Part Number: TMS320F2800157-Q1
I am facing a similar issue with F280015x controller. The data print looks like this
Hi Mrirank,
Could you confirm that your baud rate, parity and stop bit settings have been configured correctly to match the F280015x configuration? I will test this example on another C2000 device to confirm whether this is a device specific issue. Please expect a response back by tomorrow.
Thank you,
Luke
I saw the SCI ex2_code provided by TI where 9600 was the baud rate passed, along with 1 stop bit and no parity bit. I am using control card to connect pin to FTDI cable and on PC trying to collect the data on Tera Term.
Thank you,
Mrikank
Hi Mrikank,
sci example 2 is not meant to communicate with a serial putty port. There is an internal loopback mode in the SCI that allows the transmitter to communicate with the receiver without any other device intervention.
sci example 1 is used for communication with a serial port on your PC. Could you confirm whether this is example 2 or example 1 that you are testing?
Thank you,
Luke
