR1_FAULT_MASK_SET;
        obj->operateMode = OPERATE_MODE_SPEED;
        obj->flyingStartTimeDelay = (uint16_t)(objUser->ctrlFreq_Hz * 0.5f); // 0.5s
        obj->flyingStartMode = FLYINGSTART_MODE_HALT;
        if(objUser->flag_bypassMotorId == true)
            obj->svmMode = SVM_COM_C;
    #else  // !(MOTOR1_DCLINKSS)
            obj->svmMode = SVM_MIN_C;
    #endif  // !(MOTOR1_DCLINKSS)
            obj->flagEnableFWC = true;
        else
            obj->flagEnableFWC = false;
        obj->flagEnableForceAngle = true;
        // true - enables flying start, false - disables flying start
        obj->flagEnableFlyingStart = true;
        // true - enables SSIPD start, false - disables SSIPD
        obj->flagEnableSSIPD = false;
        obj->flagEnableSpeedCtrl = true;
        obj->flagEnableCurrentCtrl = true;
        obj->IsSet_A = 0.0f;
        obj->alignTimeDelay = (uint16_t)(objUser->ctrlFreq_Hz * 2.0f);      // 2.0s
        obj->forceRunTimeDelay = (uint16_t)(objUser->ctrlFreq_Hz * 1.0f);   // 1.0s
        obj->startupTimeDelay = (uint16_t)(objUser->ctrlFreq_Hz * 2.0f);    // 2.0s
        obj->estimatorMode = ESTIMATOR_MODE_BINT;
        obj->flagEnableAlignment = true;
    #elif defined(MOTOR1_FAST) && defined(MOTOR1_ENC)
        obj->estState = EST_STATE_IDLE;
        obj->trajState = EST_TRAJ_STATE_IDLE;
        obj->estimatorMode = ESTIMATOR_MODE_FAST;
    #elif defined(MOTOR1_FAST) && defined(MOTOR1_ESMO)
    #elif defined(MOTOR1_FAST) && defined(MOTOR1_HALL)
    //    obj->estimatorMode = ESTIMATOR_MODE_FAST;
        obj->estimatorMode = ESTIMATOR_MODE_HALL;
        obj->flagEnableAlignment = false;
        obj->alignTimeDelay = (uint16_t)(objUser->ctrlFreq_Hz * 0.1f);      // 0.1s
    #elif defined(MOTOR1_ESMO)
        obj->estimatorMode = ESTIMATOR_MODE_ESMO;
    #elif defined(MOTOR1_ENC)
        obj->estimatorMode = ESTIMATOR_MODE_ENC;
    #elif defined(MOTOR1_HALL)
    #else   // Not select algorithm
    #error Not select a right estimator for this project
        obj->speed_int_Hz = 0.0f;
        obj->speed_Hz = 0.0f;
        obj->speedAbs_Hz = 0.0f;
        obj->speedFilter_Hz = 0.0f;
        obj->piHandle_fwc = PI_init(&pi_fwc_M1, sizeof(pi_fwc_M1));
        // set the FWC controller
        PI_setGains(obj->piHandle_fwc, USER_M1_FWC_KP, USER_M1_FWC_KI);
        PI_setUi(obj->piHandle_fwc, 0.0);
        PI_setMinMax(obj->piHandle_fwc, USER_M1_FWC_MAX_ANGLE_RAD,
                     USER_M1_FWC_MIN_ANGLE_RAD);
    #ifdef MOTOR1_MTPA
        // initialize the Maximum torque per ampere (MTPA)
        obj->mtpaHandle = MTPA_init(&mtpa_M1, sizeof(mtpa_M1));
        // compute the motor constant for MTPA
        MTPA_computeParameters(obj->mtpaHandle,
                               objUser->motor_Ls_d_H,
                               objUser->motor_Ls_q_H,
                               objUser->motor_ratedFlux_Wb);
        obj->dclinkHandle = DCLINK_SS_init(&dclink_M1, sizeof(dclink_M1));
        DCLINK_SS_setInitialConditions(obj->dclinkHandle,
                                       HAL_getTimeBasePeriod(obj->halMtrHandle), 0.5f);
        //disable full sampling
    //    DCLINK_SS_setFlag_enableFullSampling(obj->dclinkHandle, false);     // default
        DCLINK_SS_setFlag_enableFullSampling(obj->dclinkHandle, true);    // test, not recommend in most cases
        //enable sequence control
    //    DCLINK_SS_setFlag_enableSequenceControl(obj->dclinkHandle, false);  // default
        DCLINK_SS_setFlag_enableSequenceControl(obj->dclinkHandle, true); // test, not recommend in most cases
        // Tdt  =  55 ns (Dead-time between top and bottom switch)
        // Tpd  = 140 ns (Gate driver propagation delay)
        // Tr   = 136 ns (Rise time of amplifier including power switches turn on time)
        // Ts   = 800 ns (Settling time of amplifier)
        // Ts&h = 100 ns (ADC sample&holder = 1+(9)+2 = 12 SYSCLK)
        // T_MinAVDuration = Tdt+Tr+Tpd+Ts+Ts&h
        //                 = 55+140+136+800+100 = 1231(ns) => 148 SYSCLK cycles
        // T_SampleDelay   = Tdt+Tpd+Tr+Ts
        //                 = 55+140+136+800     = 1131(ns) => 136 SYSCLK cycles
        DCLINK_SS_setMinAVDuration(obj->dclinkHandle, USER_M1_DCLINKSS_MIN_DURATION);
        DCLINK_SS_setSampleDelay(obj->dclinkHandle, USER_M1_DCLINKSS_SAMPLE_DELAY);
    #ifdef MOTOR1_VOLRECT
        // initialize the Voltage reconstruction
        obj->volrecHandle = VOLREC_init(&volrec_M1, sizeof(volrec_M1));
        // configure the Voltage reconstruction
        VOLREC_setParams(obj->volrecHandle,
                         objUser->voltageFilterPole_rps,
                         objUser->ctrlFreq_Hz);
        VOLREC_disableFlagEnableSf(obj->volrecHandle);
        // initialize the esmo
        obj->esmoHandle = ESMO_init(&esmo_M1, sizeof(esmo_M1));
        // set parameters for ESMO controller
        ESMO_setKslideParams(obj->esmoHandle,
                             USER_MOTOR1_KSLIDE_MAX, USER_MOTOR1_KSLIDE_MIN);
        ESMO_setPLLParams(obj->esmoHandle, USER_MOTOR1_PLL_KP_MAX,
                          USER_MOTOR1_PLL_KP_MIN, USER_MOTOR1_PLL_KP_SF);
        ESMO_setPLLKi(obj->esmoHandle, USER_MOTOR1_PLL_KI);   // Optional
        ESMO_setBEMFThreshold(obj->esmoHandle, USER_MOTOR1_BEMF_THRESHOLD);
        ESMO_setOffsetCoef(obj->esmoHandle, USER_MOTOR1_THETA_OFFSET_SF);
        ESMO_setBEMFKslfFreq(obj->esmoHandle, USER_MOTOR1_BEMF_KSLF_FC_SF);
        ESMO_setSpeedFilterFreq(obj->esmoHandle, USER_MOTOR1_SPEED_LPF_FC_Hz);
        // set the ESMO controller parameters
        ESMO_setParams(obj->esmoHandle, obj->userParamsHandle);
        // initialize the spdfr
        obj->spdfrHandle = SPDFR_init(&spdfr_M1, sizeof(spdfr_M1));
        // set the spdfr parameters
        SPDFR_setParams(obj->spdfrHandle, obj->userParamsHandle);
        obj->frswPos_sf = 0.6f;
    #endif  //MOTOR1_ESMO
        // initialize the ISBLDC handle
        obj->isbldcHandle = ISBLDC_init(&isbldc_M1, sizeof(isbldc_M1));
        // set the ISBLDC controller parameters
        ISBLDC_setParams(obj->isbldcHandle, obj->userParamsHandle,
                         USER_MOTOR1_ISBLDC_INT_MAX, USER_MOTOR1_ISBLDC_INT_MIN);
        // initialize the RIMPULSE handle
        obj->rimpulseHandle = RIMPULSE_init(&rimpulse_M1, sizeof(rimpulse_M1));
        // set the RIMPULSE controller parameters
        RIMPULSE_setParams(obj->rimpulseHandle, obj->userParamsHandle,
                           USER_MOTOR1_RAMP_START_Hz, USER_MOTOR1_RAMP_END_Hz,
                           USER_MOTOR1_RAMP_DELAY);
        // initialize the MOD6CNT handle
        obj->mod6cntHandle = MOD6CNT_init(&mod6cnt_M1, sizeof(mod6cnt_M1));
        // sets up the MOD6CNT controller parameters
        MOD6CNT_setMaximumCount(obj->mod6cntHandle, 6);
        // initialize the BLDC handle
        obj->bldcHandle = &bldc_M1;
        // sets up initialization value for startup
        obj->bldcHandle->IdcRefSet = 1.0f;           // 1.0A
        obj->bldcHandle->IdcStart = USER_MOTOR1_ISBLDC_I_START_A;       // 0.5A
    #if (DMC_BUILDLEVEL == DMC_LEVEL_2)
        obj->bldcHandle->pwmDutySet = 0.10f;         // 10% duty
        obj->bldcHandle->pwmDutyStart = USER_MOTOR1_ISBLDC_DUTY_START;  // 10% duty
    #endif  // DMC_LEVEL_2
        obj->bldcHandle->commSampleDelay = 3;
        // initialize the angle generate module
        obj->angleGenHandle = ANGLE_GEN_init(&angleGen_M1, sizeof(angleGen_M1));
        ANGLE_GEN_setParams(obj->angleGenHandle, objUser->ctrlPeriod_sec);
    #endif  // DMC_BUILDLEVEL <= DMC_LEVEL_3 || MOTOR1_ESMO || MOTOR1_VOLRECT || MOTOR1_ENC
    #if(DMC_BUILDLEVEL <= DMC_LEVEL_3)
        obj->Idq_set_A.value[0] = 0.0f;
        obj->Idq_set_A.value[1] = obj->startCurrent_A;
    #endif // (DMC_BUILDLEVEL == DMC_LEVEL_3)
        // initialize the Vs per Freq module
        obj->VsFreqHandle = VS_FREQ_init(&VsFreq_M1, sizeof(VsFreq_M1));
        VS_FREQ_setVsMagPu(obj->VsFreqHandle, objUser->maxVsMag_pu);
        VS_FREQ_setMaxFreq(obj->VsFreqHandle, USER_MOTOR1_FREQ_MAX_Hz);
        VS_FREQ_setProfile(obj->VsFreqHandle,
                           USER_MOTOR1_FREQ_LOW_Hz, USER_MOTOR1_FREQ_HIGH_Hz,
                           USER_MOTOR1_VOLT_MIN_V, USER_MOTOR1_VOLT_MAX_V);
        // initialize the hall handle
        obj->hallHandle = HALL_init(&hall_M1, sizeof(hall_M1));
        // set the HALL controller parameters
        HALL_setParams(obj->hallHandle, obj->userParamsHandle);
        HALL_setAngleBuf(obj->hallHandle, &hallAngleBuf[0]);
        HALL_setAngleDelta_rad(obj->hallHandle, USER_MOTOR1_HALL_DELTA_rad);
        HALL_setGPIOs(obj->hallHandle,
                      MTR1_HALL_U_GPIO, MTR1_HALL_V_GPIO, MTR1_HALL_W_GPIO);
        obj->frswPos_sf = 1.0f;     // Tune this coefficient per the motor/system
        // initialize the Clarke modules
        obj->clarkeHandle_V = CLARKE_init(&clarke_V_M1, sizeof(clarke_V_M1));
        // set the Clarke parameters
