TMS320F28377D-EP: SDRAM DATA and Address Lines Swappable?
Part Number: TMS320F28377D-EP
Hi All,
Karthi Here, I am Working On a SDRAM Chip (Part No. AS4C1M16S-6TIN),
MCU Used Is TMS320F28377DPTPEP,
Can I Swap Data Lines for Direct Routing? And For Address Lines too.?
Thank You For Your Time.
  • Hello Karthikeyan,
    I assume you're using the EMIF to transfer data to the SDRAM chip; what do you mean by swapping data lines for direct routing? Do you have some visual representation on how you plan to use the data/address lines for the EMIF to access the SDRAM chip? This will help me better understand what you're trying to implement.
    Omer Amir
  • Karthi,
       Please send us the schematics of what you are proposing to do. You don't have to send the entire schematics. Just all the connections between the MCU and the SDRAM chip would suffice.
