Part Number: LAUNCHXL-F280025C
Other Parts Discussed in Thread: TMS320F280025C, SYSCONFIG
Hello TI Team.
I am working on TMS320F280025C launch pad. I am trying to configure the launch pad to burn the code in flash memory and not in RAM. when I debug and burn the same code on RAM it works fine. After trying to run the same code on flash memory I am not able to perform it.
I have worked on changing the linker files also, but not able to perform.
After using the ready projects available in C2000 library it works fine.
Can someone please help me in the setting the required configuration setting. Also can someone please help me integrating the generated files using the SysConfig Tool.
Thanks, and Regards
Omprasad D