        setupClarke_V(obj->clarkeHandle_V, objUser->numVoltageSensors);
        obj->clarkeHandle_I = CLARKE_init(&clarke_I_M1, sizeof(clarke_I_M1));
        setupClarke_I(obj->clarkeHandle_I, objUser->numCurrentSensors);
        // initialize the inverse Park module
        obj->iparkHandle_V = IPARK_init(&ipark_V_M1, sizeof(ipark_V_M1));
        // initialize the Park module
        obj->parkHandle_I = PARK_init(&park_I_M1, sizeof(park_I_M1));
        obj->parkHandle_V = PARK_init(&park_V_M1, sizeof(park_V_M1));
        // initialize the PI controllers
        obj->piHandle_Id  = PI_init(&pi_Id_M1, sizeof(pi_Id_M1));
        obj->piHandle_Iq  = PI_init(&pi_Iq_M1, sizeof(pi_Iq_M1));
        obj->piHandle_spd = PI_init(&pi_spd_M1, sizeof(pi_spd_M1));
        // initialize the speed reference trajectory
        obj->trajHandle_spd = TRAJ_init(&traj_spd_M1, sizeof(traj_spd_M1));
        // configure the speed reference trajectory (Hz)
        TRAJ_setTargetValue(obj->trajHandle_spd, 0.0f);
        TRAJ_setIntValue(obj->trajHandle_spd, 0.0f);
        TRAJ_setMinValue(obj->trajHandle_spd, -objUser->maxFrequency_Hz);
        TRAJ_setMaxValue(obj->trajHandle_spd, objUser->maxFrequency_Hz);
        TRAJ_setMaxDelta(obj->trajHandle_spd, (objUser->maxAccel_Hzps * objUser->ctrlPeriod_sec));
        // initialize the space vector generator module
        obj->svgenHandle = SVGEN_init(&svgen_M1, sizeof(svgen_M1));
    #if !defined(MOTOR1_ISBLDC)
        SVGEN_setMode(obj->svgenHandle, SVM_COM_C);
    #endif  //! MOTOR1_ISBLDC
    #if !defined(MOTOR1_DCLINKSS)   // 2/3-shunt
        HAL_setTriggerPrams(&obj->pwmData, USER_SYSTEM_FREQ_MHz,
                            0.01f, 0.01f, 0.14f);
    #else   // MOTOR1_DCLINKSS
                            0.0f, 0.0f, 0.0f);
        obj->flagEnableFilterIs = true;
        // assign the current filter handle (low pass filter)
        obj->filterHandle_Is[0] = FILTER_FO_init((void *)(&filterIs_M1[0]), sizeof(FILTER_FO_Obj));
        obj->filterHandle_Is[1] = FILTER_FO_init((void *)(&filterIs_M1[1]), sizeof(FILTER_FO_Obj));
        obj->filterHandle_Is[2] = FILTER_FO_init((void *)(&filterIs_M1[2]), sizeof(FILTER_FO_Obj));
        obj->filterIsPole_rps = USER_M1_IS_FILTER_POLE_rps;     //
        float32_t beta_lp_Is = obj->filterIsPole_rps * objUser->ctrlPeriod_sec;
        float32_t a1_Is = (beta_lp_Is - (float32_t)2.0f) / (beta_lp_Is + (float32_t)2.0f);
        float32_t b0_Is = beta_lp_Is / (beta_lp_Is + (float32_t)2.0f);
        float32_t b1_Is = b0_Is;
        // set filter coefficients for current filters (low pass filter)
        FILTER_FO_setNumCoeffs(obj->filterHandle_Is[0], b0_Is, b1_Is);
        FILTER_FO_setDenCoeffs(obj->filterHandle_Is[0], a1_Is);
        FILTER_FO_setInitialConditions(obj->filterHandle_Is[0], 0.0f, 0.0f);
        FILTER_FO_setNumCoeffs(obj->filterHandle_Is[1], b0_Is, b1_Is);
        FILTER_FO_setDenCoeffs(obj->filterHandle_Is[1], a1_Is);
        FILTER_FO_setInitialConditions(obj->filterHandle_Is[1], 0.0f, 0.0f);
        FILTER_FO_setNumCoeffs(obj->filterHandle_Is[2], b0_Is, b1_Is);
        FILTER_FO_setDenCoeffs(obj->filterHandle_Is[2], a1_Is);
        FILTER_FO_setInitialConditions(obj->filterHandle_Is[2], 0.0f, 0.0f);
        obj->flagEnableFilterVs = true;
        // assign the voltage filter handle (low pass filter)
        obj->filterHandle_Vs[0] = FILTER_FO_init((void *)(&filterVs_M1[0]), sizeof(FILTER_FO_Obj));
        obj->filterHandle_Vs[1] = FILTER_FO_init((void *)(&filterVs_M1[1]), sizeof(FILTER_FO_Obj));
        obj->filterHandle_Vs[2] = FILTER_FO_init((void *)(&filterVs_M1[2]), sizeof(FILTER_FO_Obj));
        obj->filterVsPole_rps = USER_M1_VS_FILTER_POLE_rps;
        float32_t beta_lp_Vs = obj->filterVsPole_rps * objUser->ctrlPeriod_sec;
        float32_t a1_Vs = (beta_lp_Vs - (float32_t)2.0f) / (beta_lp_Vs + (float32_t)2.0f);
        float32_t b0_Vs = beta_lp_Vs / (beta_lp_Vs + (float32_t)2.0f);
        float32_t b1_Vs = b0_Vs;
        // set filter coefficients for voltage filters (low pass filter)
        FILTER_FO_setNumCoeffs(obj->filterHandle_Vs[0], b0_Vs, b1_Vs);
        FILTER_FO_setDenCoeffs(obj->filterHandle_Vs[0], a1_Vs);
        FILTER_FO_setInitialConditions(obj->filterHandle_Vs[0], 0.0f, 0.0f);
        FILTER_FO_setNumCoeffs(obj->filterHandle_Vs[1], b0_Vs, b1_Vs);
        FILTER_FO_setDenCoeffs(obj->filterHandle_Vs[1], a1_Vs);
        FILTER_FO_setInitialConditions(obj->filterHandle_Vs[1], 0.0f, 0.0f);
        FILTER_FO_setNumCoeffs(obj->filterHandle_Vs[2], b0_Vs, b1_Vs);
        FILTER_FO_setDenCoeffs(obj->filterHandle_Vs[2], a1_Vs);
        FILTER_FO_setInitialConditions(obj->filterHandle_Vs[2], 0.0f, 0.0f);
        // Initialize and setup the 100% SVM generator
        obj->svgencurrentHandle =
                SVGENCURRENT_init(&svgencurrent_M1, sizeof(svgencurrent_M1));
        SVGENCURRENT_setup(obj->svgencurrentHandle, 1.0f,
                           USER_M1_PWM_FREQ_kHz, USER_SYSTEM_FREQ_MHz);
        // initialize the estimator
        obj->estHandle = EST_initEst(MTR_1);
        // set the default estimator parameters
        EST_setParams(obj->estHandle, obj->userParamsHandle);
        EST_setFlag_enableForceAngle(obj->estHandle, obj->flagEnableForceAngle);
        EST_setFlag_enableRsRecalc(obj->estHandle, obj->flagEnableRsRecalc);
        // set the scale factor for high frequency low inductance motor
        EST_setOneOverFluxGain_sf(obj->estHandle,
                                  obj->userParamsHandle, USER_M1_EST_FLUX_HF_SF);
        EST_setFreqLFP_sf(obj->estHandle,
                          obj->userParamsHandle, USER_M1_EST_FREQ_HF_SF);
        EST_setBemf_sf(obj->estHandle,
                       obj->userParamsHandle, USER_M1_EST_BEMF_HF_SF);
    #if defined(MOTOR1_LS_CAL)
        objSets->Ls_d_comp_H = EST_getLs_d_H(obj->estHandle);
        objSets->Ls_q_comp_H = EST_getLs_q_H(obj->estHandle);
        objSets->Ls_d_Icomp_coef = USER_MOTOR1_Ls_d_COMP_COEF / obj->maxCurrent_A;
        objSets->Ls_q_Icomp_coef = USER_MOTOR1_Ls_q_COMP_COEF / obj->maxCurrent_A;
        objSets->Ls_min_H = objSets->Ls_d_comp_H * USER_MOTOR1_Ls_MIN_NUM_COEF;
        obj->flagEnableLsUpdate = false;
    #endif // MOTOR1_LS_CAL
        // for Rs re-calculation
        obj->flagEnableRsRecalc = false;
        // if motor is an induction motor, configure default state of PowerWarp
        if(objUser->motor_type == MOTOR_TYPE_INDUCTION)
            EST_setFlag_enablePowerWarp(obj->estHandle, obj->flagEnablePowerWarp);
            EST_setFlag_bypassLockRotor(obj->estHandle, obj->flagBypassLockRotor);
        // for Rs online calibration
        obj->flagRsOnLineContinue = false;
        obj->flagStartRsOnLine = false;
        objSets->RsOnlineWaitTimeSet = USER_MOTOR1_RSONLINE_WAIT_TIME;
        objSets->RsOnlineWorkTimeSet = USER_MOTOR1_RSONLINE_WORK_TIME;
    #ifdef BRAKE_ENABLE
        obj->brakingCurrent_A = USER_MOTOR1_BRAKE_CURRENT_A;
        obj->brakingTimeDelay = USER_MOTOR1_BRAKE_TIME_DELAY;
        obj->flagEnableBraking = false;
        obj->brakingMode = HARDSWITCH_BRAKE_MODE;
    #endif  // BRAKE_ENABLE
    #if defined(MOTOR1_RPM_CMD)
        obj->flagCmdRpmOrHz = false;     // the speed command is rpm
        obj->rpm2Hz_sf = objUser->motor_numPolePairs / 60.0f;
        obj->hz2Rpm_sf = 60.0f / objUser->motor_numPolePairs;
    #endif  // MOTOR1_RPM_CMD
        // setup the controllers, speed, d/q-axis current pid regulator
        setupControllers(handle);
    #if defined(MOTOR1_PI_TUNE)
        // set the coefficient of the controllers gains
        setupControllerSF(handle);
    #endif      // MOTOR1_PI_TUNE
        // disable the PWM
        HAL_disablePWM(obj->halMtrHandle);
        bmarkTestVars.recordDataCount = 0;
        bmarkTestVars.recordTicksSet = 15;
        return;
    }   // end of initMotor1CtrlParameters() function
    void runMotor1OffsetsCalculation(MOTOR_Handle handle)
        calcMotorOverCurrentThreshold(handle); // calculate motor protection value
        HAL_setMtrCMPSSDACValue(obj->halMtrHandle, objSets->dacCMPValH, objSets->dacCMPValL);
        ADC_setPPBReferenceOffset(MTR1_IU_ADC_BASE, MTR1_IU_ADC_PPB_NUM, USER_M1_IA_OFFSET_AD);
        ADC_setPPBReferenceOffset(MTR1_IV_ADC_BASE, MTR1_IV_ADC_PPB_NUM, USER_M1_IB_OFFSET_AD);
        ADC_setPPBReferenceOffset(MTR1_IW_ADC_BASE, MTR1_IW_ADC_PPB_NUM, USER_M1_IC_OFFSET_AD);
        obj->adcData.offset_I_ad.value[0]  = USER_M1_IA_OFFSET_AD; //default ~2000.0f
        obj->adcData.offset_I_ad.value[1]  = USER_M1_IB_OFFSET_AD;
        obj->adcData.offset_I_ad.value[2]  = USER_M1_IC_OFFSET_AD;
        obj->adcData.offset_V_sf.value[0]  = USER_M1_VA_OFFSET_SF; //Offsets in phase voltage sensing
        obj->adcData.offset_V_sf.value[1]  = USER_M1_VB_OFFSET_SF; //default ~0.5f
        obj->adcData.offset_V_sf.value[2]  = USER_M1_VC_OFFSET_SF;
        if(obj->flagEnableOffsetCalc == true)
            float32_t offsetK1 = 0.998001f;  // Offset filter coefficient K1: 0.05/(T+0.05);
