TMS320F28388D: How to use CM's memory barrier function in C language.
Part Number: TMS320F28388D
Hi all,
CM(Arm Cortex-M4) has memory barrier instructions, but is there a way to write this function in C language?
  • I presume you use the proprietary TI Arm compiler.  The command which invokes this compiler is armcl.
    This compiler supports ARM ACLE (Arm C Language Extensions) version 2.0.  Your code can use this standard header file ...
    #include <arm_acle.h>
    One way to learn about the extensions it supports is to inspect that header file.  A typical path to the directory for it is ...
    C:\ti\ccs1200\ccs\tools\compiler\ti-cgt-arm_20.2.7.LTS\include
    Search the file for Memory Barriers, and learn about the details of the intrinsics _dmb, _dsb, and _isb.
    Thanks and regards,
    -George
  • Hi George,
    Thank you very much!!
    This is exactly what I was looking for.
