Part Number: TMS320F28379D
Hi community,
So right now I've been trying to Implement this code :
#include "Peripheral_Setup.h"
void Setup_GPIO(void){
EALLOW;
// LED 31 A, 2
// LED 34 B, 1
GpioCtrlRegs.GPAGMUX2.bit.GPIO31 = 0;
GpioCtrlRegs.GPAMUX2.bit.GPIO31 = 0;
GpioCtrlRegs.GPBGMUX1.bit.GPIO34 = 0;
GpioCtrlRegs.GPBMUX1.bit.GPIO34 = 0;
GpioCtrlRegs.GPAPUD.bit.GPIO31 = 1;
GpioCtrlRegs.GPBPUD.bit.GPIO34 = 1;
GpioCtrlRegs.GPADIR.bit.GPIO31 = 1;
GpioCtrlRegs.GPBDIR.bit.GPIO34 = 1;
GpioCtrlRegs.GPBCSEL1.bit.GPIO34 = GPIO_MUX_CPU1;
GpioCtrlRegs.GPACSEL4.bit.GPIO31 = GPIO_MUX_CPU1;
//PWM 1A e 1B
GpioCtrlRegs.GPAGMUX1.bit.GPIO0 = 0;
GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1;
GpioCtrlRegs.GPAPUD.bit.GPIO0 = 1;
GpioCtrlRegs.GPAGMUX1.bit.GPIO1 = 0;
GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1;
GpioCtrlRegs.GPAPUD.bit.GPIO1 = 1;
//PWM 7A e 8A
GpioCtrlRegs.GPEGMUX2.bit.GPIO157 = 0;
GpioCtrlRegs.GPEMUX2.bit.GPIO157 = 1;
GpioCtrlRegs.GPEPUD.bit.GPIO157 = 1;
GpioCtrlRegs.GPEGMUX2.bit.GPIO159 = 0;
GpioCtrlRegs.GPEMUX2.bit.GPIO159 = 1;
GpioCtrlRegs.GPEPUD.bit.GPIO159 = 1;
//GPIO 14
GpioCtrlRegs.GPAGMUX1.bit.GPIO14 = 0;
GpioCtrlRegs.GPAMUX1.bit.GPIO14 = 0;
GpioCtrlRegs.GPAPUD.bit.GPIO14 = 1;
GpioCtrlRegs.GPADIR.bit.GPIO14 = 1;
GpioCtrlRegs.GPACSEL2.bit.GPIO14 = GPIO_MUX_CPU1;
EDIS;
void Setup_ePWM(void){
EALLOW;
CpuSysRegs.PCLKCR2.bit.EPWM1 = 1;
CpuSysRegs.PCLKCR2.bit.EPWM7 = 1;
CpuSysRegs.PCLKCR2.bit.EPWM8 = 1;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 0;
EPwm1Regs.TBPRD = 3255; // Set timer period
EPwm1Regs.CMPA.bit.CMPA = EPwm1Regs.TBPRD >> 1;
EPwm1Regs.TBPHS.bit.TBPHS = 0; // Phase is 0
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
EPwm1Regs.TBCTR = 0x0000; // Clear counter
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up/down
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD;
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; // Load registers every ZERO
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO_PRD;
EPwm1Regs.AQCTLA.bit.PRD = AQ_NO_ACTION;
EPwm1Regs.AQCTLA.bit.ZRO = AQ_NO_ACTION;
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; // set actions for EPWM1A
EPwm1Regs.AQCTLA.bit.CAD = AQ_SET;
EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active Hi complementary
EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; // enable Dead-band module
EPwm1Regs.DBFED.bit.DBFED = 100; // FED = 20 TBCLKs
EPwm1Regs.DBRED.bit.DBRED = 100; // RED = 20 TBCLKs
//Trigger ADC
EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group
EPwm1Regs.ETSEL.bit.SOCASEL = ET_CTR_PRDZERO; // Dispara ADC no topo
EPwm1Regs.ETPS.bit.SOCAPRD = ET_1ST; // Trigger on every event
// PWM 7A
EPwm7Regs.TBPRD = 3255; // Set timer period
EPwm7Regs.CMPA.bit.CMPA = 0;
EPwm7Regs.TBPHS.bit.TBPHS = 0; // Phase is 0
EPwm7Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm7Regs.TBCTR = 0x0000; // Clear counter
EPwm7Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up/down
EPwm7Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm7Regs.TBCTL.bit.PHSDIR = TB_DOWN; // Phase UP/DOWN