            float32_t offsetK2 = 0.001999f;  // Offset filter coefficient K2: T/(T+0.05);
            float32_t invCurrentSf = 1.0f / obj->adcData.current_sf;
            float32_t invVdcbus;
            uint16_t offsetCnt;
            DEVICE_DELAY_US(2.0f);      // delay 2us
            ADC_setPPBReferenceOffset(MTR1_IU_ADC_BASE, MTR1_IU_ADC_PPB_NUM, 0);//1860);
            ADC_setPPBReferenceOffset(MTR1_IV_ADC_BASE, MTR1_IV_ADC_PPB_NUM, 0);//1845);
            ADC_setPPBReferenceOffset(MTR1_IW_ADC_BASE, MTR1_IW_ADC_PPB_NUM, 0);//1805);
            obj->adcData.offset_I_ad.value[0] = obj->adcData.offset_I_ad.value[0] * obj->adcData.current_sf;
            obj->adcData.offset_I_ad.value[1] = obj->adcData.offset_I_ad.value[1] * obj->adcData.current_sf;
            obj->adcData.offset_I_ad.value[2] = obj->adcData.offset_I_ad.value[2] * obj->adcData.current_sf;
            // Set the 3-phase output PWMs to 50% duty cycle.
            //MATH_Vec3 Vabc_pu;     //!< the PWM time-durations for each motor phase
            obj->pwmData.Vabc_pu.value[0] = 0.0f;
            obj->pwmData.Vabc_pu.value[1] = 0.0f;
            obj->pwmData.Vabc_pu.value[2] = 0.0f;
            HAL_writePWMData(obj->halMtrHandle, &obj->pwmData); // write the PWM compare values
            HAL_enablePWM(obj->halMtrHandle); // enable the PWM
            for(offsetCnt = 0; offsetCnt < 2000; offsetCnt++)//32000; offsetCnt++)
                ADC_clearInterruptStatus(MTR1_ADC_INT_BASE, MTR1_ADC_INT_NUM); // clear the ADC interrupt flag
                while(ADC_getInterruptStatus(MTR1_ADC_INT_BASE, MTR1_ADC_INT_NUM) == false);
                HAL_readMtr1ADCData(&obj->adcData);
                if(offsetCnt >= 15)       // Ignore the first 2000 times
                    // Offsets in phase current sensing
                    //new offset value  = filter coef. 1 (0.998) * previous offset value             +       new ADC value       * filter coefficient 2 (0.002)
                    obj->adcData.offset_I_ad.value[0] = offsetK1 * obj->adcData.offset_I_ad.value[0] + obj->adcData.I_A.value[0] * offsetK2;
                    obj->adcData.offset_I_ad.value[1] = offsetK1 * obj->adcData.offset_I_ad.value[1] + obj->adcData.I_A.value[1] * offsetK2;
                    obj->adcData.offset_I_ad.value[2] = offsetK1 * obj->adcData.offset_I_ad.value[2] + obj->adcData.I_A.value[2] * offsetK2;
                    invVdcbus = 1.0f / obj->adcData.VdcBus_V;
                    // Offsets in phase voltage sensing
                    //disabled, these should all be scaled correctly
                    obj->adcData.offset_V_sf.value[0] = offsetK1 * obj->adcData.offset_V_sf.value[0] + (invVdcbus * obj->adcData.V_V.value[0]) * offsetK2;
                    obj->adcData.offset_V_sf.value[1] = offsetK1 * obj->adcData.offset_V_sf.value[1] + (invVdcbus * obj->adcData.V_V.value[1]) * offsetK2;
                    obj->adcData.offset_V_sf.value[2] = offsetK1 * obj->adcData.offset_V_sf.value[2] + (invVdcbus * obj->adcData.V_V.value[2]) * offsetK2;
                else if(offsetCnt <= 1000)
                    // enable the PWM
            } // for()
            // disable the PWM
            obj->adcData.offset_I_ad.value[0] = obj->adcData.offset_I_ad.value[0] * invCurrentSf;
            obj->adcData.offset_I_ad.value[1] = obj->adcData.offset_I_ad.value[1] * invCurrentSf;
            obj->adcData.offset_I_ad.value[2] = obj->adcData.offset_I_ad.value[2] * invCurrentSf;
            ADC_setPPBReferenceOffset(MTR1_IU_ADC_BASE, MTR1_IU_ADC_PPB_NUM, (uint16_t)obj->adcData.offset_I_ad.value[0]);
            ADC_setPPBReferenceOffset(MTR1_IV_ADC_BASE, MTR1_IV_ADC_PPB_NUM, (uint16_t)obj->adcData.offset_I_ad.value[1]);
            ADC_setPPBReferenceOffset(MTR1_IW_ADC_BASE, MTR1_IW_ADC_PPB_NUM, (uint16_t)obj->adcData.offset_I_ad.value[2]);
        }   // flagEnableOffsetCalc = true
        IU_OFFSET_SF_MAX = USER_M1_IA_OFFSET_AD_MAX;
        IU_OFFSET_SF_MIN = USER_M1_IA_OFFSET_AD_MIN;
        IV_OFFSET_SF_MAX = USER_M1_IB_OFFSET_AD_MAX;
        IV_OFFSET_SF_MIN = USER_M1_IB_OFFSET_AD_MIN;
        IW_OFFSET_SF_MAX = USER_M1_IC_OFFSET_AD_MAX;
        IW_OFFSET_SF_MIN = USER_M1_IC_OFFSET_AD_MIN;
        VU_OFFSET_SF_MAX = USER_M1_VA_OFFSET_SF_MAX;
        VU_OFFSET_SF_MIN = USER_M1_VA_OFFSET_SF_MIN;
        VV_OFFSET_SF_MAX = USER_M1_VB_OFFSET_SF_MAX;
        VV_OFFSET_SF_MIN = USER_M1_VB_OFFSET_SF_MIN;
        VW_OFFSET_SF_MAX = USER_M1_VC_OFFSET_SF_MAX;
        VW_OFFSET_SF_MIN = USER_M1_VC_OFFSET_SF_MIN;
        // Check current and voltage offset
        if( (obj->adcData.offset_I_ad.value[0] > USER_M1_IA_OFFSET_AD_MAX) ||
            (obj->adcData.offset_I_ad.value[0] < USER_M1_IA_OFFSET_AD_MIN) )
            obj->faultMtrNow.bit.currentOffset = 1;
        if( (obj->adcData.offset_I_ad.value[1] > USER_M1_IB_OFFSET_AD_MAX) ||
            (obj->adcData.offset_I_ad.value[1] < USER_M1_IB_OFFSET_AD_MIN) )
        if( (obj->adcData.offset_I_ad.value[2] > USER_M1_IC_OFFSET_AD_MAX) ||
            (obj->adcData.offset_I_ad.value[2] < USER_M1_IC_OFFSET_AD_MIN) )
    #if defined(MOTOR1_FAST) || defined(MOTOR1_ISBLDC)
        if( (obj->adcData.offset_V_sf.value[0] > USER_M1_VA_OFFSET_SF_MAX) ||
            (obj->adcData.offset_V_sf.value[0] < USER_M1_VA_OFFSET_SF_MIN) )
            obj->faultMtrNow.bit.voltageOffset = 1;
        if( (obj->adcData.offset_V_sf.value[1] > USER_M1_VB_OFFSET_SF_MAX) ||
            (obj->adcData.offset_V_sf.value[1] < USER_M1_VB_OFFSET_SF_MIN) )
        if( (obj->adcData.offset_V_sf.value[2] > USER_M1_VC_OFFSET_SF_MAX) ||
            (obj->adcData.offset_V_sf.value[2] < USER_M1_VC_OFFSET_SF_MIN) )
    #endif  // MOTOR1_FAST ||  MOTOR1_ISBLDC
        if((obj->faultMtrNow.bit.voltageOffset == 0) &&
                (obj->faultMtrNow.bit.currentOffset == 0))
            obj->flagEnableOffsetCalc = false;
        return;
    } // end of runMotor1OffsetsCalculation() function
    void runMotor1Control(MOTOR_Handle handle)
        MOTOR_SetVars_t *objSets = (MOTOR_SetVars_t *)(obj->motorSetsHandle);
        USER_Params *objUser = (USER_Params *)(obj->userParamsHandle);
        //HAL_readMtr1ADCData(&obj->adcData);
        // enable the PWM
        //HAL_enablePWM(obj->halMtrHandle);
        if(HAL_getPwmEnableStatus(obj->halMtrHandle) == true)
            if(HAL_getMtrTripFaults(obj->halMtrHandle) != 0)
                obj->faultMtrNow.bit.moduleOverCurrent = 1;
        obj->faultMtrPrev.all |= obj->faultMtrNow.all;
        obj->faultMtrUse.all = obj->faultMtrNow.all & obj->faultMtrMask.all;
        if(obj->flagClearFaults == true)
            HAL_clearMtrFaultStatus(obj->halMtrHandle);
            obj->faultMtrNow.all &= MTR_FAULT_CLEAR;
            obj->flagClearFaults = false;
        if(obj->flagEnableRunAndIdentify == true)
            // Had some faults to stop the motor
            if(obj->faultMtrUse.all != 0)
                if(obj->flagRunIdentAndOnLine == true)
                    obj->flagRunIdentAndOnLine = false;
                    obj->motorState = MOTOR_FAULT_STOP;
                    obj->stopWaitTimeCnt = objSets->restartWaitTimeSet;
                    obj->restartTimesCnt++;
                    if(obj->flagEnableRestart == false)
                        obj->flagEnableRunAndIdentify = false;
                else if(obj->stopWaitTimeCnt == 0)
                    if(obj->restartTimesCnt < objSets->restartTimesSet)
                        obj->flagClearFaults = 1;
                    else
            // Restart
            else if((obj->flagRunIdentAndOnLine == false) &&
                    (obj->stopWaitTimeCnt == 0))
                restartMotorControl(handle);
        // if(obj->flagEnableRunAndIdentify == false)
        else if(obj->flagRunIdentAndOnLine == true)
            stopMotorControl(handle);
            if(obj->flagEnableFlyingStart == false)
                obj->stopWaitTimeCnt = objSets->stopWaitTimeSet;
            else
        else
        // enable or disable bypassLockRotor flag
        if((objUser->motor_type == MOTOR_TYPE_INDUCTION)
            && (obj->flagMotorIdentified == true))
            if(HAL_getPwmEnableStatus(obj->halMtrHandle) == false)
                // enable the estimator
                EST_enable(obj->estHandle);
                // enable the trajectory generator
                EST_enableTraj(obj->estHandle);
                // enable the PWM
            if(obj->flagMotorIdentified == true)
                if(obj->speedRef_Hz > 0.0f)
                    obj->direction = 1.0f;
                else
                    obj->direction = -1.0f;
                // enable or disable force angle
                // enable or disable stator resistance (Rs) re-calculation
                // Sets the target speed for the speed trajectory
                if(obj->motorState >= MOTOR_CL_RUNNING)
                    TRAJ_setTargetValue(obj->trajHandle_spd, obj->speedRef_Hz);
