Part Number: TMS320F28388D
Greetings,
I’m looking at spruii0e and sprsp14e and specifically the IPC Message RAMs which are used to communicate with the CM. In the TRM, section 16.2 Message RAMs, Table 16-1 and 16-2, there are separate message RAMs for the CM/CPU1 communications, and CM/CPU2 communications. And in the Data Sheet section 3.1 Functional Block Diagram, the CM has a pair of message RAMs which are used in its communications with CPU1 and a second pair which are used with CPU2. But in section 8.3.1, Table-1 C28x Memory Map, there seems to be only one pair which the CM uses in its communications with both CPU1 and CPU2. What am I missing?
Thank you,
Ed