EPwm7Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm7Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm7Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO
EPwm7Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD;
EPwm7Regs.AQCTLA.bit.PRD = AQ_NO_ACTION;
EPwm7Regs.AQCTLA.bit.ZRO = AQ_NO_ACTION;
EPwm7Regs.AQCTLA.bit.CAU = AQ_CLEAR; // set actions for EPWM1A
EPwm7Regs.AQCTLA.bit.CAD = AQ_SET;
// PWM 7B
EPwm8Regs.TBPRD = 3255; // Set timer period
EPwm8Regs.CMPA.bit.CMPA = 0;
EPwm8Regs.TBPHS.bit.TBPHS = 0; // Phase is 0
EPwm8Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm8Regs.TBCTR = 0x0000; // Clear counter
EPwm8Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up/down
EPwm8Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm8Regs.TBCTL.bit.PHSDIR = TB_DOWN; // Phase UP/DOWN
EPwm8Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm8Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm8Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO
EPwm8Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO_PRD;
EPwm8Regs.AQCTLA.bit.PRD = AQ_NO_ACTION;
EPwm8Regs.AQCTLA.bit.ZRO = AQ_NO_ACTION;
EPwm8Regs.AQCTLA.bit.CAU = AQ_CLEAR; // set actions for EPWM1A
EPwm8Regs.AQCTLA.bit.CAD = AQ_SET;
CpuSysRegs.PCLKCR0.bit.TBCLKSYNC = 1;
EDIS;
void Setup_ADC(void){
Uint16 acqps;
AdcbRegs.ADCCTL2.bit.RESOLUTION = 1;
// determine minimum acquisition window (in SYSCLKS) based on resolution
if(ADC_RESOLUTION_12BIT == AdcaRegs.ADCCTL2.bit.RESOLUTION)
acqps = 14; // 75ns
else // resolution is 16-bit
acqps = 63; // 320ns
EALLOW;
CpuSysRegs.PCLKCR13.bit.ADC_A = 1;
AdcaRegs.ADCCTL2.bit.PRESCALE = 6; // set ADCCLK divider to /4
AdcSetMode(ADC_ADCA, ADC_RESOLUTION_12BIT, ADC_SIGNALMODE_SINGLE);
AdcaRegs.ADCCTL1.bit.INTPULSEPOS = 1; // Set pulse um ciclo antes do resultado
AdcaRegs.ADCCTL1.bit.ADCPWDNZ = 1; // power up the ADC
DELAY_US(1000); // delay for 1ms to allow ADC time to power up
AdcaRegs.ADCSOC0CTL.bit.CHSEL = 3;
AdcaRegs.ADCSOC0CTL.bit.ACQPS = acqps; //sample window is 15 SYSCLK cycles
AdcaRegs.ADCSOC0CTL.bit.TRIGSEL = 0x05; //trigger on ePWM2 SOCA
AdcaRegs.ADCSOC1CTL.bit.CHSEL = 4;
AdcaRegs.ADCSOC1CTL.bit.ACQPS = acqps;
AdcaRegs.ADCSOC1CTL.bit.TRIGSEL = 0x05;
AdcaRegs.ADCINTSEL1N2.bit.INT1SEL = 0x01; // end of SOC1 will set INT1 flag
AdcaRegs.ADCINTSEL1N2.bit.INT1E = 1; // enable INT1 flag
AdcaRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; // make sure INT1 flag is cleared
EDIS;
void Setup_DAC(void){
EALLOW;
CpuSysRegs.PCLKCR16.bit.DAC_A = 1;
DacaRegs.DACCTL.bit.SYNCSEL = 0x00;
DacaRegs.DACCTL.bit.LOADMODE = 0x01;
DacaRegs.DACCTL.bit.DACREFSEL = 0x01;
DacaRegs.DACVALS.bit.DACVALS = 0; //12 bits
DacaRegs.DACOUTEN.bit.DACOUTEN = 1;
DacaRegs.DACLOCK.all = 0x00;
EDIS;
but it continuously showing this error :
Description Resource Path Location Type
#20 identifier "ADC_RESOLUTION_12BIT" is undefined Peripheral_Setup.c /PLL line 148 C/C++ Problem
gmake: *** [Peripheral_Setup.obj] Error 1 PLL C/C++ Problem
gmake: Target 'all' not remade because of errors. PLL C/C++ Problem
So I did declared/defined ADC_RESOLUTION_12BIT in code.
