Other Parts Discussed in Thread: C2000WARE, SYSCONFIG
Team,
Our customer is working with f28p650's c2000ware examples for PWM dead band generation which configures 6 modules in different dead band configurations.
From the example code, they are testing active high complementary mode on ePWM4 output which has the following dead band setting (400 and 200), but it results in complementary PWM with no dead band (see the scope shots attached herewith), can you please check the same. ?
Also, configuration of divide /2 for PWMclock in the clock tree results in PWM clock of 200.0 MHz (although it shows 100 MHz) and divide/1 gives 100MHz, in sysconfig tool (1.17) can you please check the same.
TY,
CY (for customer)