                else
                                        (obj->speedForce_Hz * obj->direction));
            #elif defined(MOTOR1_ISBLDC)
                else
                    obj->speed_int_Hz = obj->speedForce_Hz * obj->direction;
                else
                else
            #else   // !MOTOR1_ESMO && !MOTOR1_FAST
            #error No select a right estimator for motor_1 control
            #endif  // MOTOR1_ESMO || MOTOR1_FAST
                if((fabsf(obj->speed_Hz) > obj->speedStart_Hz) ||
                        (obj->motorState == MOTOR_CTRL_RUN))
                    //  Sets the acceleration / deceleration for the speed trajectory
                      (obj->accelerationMax_Hzps * objUser->ctrlPeriod_sec));
    #if defined(MOTOR1_FAST) && defined(MOTOR1_LS_CAL)
                    if(obj->flagEnableLsUpdate ==  true)
                        // Calculate the Ld and Lq which reduce with current
                        objSets->Ls_d_comp_H = objUser->motor_Ls_d_H * (1.0f - obj->Is_A * objSets->Ls_d_Icomp_coef);
                        objSets->Ls_q_comp_H = objUser->motor_Ls_q_H * (1.0f - obj->Is_A * objSets->Ls_q_Icomp_coef);
                        if(objSets->Ls_d_comp_H < objSets->Ls_min_H)
                            objSets->Ls_d_comp_H = objSets->Ls_min_H;
                        if(objSets->Ls_q_comp_H < objSets->Ls_min_H)
                            objSets->Ls_q_comp_H = objSets->Ls_min_H;
                        // Update the Ld and Lq for motor control
                        EST_setLs_d_H(obj->estHandle, objSets->Ls_d_comp_H);
                        EST_setLs_q_H(obj->estHandle, objSets->Ls_q_comp_H);
    #endif //MOTOR1_FAST & MOTOR1_LS_CAL
                    ISBLDC_updateThresholdInt(obj->isbldcHandle, obj->speed_int_Hz);
                    #if (DMC_BUILDLEVEL >= DMC_LEVEL_4)
                    PI_setMinMax(obj->piHandle_spd, -obj->maxCurrent_A, obj->maxCurrent_A);
                    #else
                    PI_setMinMax(obj->piHandle_spd, -1.0f, 1.0f);
                    SVGEN_setMode(obj->svgenHandle, obj->svmMode);
                    if(obj->motorState == MOTOR_CL_RUNNING)
                        obj->stateRunTimeCnt++;
                        if(obj->stateRunTimeCnt == obj->startupTimeDelay)
                            obj->Idq_out_A.value[0] = 0.0f;
                            obj->motorState = MOTOR_CTRL_RUN;
                else
                      (obj->accelerationStart_Hzps * objUser->ctrlPeriod_sec));
                    if(obj->speed_int_Hz > 0.0f)
                        PI_setMinMax(obj->piHandle_spd, 0.0f, obj->startCurrent_A);
                    else
                        PI_setMinMax(obj->piHandle_spd, -obj->startCurrent_A, 0.0f);
                    #else   // (DMC_BUILDLEVEL < DMC_LEVEL_3)
                    #endif  // DMC_BUILDLEVEL < DMC_LEVEL_3
                    if(obj->speed_int_Hz >= 0.0f)
                    else
            // Identification
    #if(DMC_BUILDLEVEL == DMC_LEVEL_3)
            obj->Idq_out_A.value[0] = obj->Idq_set_A.value[0];
            obj->Idq_out_A.value[1] = obj->Idq_set_A.value[1] * obj->direction;
        else
            // reset motor control parameters
            resetMotorControl(handle);
        // check the trajectory generator
        if(EST_isTrajError(obj->estHandle) == true)
            // disable the PWM
        else
            // update the trajectory generator state
            EST_updateTrajState(obj->estHandle);
        // check the estimator
        if(EST_isError(obj->estHandle) == true)
            // disable the PWM
        else
            bool flagEstStateChanged = false;
            float32_t Id_target_A = EST_getIntValue_Id_A(obj->estHandle);
                flagEstStateChanged = EST_updateState(obj->estHandle, 0.0f);
            else
                flagEstStateChanged = EST_updateState(obj->estHandle, Id_target_A);
            if(flagEstStateChanged == true)
                // configure the trajectory generator, enter once every state
                EST_configureTraj(obj->estHandle);
                if(obj->flagMotorIdentified == false)
                    // configure the controllers, enter once every state
                    EST_configureTrajState(obj->estHandle, obj->userParamsHandle,
                                           obj->piHandle_spd,
                                           obj->piHandle_Id, obj->piHandle_Iq);
                if(objUser->flag_bypassMotorId == false)
                    if((EST_isLockRotor(obj->estHandle) == true) ||
                            ( (EST_isMotorIdentified(obj->estHandle) == true)
                                      && (EST_isIdle(obj->estHandle) == true) ) )
                        if(EST_isMotorIdentified(obj->estHandle) == true)
                            obj->flagMotorIdentified = true;
                            // clear the flag
                            // disable the estimator
                            EST_disable(obj->estHandle);
                            EST_disableTraj(obj->estHandle);
                            // clear the flag
                }   // objUser->flag_bypassMotorId = false
        obj->flagMotorIdentified = EST_isMotorIdentified(obj->estHandle);
    #else   // !MOTOR1_FAST
    #endif //  !MOTOR1_FAST
            if(obj->flagSetupController == true)
                // update the controller
                updateControllers(handle);
            else
                obj->flagSetupController = true;
        // run Rs online
        runRsOnLine(handle);
        // update the global variables
        updateGlobalVariables(handle);
        if(obj->motorState >= MOTOR_CTRL_RUN)
            ESMO_updateFilterParams(obj->esmoHandle);
            ESMO_updatePLLParams(obj->esmoHandle);
    #endif  // MOTOR2_ESMO
        return;
    }   // end of the runMotor1Control() function
    __interrupt void motor1CtrlISR(void)
        motorVars_M1.ISRCount++;
        MOTOR_Vars_t *obj = (MOTOR_Vars_t *)motorHandle_M1;
        HAL_ackMtr1ADCInt();        // acknowledge the ADC interrupt
        HAL_readMtr1ADCData(&obj->adcData);    // read the ADC data with offsets
    // 180-degree Sinusoidal Sensorless-FOC or Sensored-FOC
        // run single-shunt current reconstruction
        DCLINK_SS_runCurrentReconstruction(obj->dclinkHandle,
                                         &obj->adcData.Idc1_A, &obj->adcData.Idc2_A);
        obj->sector = DCLINK_SS_getSector1(obj->dclinkHandle);
        obj->adcData.I_A.value[0] = DCLINK_SS_getIa(obj->dclinkHandle);
        obj->adcData.I_A.value[1] = DCLINK_SS_getIb(obj->dclinkHandle);
        obj->adcData.I_A.value[2] = DCLINK_SS_getIc(obj->dclinkHandle);
        // run first order filters for current sensing
        obj->adcIs_A.value[0] = FILTER_FO_run(obj->filterHandle_Is[0], obj->adcData.I_A.value[0]);
        obj->adcIs_A.value[1] = FILTER_FO_run(obj->filterHandle_Is[1], obj->adcData.I_A.value[1]);
        obj->adcIs_A.value[2] = FILTER_FO_run(obj->filterHandle_Is[2], obj->adcData.I_A.value[2]);
        if(obj->flagEnableFilterIs == true)
            obj->adcData.I_A.value[0] = obj->adcIs_A.value[0];
            obj->adcData.I_A.value[1] = obj->adcIs_A.value[1];
            obj->adcData.I_A.value[2] = obj->adcIs_A.value[2];
        // Over Modulation Supporting, run the current reconstruction algorithm
        SVGENCURRENT_RunRegenCurrent(obj->svgencurrentHandle,
                                     &obj->adcData.I_A, &obj->adcDataPrev);
    #if defined(MOTOR1_FAST) && defined(MOTOR1_ESMO)    // (OK<->OK)
        // sensorless-FOC
        MATH_Vec2 phasor;
        ANGLE_GEN_run(obj->angleGenHandle, obj->speed_int_Hz);
        obj->angleGen_rad = ANGLE_GEN_getAngle(obj->angleGenHandle);
        VOLREC_run(obj->volrecHandle, obj->adcData.VdcBus_V,
                   &(obj->pwmData.Vabc_pu), &(obj->estInputData.Vab_V));
    #else  // !MOTOR1_VOLRECT
        // remove offsets
        obj->adcData.V_V.value[0] -=
                obj->adcData.offset_V_sf.value[0] * obj->adcData.VdcBus_V;
        obj->adcData.V_V.value[1] -=
                obj->adcData.offset_V_sf.value[1] * obj->adcData.VdcBus_V;
        obj->adcData.V_V.value[2] -=
                obj->adcData.offset_V_sf.value[2] * obj->adcData.VdcBus_V;
        // run first order filters for voltage sensing
        obj->adcVs_V.value[0] = FILTER_FO_run(obj->filterHandle_Vs[0], obj->adcData.V_V.value[0]);
        obj->adcVs_V.value[1] = FILTER_FO_run(obj->filterHandle_Vs[1], obj->adcData.V_V.value[1]);
        obj->adcVs_V.value[2] = FILTER_FO_run(obj->filterHandle_Vs[2], obj->adcData.V_V.value[2]);
        if(obj->flagEnableFilterVs == true)
            obj->adcData.V_V.value[0] = obj->adcVs_V.value[0];
            obj->adcData.V_V.value[1] = obj->adcVs_V.value[1];
            obj->adcData.V_V.value[2] = obj->adcVs_V.value[2];
        // run Clarke transform on voltage
        CLARKE_run(obj->clarkeHandle_V,
