Hi Team,
Looking through the "F287x_180controlCARD_R1_3_SCH_02OCT2015.pdf" it seems that not every VDDIO has an independent decoupling capacitor.
In the datasheet, for the VDDIO pins it states "Place a minimum 0.1-µF decoupling capacitor on each pin. The exact value of the decoupling capacitance should be determined by your system voltage regulation solution."
Is there a method to determine which pins can share decoupling capacitors?
Thanks!
