Part Number: TMS320F28034
Hi all,
I’ve a question about serial programming with C2prog and security password.
I’ve a board with a microcontroller TMS320F28034.
After programming the micro with Uniflash Software and locked the device with a password, if I want to reprogram it with C2prog in serial boot mode I must insert the correct password in the configuration, like the below picture:
if I check “Smart sector selection” box, C2prog erase the FlashA sector and also the password, so after reprogram it the microcontroller is not more protected by password.
To maintain the original password I select to erase all the Flash sectors except FlashA. But doing this I receive an error (see below picture):
and the programming procedure does not end. I must to click cancel button.
The microcontroller seems to be correctly programmed.
My question is:
Is this a correct way to proceed?
Massimo.