                   &obj->adcData.V_V, &obj->estInputData.Vab_V);
        // run Clarke transform on current
        CLARKE_run(obj->clarkeHandle_I, &obj->adcData.I_A, &obj->estInputData.Iab_A);
        if(((EST_isMotorIdentified(obj->estHandle) == false) ||
                (EST_getState(obj->estHandle) == EST_STATE_RS)) &&
                (EST_isEnabled(obj->estHandle) == true))
            // run identification or Rs Recalibration
            // setup the trajectory generator
            EST_setupTrajState(obj->estHandle,
                               obj->Idq_out_A.value[1],
                               obj->speedRef_Hz,
                               0.0f);
            // run the trajectories
            EST_runTraj(obj->estHandle);
            obj->IdRated_A = EST_getIntValue_Id_A(obj->estHandle);
            // store the input data into a buffer
            obj->estInputData.speed_ref_Hz = EST_getIntValue_spd_Hz(obj->estHandle);
            obj->speed_int_Hz = obj->estInputData.speed_ref_Hz;
            obj->enableSpeedCtrl = EST_doSpeedCtrl(obj->estHandle);
            obj->enableCurrentCtrl = EST_doCurrentCtrl(obj->estHandle);
        else if(obj->flagMotorIdentified == true)
                obj->counterTrajSpeed++;
                if(obj->counterTrajSpeed >= objUser->numIsrTicksPerTrajTick)
                    // clear counter
                    obj->counterTrajSpeed = 0;
                    // run a trajectory for speed reference,
                    // so the reference changes with a ramp instead of a step
                    TRAJ_run(obj->trajHandle_spd);
                obj->enableCurrentCtrl = obj->flagEnableCurrentCtrl;
                obj->enableSpeedCtrl = obj->flagEnableSpeedCtrl;
                // get Id reference for Rs OnLine
                obj->IdRated_A = EST_getIdRated_A(obj->estHandle);
            else
                obj->enableSpeedCtrl = false;
                obj->enableCurrentCtrl = false;
            obj->estInputData.speed_ref_Hz = TRAJ_getIntValue(obj->trajHandle_spd);
        obj->estInputData.dcBus_V = obj->adcData.VdcBus_V;
        // run the FAST estimator
        EST_run(obj->estHandle, &obj->estInputData, &obj->estOutputData);
        // compute angle with delay compensation
        obj->angleESTCOMP_rad =
                objUser->angleDelayed_sf_sec * obj->estOutputData.fm_lp_rps;
        obj->angleEST_rad =
                MATH_incrAngle(obj->estOutputData.angle_rad, obj->angleESTCOMP_rad);
        obj->speedEST_Hz = EST_getFm_lp_Hz(obj->estHandle);
        obj->oneOverDcBus_invV = obj->estOutputData.oneOverDcBus_invV;
        // run the eSMO
        ESMO_setSpeedRef(obj->esmoHandle, obj->speed_int_Hz);
        ESMO_run(obj->esmoHandle, obj->adcData.VdcBus_V,
                        &(obj->pwmData.Vabc_pu), &(obj->estInputData.Iab_A));
        obj->anglePLLComp_rad = obj->speedPLL_Hz * obj->angleDelayed_sf;
        obj->anglePLL_rad = MATH_incrAngle(ESMO_getAnglePLL(obj->esmoHandle), obj->anglePLLComp_rad);
    #if defined(ESMO_DEBUG)
        obj->angleSMO_rad = ESMO_getAngleElec(obj->esmoHandle);
    #endif  //ESMO_DEBUG
        SPDFR_run(obj->spdfrHandle, obj->anglePLL_rad);
        obj->speedPLL_Hz = SPDFR_getSpeedHz(obj->spdfrHandle);
        obj->speedFilter_Hz = obj->speedFilter_Hz *0.875f + obj->speed_Hz * 0.125f;
        obj->speedAbs_Hz = fabsf(obj->speedFilter_Hz);
        // Running state
        if(obj->estimatorMode == ESTIMATOR_MODE_FAST)
            obj->speed_Hz = obj->speedEST_Hz;
                obj->angleFOC_rad = obj->angleEST_rad;
                ESMO_updateKslide(obj->esmoHandle);
            else if(obj->motorState == MOTOR_CL_RUNNING)
                ESMO_setAnglePu(obj->esmoHandle, obj->angleFOC_rad);
            else if(obj->motorState == MOTOR_OL_START)
                obj->motorState = MOTOR_CL_RUNNING;
            else if(obj->motorState == MOTOR_ALIGNMENT)
                obj->angleFOC_rad = 0.0f;
                obj->IsRef_A = 0.0f;
                obj->Idq_out_A.value[0] = obj->alignCurrent_A;
                obj->Idq_out_A.value[1] = 0.0f;
                EST_setAngle_rad(obj->estHandle, obj->angleFOC_rad);
                if((obj->stateRunTimeCnt > obj->alignTimeDelay) ||
                         (obj->flagEnableAlignment == false))
                    obj->stateRunTimeCnt = 0;
                    obj->motorState = MOTOR_OL_START;
                    obj->Idq_out_A.value[0] = obj->fluxCurrent_A;
                    PI_setUi(obj->piHandle_spd, 0.0);
            else if(obj->motorState == MOTOR_SEEK_POS)
                if(obj->stateRunTimeCnt > obj->flyingStartTimeDelay)
                    if(obj->speedAbs_Hz > obj->speedFlyingStart_Hz)
                        obj->speed_int_Hz = obj->speedFilter_Hz;
                        TRAJ_setIntValue(obj->trajHandle_spd, obj->speedFilter_Hz);
                        PI_setUi(obj->piHandle_spd, 0.0f);
                    else
                        obj->motorState = MOTOR_ALIGNMENT;
        else    // if(obj->estimatorMode == ESTIMATOR_MODE_ESMO)
            obj->speed_Hz = obj->speedPLL_Hz;
                obj->angleFOC_rad = obj->anglePLL_rad;
                obj->angleFOC_rad = obj->angleGen_rad;
                    obj->IsRef_A = obj->startCurrent_A;
                    obj->Idq_out_A.value[1] = obj->startCurrent_A;
                else
                    obj->IsRef_A = -obj->startCurrent_A;
                    obj->Idq_out_A.value[1] = -obj->startCurrent_A;
                if(fabsf(obj->estInputData.speed_ref_Hz) >= obj->speedForce_Hz)
                    TRAJ_setIntValue(obj->trajHandle_spd, obj->estInputData.speed_ref_Hz);
                    if(obj->stateRunTimeCnt > obj->forceRunTimeDelay)
                        PI_setUi(obj->piHandle_spd, (obj->frswPos_sf * obj->Idq_out_A.value[1]));
                ANGLE_GEN_setAngle(obj->angleGenHandle, obj->angleFOC_rad);
                    else
            else
            if(obj->speedAbs_Hz >= obj->speedForce_Hz)
                PI_setUi(obj->piHandle_spd, obj->startCurrent_A * 0.5f);
    #endif
        // compute the sin/cos phasor
        phasor.value[0] = __cos(obj->angleFOC_rad);
        phasor.value[1] = __sin(obj->angleFOC_rad);
        // set the phasor in the Park transform
        PARK_setPhasor(obj->parkHandle_I, &phasor);
        // run the Park transform
        PARK_run(obj->parkHandle_I, &(obj->estInputData.Iab_A),
                 (MATH_vec2 *)&(obj->Idq_in_A));
        // End of MOTOR1_FAST && MOTOR1_ESMO
        // sensorless-FOC
        MATH_Vec2 phasor;
        // remove offsets
                               obj->speedRef_Hz,
                               0.0f);
        else if(obj->flagMotorIdentified == true)   // Normal Running
                    // clear counter
            else
        // Runs the FAST estimator
        obj->angleEST_rad =
        // Runs encoder
        ENC_run(obj->encHandle);
        obj->angleENC_rad = ENC_getElecAngle(obj->encHandle);
        SPDCALC_run(obj->spdcalcHandle, obj->angleENC_rad);
        obj->speedENC_Hz = SPDCALC_getSpeedHz(obj->spdcalcHandle);
        // Running state
                if((ENC_getState(obj->encHandle) == ENC_CALIBRATION_DONE) ||
                        ((obj->stateRunTimeCnt > obj->forceRunTimeDelay)))
                    ENC_setState(obj->encHandle, ENC_WAIT_FOR_INDEX);
                    else
        else    // if(obj->estimatorMode == ESTIMATOR_MODE_ENC)
            obj->speed_Hz = obj->speedENC_Hz;
                obj->angleFOC_rad = obj->angleENC_rad;
                else
                TRAJ_setIntValue(obj->trajHandle_spd, obj->speed_int_Hz);
                if(ENC_getState(obj->encHandle) == ENC_CALIBRATION_DONE)
                    else
    #endif
    #ifdef BRAKE_ENABLE
        if(obj->flagEnableBraking == true)
            if(obj->motorState != MOTOR_BRAKE_STOP)
                obj->motorState = MOTOR_BRAKE_STOP;
                if(obj->brakingMode == HARDSWITCH_BRAKE_MODE)
                    // enable the braking mode PWM with
                    // turning-on three low side, turn off three high side
                    HAL_enableBrakePWM(obj->halMtrHandle);
                else if(obj->brakingMode == FORCESTOP_BRAKE_MODE)
                    obj->angleBrake_rad = obj->angleFOC_rad;
                    PI_setRefValue(obj->piHandle_spd, 0.0f);
                obj->angleBrake_rad = obj->angleBrake_rad;
                obj->IsRef_A = obj->brakingCurrent_A;
                obj->Idq_out_A.value[1] = obj->brakingCurrent_A;
                obj->enableCurrentCtrl = true;
            else
    // End of MOTOR1_FAST && MOTOR1_ENC
    #elif defined(MOTOR1_ESMO) && defined(MOTOR1_ENC)
        // sensorless-FOC
        MATH_Vec2 phasor;
        CLARKE_run(obj->clarkeHandle_I, &obj->adcData.I_A, &obj->Iab_A);
                // clear counter
        else
        obj->speed_int_Hz = TRAJ_getIntValue(obj->trajHandle_spd);
        obj->oneOverDcBus_invV = 1.0f / obj->adcData.VdcBus_V;
