Part Number: TMS320F28388D
The PWM output is switched every 50us using the ePWM up/down mode. It operates normally without USB communication, but if you monitor the PWM output with USB communication in progress, There are times when an interrupt does not occur and the PWM output does not invert, as often as 10 times per second.
If there is no USB connection, it will rise and fall at 50us without any disturbance, so it seems that USB communication is affected. It's possible that it has something to do with the priority of interrupts, but is it possible to get some advice?
Conor