        // run the eSMO
                        &(obj->pwmData.Vabc_pu), &(obj->Iab_A));
    #endif  //ESMO_DEBUG
        // run the encoder
        ENC_inline_run(obj->encHandle);
        // Running state
                else
                if(fabsf(obj->speed_int_Hz) >= obj->speedForce_Hz)
                ESMO_setAnglePu(obj->esmoHandle, 0.0f);
                ANGLE_GEN_setAngle(obj->angleGenHandle, 0.0f);
                    else
                else
                    else
    #endif
        PARK_run(obj->parkHandle_I, &(obj->Iab_A),
    // End of MOTOR1_ESMO && MOTOR1_ENC
        // sensorless-FOC
        MATH_Vec2 phasor;
    #endif  // (DMC_BUILDLEVEL <= DMC_LEVEL_3)
        // remove offsets
                    // clear counter
            else
        else if(EST_isEnabled(obj->estHandle) == true)  // run identification
                               obj->speedRef_Hz,
                               0.0f);
        obj->angleEST_rad =
        // Hall Sensor
        HALL_setTimeStamp(obj->hallHandle, HAL_calcCAPCount(obj->halMtrHandle));
        HALL_run(obj->hallHandle, obj->speed_int_Hz);
        obj->angleHall_rad = HALL_getAngle_rad(obj->hallHandle);
        obj->speedHall_Hz = HALL_getSpeed_Hz(obj->hallHandle);
        #ifdef HALL_CAL
        HALL_calibrateIndexAngle(obj->hallHandle, obj->angleEST_rad);
        #endif  // MOTOR1_HALL_CAL
        // Running state
                HALL_setForceAngleAndIndex(obj->hallHandle, obj->speedRef_Hz);
                    else
        else    // if(obj->estimatorMode == ESTIMATOR_MODE_HALL)
            obj->speed_Hz = obj->speedHall_Hz;
                obj->angleFOC_rad = obj->angleHall_rad;
                else
                    else
    #endif
    // End of MOTOR1_FAST && MOTOR1_HALL
        // sensorless-FOC
        MATH_Vec2 phasor;
                // clear counter
        else
        // run the eSMO
    #endif  //ESMO_DEBUG
            else
                else
    #endif
        PARK_run(obj->parkHandle_I, &(obj->Iab_A), (MATH_vec2 *)&(obj->Idq_in_A));
        MATH_Vec2 phasor;
                // clear counter
        else
            else
                else
    #endif
    // End of MOTOR1_ENC
        // sensorless-FOC
        MATH_Vec2 phasor;
    #if ((DMC_BUILDLEVEL <= DMC_LEVEL_3) || defined(MOTOR1_VOLRECT))
    #endif  // ((DMC_BUILDLEVEL <= DMC_LEVEL_3) || defined(MOTOR1_VOLRECT))
        // remove offsets
        obj->angleEST_rad =
                               obj->speedRef_Hz,
                               0.0);
                    // clear counter
            else
        // Running state
                PI_setUi(obj->piHandle_spd, obj->alignCurrent_A);
                else
            else
    #endif
        MATH_Vec2 phasor;
                // clear counter
        else
            else
                else
    #endif
    // End of MOTOR1_HALL
    #else   // No Any Estimator
    #endif  // (ESTIMATOR)
        // convert the feedback speed to rpm
        obj->speed_rpm = obj->speed_Hz * obj->hz2Rpm_sf;
        if(obj->flagCmdRpmOrHz == false)
            obj->speedRef_rpm = obj->speedRef_Hz * obj->hz2Rpm_sf;
        else
            obj->speedRef_Hz = obj->speedRef_rpm * obj->rpm2Hz_sf;
    //---------- Common Speed and Current Loop for all observers -------------------
    #if(DMC_BUILDLEVEL >= DMC_LEVEL_4)
    #if defined(SFRA_ENABLE)
        if(sfraCollectStart == true)
            collectSFRA(motorHandle_M1);    // Collect noise feedback from loop
        //  SFRA injection
        injectSFRA();                   // create SFRA Noise per 'sfraTestLoop'
        sfraCollectStart = true;       // enable SFRA data collection
    #endif  // SFRA_ENABLE
        // run the speed controller
        obj->counterSpeed++;
        if(obj->counterSpeed >= objUser->numCtrlTicksPerSpeedTick)
            obj->counterSpeed = 0;
            obj->speed_reg_Hz = obj->speed_Hz;
            if(obj->enableSpeedCtrl == true)
                obj->Is_ffwd_A = 0.0f;
                PI_run_series(obj->piHandle_spd,
                       (obj->speed_int_Hz + sfraNoiseSpd), obj->speed_reg_Hz,
                       obj->Is_ffwd_A, (float32_t *)&obj->IsRef_A);
    #else     // !SFRA_ENABLE
                       obj->speed_int_Hz, obj->speed_reg_Hz,
    #endif  // !SFRA_ENABLE
            else if((obj->motorState >= MOTOR_CL_RUNNING) &&
                    obj->IsRef_A = obj->IsSet_A;
                else
                    obj->IsRef_A = -obj->IsSet_A;
                // for switching back speed closed-loop control
                PI_setUi(obj->piHandle_spd, obj->IsRef_A);
    #if defined(MOTOR1_FWC) && defined(MOTOR1_MTPA)
        else if(obj->counterSpeed == 1)
            MATH_Vec2 fwcPhasor;
            // get the current angle
            obj->angleCurrent_rad =
                    (obj->angleFWC_rad > obj->angleMTPA_rad) ?
                            obj->angleFWC_rad : obj->angleMTPA_rad;
            fwcPhasor.value[0] = __cos(obj->angleCurrent_rad);
            fwcPhasor.value[1] = __sin(obj->angleCurrent_rad);
            if((obj->flagEnableFWC == true) || (obj->flagEnableMTPA == true))
                obj->Idq_out_A.value[0] = obj->IsRef_A * fwcPhasor.value[0];
            obj->Idq_out_A.value[1] = obj->IsRef_A * fwcPhasor.value[1];
        else if(obj->counterSpeed == 2)
            // Compute the output and reference vector voltage
            obj->Vs_V =
                    __sqrt((obj->Vdq_out_V.value[0] * obj->Vdq_out_V.value[0]) +
                           (obj->Vdq_out_V.value[1] * obj->Vdq_out_V.value[1]));
            obj->VsRef_V = obj->VsRef_pu * obj->adcData.VdcBus_V;
        else if(obj->counterSpeed == 3)   // FWC
            if(obj->flagEnableFWC == true)
                float32_t angleFWC;
                PI_run(obj->piHandle_fwc,
                       obj->VsRef_V, obj->Vs_V, (float32_t*)&angleFWC);
                obj->angleFWC_rad = MATH_PI_OVER_TWO - angleFWC;
            else
                PI_setUi(obj->piHandle_fwc, 0.0f);
                obj->angleFWC_rad = MATH_PI_OVER_TWO;
        else if(obj->counterSpeed == 4)   // MTPA
            if(obj->flagEnableMTPA == true)
                obj->angleMTPA_rad =
                        MTPA_computeCurrentAngle(obj->mtpaHandle, obj->IsRef_A);
            else
                obj->angleMTPA_rad = MATH_PI_OVER_TWO;
    #elif defined(MOTOR1_FWC)
            obj->angleCurrent_rad = obj->angleFWC_rad;
            obj->Vs_V =
                float32_t angleFWC;
            else
    #elif defined(MOTOR1_MTPA)
            obj->angleCurrent_rad = obj->angleMTPA_rad;
                obj->angleMTPA_rad = MTPA_computeCurrentAngle(obj->mtpaHandle, obj->IsRef_A);
            else
    #else   // !MOTOR1_MTPA && !MOTOR1_FWC
        obj->Idq_out_A.value[1] = obj->IsRef_A;
    #endif  // !MOTOR1_MTPA && !MOTOR1_FWC/
    #if !defined(STEP_RP_EN)
        obj->IdqRef_A.value[0] = obj->Idq_out_A.value[0] + obj->IdRated_A;
    #endif  // STEP_RP_EN
        // update Id reference for Rs OnLine
        EST_updateId_ref_A(obj->estHandle, &obj->IdqRef_A.value[0]);
    #if defined(MOTOR1_VIBCOMP)
        // get the Iq reference value plus vibration compensation
        obj->IdqRef_A.value[1] = Idq_out_A.value[1] +
                VIB_COMP_inline_run(vibCompHandle, angleFOCM1_rad, Idq_in_A.value[1]);
    #else
        obj->IdqRef_A.value[1] = obj->Idq_out_A.value[1];
    #endif  // MOTOR1_VIBCOMP
    #else   // STEP_RP_EN
        if(GRAPH_getBufferMode(&stepRPVars) != GRAPH_STEP_RP_TORQUE)
        else
            PI_setUi(obj->piHandle_spd, obj->IdqRef_A.value[1]);
    #elif(DMC_BUILDLEVEL == DMC_LEVEL_3)
        obj->IdqRef_A.value[0] = obj->Idq_set_A.value[0];
        obj->IdqRef_A.value[1] = obj->Idq_set_A.value[1];
        if(obj->enableCurrentCtrl == true)
            obj->Vdq_ffwd_V.value[0] = 0.0f;
            obj->Vdq_ffwd_V.value[1] = 0.0f;
            // Maximum voltage output
            obj->VsMax_V = objUser->maxVsMag_pu * obj->adcData.VdcBus_V;
            PI_setMinMax(obj->piHandle_Id, -obj->VsMax_V, obj->VsMax_V);
            // run the Id controller
            PI_run_series(obj->piHandle_Id,
                          (obj->IdqRef_A.value[0] + sfraNoiseId), obj->Idq_in_A.value[0],
                          obj->Vdq_ffwd_V.value[0], (float32_t*)&obj->Vdq_out_V.value[0]);
            // calculate Iq controller limits
            float32_t outMax_V = __sqrt((obj->VsMax_V * obj->VsMax_V) -
                              (obj->Vdq_out_V.value[0] * obj->Vdq_out_V.value[0]));
            PI_setMinMax(obj->piHandle_Iq, -outMax_V, outMax_V);
            // run the Iq controller
            PI_run(obj->piHandle_Iq, (obj->IdqRef_A.value[1] + sfraNoiseIq),
                   obj->Idq_in_A.value[1], (float32_t*)&obj->Vdq_out_V.value[1]);
                          obj->IdqRef_A.value[0], obj->Idq_in_A.value[0],
            PI_run(obj->piHandle_Iq, obj->IdqRef_A.value[1],
            // set the Id reference value in the estimator
            EST_setId_ref_A(obj->estHandle, obj->IdqRef_A.value[0]);
            EST_setIq_ref_A(obj->estHandle, obj->IdqRef_A.value[1]);
        VS_FREQ_run(obj->VsFreqHandle, obj->speed_int_Hz);
        obj->Vdq_out_V.value[0] = VS_FREQ_getVd_out(obj->VsFreqHandle);
        obj->Vdq_out_V.value[1] = VS_FREQ_getVq_out(obj->VsFreqHandle);
    #if defined(PHASE_ADJ_EN)
        if(obj->flagPhaseAdjustEnable == true)
            obj->angleFOCAdj_rad =
                    MATH_incrAngle(obj->angleFOC_rad, obj->anglePhaseAdj_rad);
            phasor.value[0] = __cos(obj->angleFOCAdj_rad);
            phasor.value[1] = __sin(obj->angleFOCAdj_rad);
        else
            obj->angleFOCAdj_rad = obj->angleFOC_rad;
        EST_getEab_V(obj->estHandle, &obj->Eab_V);
    #endif  // PHASE_ADJ_EN
        // set the phasor in the inverse Park transform
        IPARK_setPhasor(obj->iparkHandle_V, &phasor);
        // run the inverse Park module
        IPARK_run(obj->iparkHandle_V,
                  &obj->Vdq_out_V, &obj->Vab_out_V);
        // setup the space vector generator (SVGEN) module
        SVGEN_setup(obj->svgenHandle,
                    obj->oneOverDcBus_invV);
        // run the space vector generator (SVGEN) module
        SVGEN_run(obj->svgenHandle,
                  &obj->Vab_out_V, &(obj->pwmData.Vabc_pu));
    #if(DMC_BUILDLEVEL == DMC_LEVEL_1)
        // output 50%
    #endif
            // clear PWM data
        else
            // run the PWM compensation and current ignore algorithm
            SVGENCURRENT_compPWMData(obj->svgencurrentHandle,
                                     &obj->pwmData.Vabc_pu, &obj->pwmDataPrev);
        obj->ignoreShuntNextCycle = SVGENCURRENT_getIgnoreShunt(obj->svgencurrentHandle);
        obj->midVolShunt = SVGENCURRENT_getVmid(obj->svgencurrentHandle);
        // Set trigger point in the middle of the low side pulse
        HAL_setTrigger(obj->halMtrHandle,
                       &obj->pwmData, obj->ignoreShuntNextCycle, obj->midVolShunt);
    #else   // !MOTOR1_OVM
    #endif  // !MOTOR1_OVM
        // Collect current and voltage data to calculate the RMS value
        collectRMSData(motorHandle_M1);
        recordSpeedData(motorHandle_M1);
    #if defined(STEP_RP_EN)
        // Collect predefined data into arrays
        GRAPH_updateBuffer(&stepRPVars);
    #if defined(EPWMDAC_MODE)
        // connect inputs of the PWMDAC module.
        HAL_writePWMDACData(halHandle, &pwmDACData);
    #endif  // EPWMDAC_MODE
    #if defined(DATALOGF2_EN)
        if(DATALOGIF_enable(datalogHandle) == true)
            DATALOGIF_updateWithDMA(datalogHandle);
            // Force trig DMA channel to save the data
            HAL_trigDMAforDLOG(halHandle, 0);
            HAL_trigDMAforDLOG(halHandle, 1);
    #elif defined(DATALOGF4_EN) || defined(DATALOGI4_EN)
            HAL_trigDMAforDLOG(halHandle, 2);
            HAL_trigDMAforDLOG(halHandle, 3);
    #endif  // DATALOGF4_EN || DATALOGF2_EN
    #if defined(DAC128S_ENABLE)
    #if defined(_F280013x) || defined(_F280015x)
    #if defined(BSXL8323RS_REVA) || defined(BSXL8353RS_REVA) || \
        if(HAL_getSelectionSPICS(motorHandle_M1->halMtrHandle) == SPI_CS_DAC)
            // Write the variables data value to DAC128S085
            DAC128S_writeData(dac128sHandle);
    #else   // !(BSXL8323RS_REVA | BSXL8353RS_REVA | BSXL8316RT_REVA)
    #endif   // !(BSXL8323RS_REVA | BSXL8353RS_REVA | BSXL8316RT_REVA)
    #elif defined(_F28002x) || defined(_F28003x)
    #endif  // !(F280013x | F280015x | F28002x | F28003x)
    #endif  // DAC128S_ENABLE
        return;
    } // end of motor1CtrlISR() function
    //-- end of this file ----------------------------------------------------------
  • Hi Aric,
    Looks like the custom PCB may have a hardware issue. Perhaps you can use a signal injector if 0R in series current amp outputs. Remove 0R's take inputs to ground one at time see if the noise ever reduces. Make sure you have ADC power inputs correctly setup, ring out without power on, no micro solder balls between pins. Double check hal.h has the correct ADC, PPB inputs match ADC number. Verify using TRM analog tables and debug register view to check any action on PPBs, look at that first to sniff out what is going on.
  • I think my ADC's are set up correctly. No 0R in series on output of amps, but I can verify the PPB are working by the offset calibration stage, and by attaching a resistive load and turning on one of the PWM paths; they correctly measure the current, but the noise is centered on the correct value.
    What do you mean by "ring out without power on"?
    (edit) oh its a saying, check all the hardware is hooked up start to finish and is signaling good
    Do you think the ADC noise is contributing to the failing frequency generator?
    (edit) did a thorough resistive load test to verify offsets are working (PPB) and verify current is scaling correctly.
    I used a 30 Ohm resistor and 24V so ~800mA would flow over the shunt resistors.
    Here are my results:
    Tabulated:
    Hi-Phase Lo-Phase PHA C PHB C PHC C PHA V PHB V PHC V
    A B 0 0.85 0 23 0 12
    A C 0 0 0.85 23 12 0
    B A 0.85 0 0 0 23 12
    B C 0 0 0.85 12 23 0
    C A 0.85 0 0 0 12 23
    C B 0 0.85 0 12 0 23
    The power supply I was using said it was drawing 0.86A for each part of the test.
    An example result from the test:
    The I_A_AVG is a quick little multisampling I attempted by averaging 10 of the datalog values of I_A to cut through some noise; this is NOT used by the control system, just a diagnostic tool at this point.
    [0] -> phase A, [1] -> phase B, [2] -> phase C
  • The Offset_I_ad seem very low, should be roughly 2048. Any value seems to stay fixed may indicate a mismatched PPB to ADC. The x49 has 3 ADC's so it gets more complex that can occur in software not matching the ADC hardware channel inputs. I have one reading 1274 offset today, not good so low.
    About I_A noise my current amps run >40mV idle.  ADC inputs can get crossed in software between hal.c and hal.h configurations. That can cause an immediate OVC trip build level 2-3 when USER_MOTOR1_OVER_CURRENT_A  is not at least set one even few amps greater than any expected fault condition. You can also add some hysterias to CMPSS modules. Depending on the shunt resistance and FS current the fault window may need be set even greater. The angle signal seems to not be reading any data, be sure x37 has PWMDAC's verify GPIO pins and call exists to configured PWMDAC's hal.c.
    /* Set 3x hysteresis on comparator inputs */
    CMPSS_setHysteresis(obj->cmpssHandle[cnt], 3);
  • The offset is low. It used to be roughly 2048 like you described, but I lowered the offset (changed the resistor divider circuit on the input to the OPAMP) and doubled the gain, so I could get a bit better resolution at the cost of lowered maximum possible current (and significantly reduced negative current maximum); I think that may be a mistake, but I was trying to isolate the noise issue, and I may change it back to 2048.
    If the system seems like it should run with ~40mV noise, then the issue may be somewhere other than this small amount of noise.
    I noticed today that the angle generator DOES initially have a nice saw wave, but I think some sort of feedback is causing it to go haywire. 'motorVars_M1.speed_Hz' in particular swings between -500 and 500, even with the motor off.
    I set the angle generator to use the reference speed instead of the ISR-feedback controlled speed, forcing the angle generator into the correct saw wave vs reference speed, and it rotates but draws maximum current and sounds very... angry...
    I am going to investigate the control loop, and compare it with an evaluation kit I have (BOOSTXL-DRV8320RS + LAUNCHXL-F280049C).
    All the documentation says it should simply work at this point...
  • Another day, more progress.
    1) I modified the ADC feedback offset so it sits closer to halfway again (~1900 now)
    2) I also noticed one more problem: the Voltage feedback (as opposed to current) offset on the F280049C/DRV8320RS evaluation kit is ~1/2 bus Voltage.
    However, the Voltage feedback that the Universal Motor Control lab offsets to is  - ~1/2 bus Voltage.
    I can confirm that with the Voltage feedback set to positive, and attempting to spin the motor, the Voltage feedback oscillates  around a positive offset, however with the feedback set to negative, the Voltage oscillates around zero, which appears to be the correct setting.
    No where is this offset requirement mentioned at all, and the fact the eval kit and the Universal Motor Control lab use opposite polarity for this is a bit disconcerting.
    Anyway, the motor still sounds bad though I think I corrected the offset issues.
    3) On the evaluation kit, the motor spins quietly and smoothly in 'is03', the open loop InstaSPIN lab.
    Here are a few images of the high side gates on the gently spinning motor:
    The active high/low complementary system gently wiggles between states like those above.
    Here are a few images of my prototype system  on DMC build level 2 (left zoomed out, right zoomed in)
    This does NOT look like a healthy system as above...
    Scratching my head as to what to look at next.
    I am not so sure bad feedback into the system would cause something to look like that.
    Here is a oscilloscope image of the unloaded (no motor) turned on (DMC build level 2):
    The unloaded 'is03' lab on the evaluation kit looks just like the images of its loaded system.
    It looks like a completely different commutation technique.
    I am still figuring out how all this works, but it looks like the UMC lab is doing a completely different control scheme entirely...
    What could be going on?
  • I am still figuring out how all this works, but it looks like the UMC lab is doing a completely different control scheme entirely...
    Make sure PWM mode is not set to SVM_MIN_C during motor run and FW disabled bottom expression tab. Check current amplifier output polarity is not inverting, default is non-inverting. So your eval kit x49c with drv8320rs same here. SVM_COM_C produces full modulation.
    Perhaps a build issue exits x37c as the speed Hz should be 0.0 during est state idle. You have EST mode/type set FAST before attempting to run eSMO? So the x37c is directly supported by UMC kit?  Using 2 CMPSS for trips was very strange in UMC conversion example. The x49c use 3 CMPSS and notice if DAC-Hi/Low trips are not in one shot mode as configured. Somehow latches auto clear act more like CBC and chop PWM much like your scope capture acts like current is being interrupted.
    Right after I mention ADC current offset smoked 105vdc motor, CMPSS one shot latch did not stop inverter pushing current. Could not hit pause fast enough, motor rated 25 watts user_est set 0.92mA #24 AWG winding, trip set 1.8A holding it down in the cradle stopping it from jumping into the air. Fumbling to disable by clicking typing in 0x0 is hit miss anyhow and often forget that pause is an immediate kill switch UMC. Seeming the stall current, defaults 10A forgot to it lower back weeks ago messing with another much bigger motor.
    Also use SDK4.0 LCD has stop button being UMC build had issues motorVars_M1 struct Boolean flag states being tested or toggled via SCI RX commands. Seems like the symbols are broken links though UMC project compiles without errors or warnings with SCI control modules. Seems the UMC does a better job of motor ID though still had to tweak inductance to get small 4 pole motor to reach 13KRPM. The SDK has no problem with Boolean flag states being tested or changed by SCI RX_ISR context motor control commands. A bit concerning since another micro PCM enables MCU controller and estimator states, not sure about dual core control scenario.
  • I am having a little bit of luck now, but by commenting out the main loop and ISR and using the loop from the evaluation kit (EVK).
    Using this as an opportunity to learn what steps the motor takes to control it. I think your comments will make a bit more sense once I see what steps the control loop goes through in the code.
    Right this moment I have a motor correctly drawing a small amount of current (not max), as if its attempting to turn, but the motor itself is locked in place. More importantly, the PWM gate signals look correct, like its trying to power one (edit) coil (in active complementary, two high gates are on, and one low gate is on, what I am calling the 'on' coil). It is also self-limiting the current, which tells me the control loop is correctly limiting its current, a very good sign.
    That is too bad... Once I get a motor spinning, I think I will immediately set up a physical kill switch. Trying to set an expression to 0 in the expression window while a motor is going haywire seems like a recipe for disaster.
  • Finally got motor to spin in build level 2!
    I completely adapted the code in the InstaSPIN lab 03 'is03' to my board.
    Not 100% sure why the code wasn't working, the biggest difference I can find at a glance (edit: grammar) between  'is03' and UMC build level 2 is the estimator is not run in the ISR in 'is03'.
    Anyway, there are a LOT of options and #if statements in the UMC, it is very likely some code slipped through that shouldn't have.
    Trying to clean up motor1_drive.c and sys_main.c in the UMC seems like an uphill battle, adapting the ISR and main loop code from the instaSPIN labs seems a bit more successful. I will try incrementing the lab and verifying the control loop is working.
    Also I will set up a kill switch like... right now.
  • Good to see you got motor to spin build #3. Agree far too many #if/endif statements just increases the chance for Murphys law to invade. There are a lot of breaks in the main control loop code is hard to follow and debug. I left in place MDAC board, DRV8323RS and DRV8320RS code added defines for x49c, x25c site 1&2 headers hal.c/h for PWM, ADC, PGA, CMPSS functions and defines. The DRV8323RS is only valid on Site-1 x25c and drv8320RS Site-1 x49c where Site 2 is for jumpers to any DC inverter. The smoked motor stinks like cow dung lucky is not very expensive. One can tell coils are shorted when rotor is more difficult to spin by fingers. There is a fluid claims to fix shorted coils in motors past sold ebay and have to wonder how well that works in all cases. Seemingly check stall current setting user_motor1.h does not allow saturation current to peak as I did.
    Agree that just is not fast enough though clicking on pause is much quicker without a button. Recommend to bolt down small motors or hold down on flat surface with one hand or it can do some damage when or if startup goes haywire. Oddly that was not such an issue with SDK4.0 but UMC has 1ms CPU timer clearing several fault flags. The code in that area seems to do auto else if clear several Boolean states. Perhaps it should check a general fault flag prior to resetting state. Suspect the CMPSS H/L latch states are getting cleared since the debug shows them set even when the motor is running 13KRPM.
    How is that possible since DMC build level 3 is run in closed loop? Perhaps check the #if statements where FAST_ESMO symbol defines are shared in the build. Discovered an odd combination of logic that seems to contradict PDF symbol defines. The PDF  shows two tables of valid functions, motor ID only valid in FAST not ESMO. Check below code motor_common.h and one other module it is setup very important PWM_COM_C state is showing in debug not MIN_C, may have to add the flag to expressions.
    #elif defined(MOTOR1_FAST) || defined(MOTOR1_ESMO) //5/3/23 added motor1_esmo
    typedef enum
    ESTIMATOR_MODE_FAST = 0, //!< FAST estimator
    ESTIMATOR_MODE_ESMO = 1 //!< ESMO estimator
    } ESTIMATOR_Mode_e;
  • UMC build level 2 is the estimator is not run in the ISR in 'is03'.
    In the InstaSPIN labs, 'is03' is actually runs open loop, so this is the lab I used as equivalent to DMC_BUILDLEVEL_2
  • Ok now get you ran SDK LAB is03 on your custom PCB to trouble shoot UMC issues. UMC build level 2 still not working on custom PCB?
    Are you using SDK parameters derived via drv8230rs motor ID LAB is05 to run the motor build level 2 on custom PCB? That may be a mistake if custom PCB has different resistance and inductance paths and ADC offsets are very different. I found the UMC motor ID is much more accurate with my custom inverter than LAB is05 was ever. Still had to tweak user parameters inductance for that small 105vdc 4 pole motor to ever reach 13KRPM as confirmed via laser tachometer. Oddly a 24vdc 4 pole small motor reached 11KRPM from the same ID parameters of inductance both SDK & UMC.
    This code snip (motor_common.c) converts Hz to RPM in expressions tab; motorVars_M1.speed_krpm
    #if defined(MOTOR1_ESMO) || defined(MOTOR1_FAST) || defined(MOTOR2_FAST)
    // update motor control variables
    void updateGlobalVariables(MOTOR_Handle handle)
       MOTOR_Vars_t *obj = (MOTOR_Vars_t *)handle;
       MOTOR_SetVars_t *objSets = (MOTOR_SetVars_t *)(handle->motorSetsHandle);
        motorVars_M1.speed_krpm = (motorVars_M1.speed_Hz * (60.0 / 1000.0 / USER_MOTOR1_NUM_POLE_PAIRS));
  • That is the plan, I am using the parameters derived from the drv8320RS on the motor ID LAB is05. The code is kind of stitched together, I am using the main loop from the 'is0#' labs instead of the 'runMotor1Ctrl' loop in 'motor_drive.c in the UMC, as well as the ISR loop from the 'is0#' labs. I am modifying the code to use the variables available to the UMC labs. Using this as an opportunity to figure out exactly how this system works.  The idea was, since I was certain the hardware and drivers (ADC feedback, PWM) were working, but the code wasn't, and since both labs use the same libraries, I would just adapt the working code; besides, I don't know enough about the UMC code to figure out why it isn't working, and the available documentation doesn't help much in this regard.
    Today I am turning on the estimator in DMC_LEVEL_3 / is04. So far I suspect the estimator and the PI values are not correct, and since the estimator was being (erroneously?) inserted into the DMC_LEVEL_2 code, that might explain why the system wasn't working. No proof yet, still working on it.
  •  Also mixed SDK is07 and is05 into the same mainISR used Boolean flags to control which function in mainISR via SCI command console. Motor ID seemingly executed correct wait times, often controller had issues state machine during Rov/L, Ramp-up, ld/lq detection. PARK transform for PWM drive was random if at all most times wouldn't even execute ramp up after the first or second run. The is05 est/ctrl states machine status would change via TXISR context but GDSVM was missing periods. Though group ISR nesting configured with same is07 mainISR that correctly runs a motor without any issues. Also has global updates SCI TXFFIO several motor variables current, voltage, wattage, faults, etc.. The hal.c/h are SDK4.0 only symbols and #pragma sections are uniquely different than UMC #pragma memory sections.
    BTW: Never could get fast_full_lib_eabi.lib to compile with SDK labs. MainISR has 12.4µs ISR decimation time, use GPIO toggle to check it out. Still have to use embedded fast ROM library x49c SDK4.0 reason why I kept the projects separate. The hal.c/h ADC configuration is unique to UMC and adds a bunch of symbols that SDK4.0 never had. Recommend keeping the projects separate due to the number of #pragma sections UMC loads into SRAM. Noticed ISR loop-counter was not working UMC required incrementing and good indicator the 1ms forever loops are working.
  • I am currently taking the 'debug the UMC' route, avoiding any further incompatibilities between the UMC and InstaSPIN labs, and utilizing the features in the UMC.
    I didn't touch any of the memory mapping in the UMC, only rewrote the sys_main.c while loop, and the ISR in motor1_drive.c
    So far I have gotten the UMC to spin open loop on DMC_LEVEL_2 by commenting out some outputs called from the EST line of functions, particularly those that input the 'TRAJ' trajectory generator: garbage from the EST in, garbage through the trajectory generator -> SVM module -> PWM out.
    Currently I am checking out how each of the 'EST_...' functions are working. Since I got my motor to spin in open loop, I consider this question done and I opened a new one:
    https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1272940/tms320f280037c-universal-motor-control-lab-estimator-estoutputdata-bad-despite-good-inputs-dmc_level_3-from-successful-dmc_level_2