But after doing that I'm getting this error:
#10263 ACCESSPROTECTION memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 5 C/C++ Problem
#10263 ADCA memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 6 C/C++ Problem
#10263 ADCARESULT memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 10 C/C++ Problem
#10263 ADCB memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 7 C/C++ Problem
#10263 ADCBRESULT memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 11 C/C++ Problem
#10263 ADCC memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 8 C/C++ Problem
#10263 ADCCRESULT memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 12 C/C++ Problem
#10263 ADCD memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 9 C/C++ Problem
#10263 ADCDRESULT memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 13 C/C++ Problem
#10263 ANALOGSUBSYS memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 14 C/C++ Problem
#10263 CANA memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 15 C/C++ Problem
#10263 CANB memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 16 C/C++ Problem
#10263 CLA1 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 17 C/C++ Problem
#10263 CLB1DATAEXCH memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 18 C/C++ Problem
#10263 CLB1LOGICCFG memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 22 C/C++ Problem
#10263 CLB1LOGICCTRL memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 26 C/C++ Problem
#10263 CLB2DATAEXCH memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 19 C/C++ Problem
#10263 CLB2LOGICCFG memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 23 C/C++ Problem
#10263 CLB2LOGICCTRL memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 27 C/C++ Problem
#10263 CLB3DATAEXCH memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 20 C/C++ Problem
#10263 CLB3LOGICCFG memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 24 C/C++ Problem
#10263 CLB3LOGICCTRL memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 28 C/C++ Problem
#10263 CLB4DATAEXCH memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 21 C/C++ Problem
#10263 CLB4LOGICCFG memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 25 C/C++ Problem
#10263 CLB4LOGICCTRL memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 29 C/C++ Problem
#10263 CLBXBAR memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 30 C/C++ Problem
#10263 CLKCFG memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 31 C/C++ Problem
#10263 CMPSS1 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 32 C/C++ Problem
#10263 CMPSS2 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 33 C/C++ Problem
#10263 CMPSS3 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 34 C/C++ Problem
#10263 CMPSS4 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 35 C/C++ Problem
#10263 CMPSS5 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 36 C/C++ Problem
#10263 CMPSS6 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 37 C/C++ Problem
#10263 CMPSS7 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 38 C/C++ Problem
#10263 CMPSS8 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 39 C/C++ Problem
#10263 CPUSYS memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 43 C/C++ Problem
#10263 CPUTIMER0 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 40 C/C++ Problem
#10263 CPUTIMER1 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 41 C/C++ Problem
#10263 CPUTIMER2 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 42 C/C++ Problem
#10263 DACA memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 44 C/C++ Problem
#10263 DACB memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 45 C/C++ Problem
#10263 DACC memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 46 C/C++ Problem
#10263 DCSMCOMMON memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 47 C/C++ Problem
#10263 DCSMZ1 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 48 C/C++ Problem
#10263 DCSMZ2 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 49 C/C++ Problem
#10263 DEVCFG memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 50 C/C++ Problem
#10263 DMACLASRCSEL memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 51 C/C++ Problem
#10263 DMA memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 52 C/C++ Problem
#10263 ECAP1 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 53 C/C++ Problem
#10263 ECAP2 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 54 C/C++ Problem
#10263 ECAP3 memory range has already been specified F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 55 C/C++ Problem
#10264 ACCESSPROTECTION memory range overlaps existing memory range ACCESSPROTECTION F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 5 C/C++ Problem
#10264 ADCA memory range overlaps existing memory range ADCA F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 6 C/C++ Problem
#10264 ADCARESULT memory range overlaps existing memory range ADCARESULT F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 10 C/C++ Problem
#10264 ADCB memory range overlaps existing memory range ADCB F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 7 C/C++ Problem
#10264 ADCBRESULT memory range overlaps existing memory range ADCBRESULT F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 11 C/C++ Problem
#10264 ADCC memory range overlaps existing memory range ADCC F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 8 C/C++ Problem
#10264 ADCCRESULT memory range overlaps existing memory range ADCCRESULT F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 12 C/C++ Problem
#10264 ADCD memory range overlaps existing memory range ADCD F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 9 C/C++ Problem
#10264 ADCDRESULT memory range overlaps existing memory range ADCDRESULT F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 13 C/C++ Problem
#10264 ANALOGSUBSYS memory range overlaps existing memory range ANALOGSUBSYS F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 14 C/C++ Problem
#10264 CANA memory range overlaps existing memory range CANA F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 15 C/C++ Problem
#10264 CANB memory range overlaps existing memory range CANB F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 16 C/C++ Problem
#10264 CLA1 memory range overlaps existing memory range CLA1 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 17 C/C++ Problem
#10264 CLB1DATAEXCH memory range overlaps existing memory range CLB1DATAEXCH F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 18 C/C++ Problem
#10264 CLB1LOGICCFG memory range overlaps existing memory range CLB1LOGICCFG F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 22 C/C++ Problem
#10264 CLB1LOGICCTRL memory range overlaps existing memory range CLB1LOGICCTRL F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 26 C/C++ Problem
#10264 CLB2DATAEXCH memory range overlaps existing memory range CLB2DATAEXCH F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 19 C/C++ Problem
#10264 CLB2LOGICCFG memory range overlaps existing memory range CLB2LOGICCFG F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 23 C/C++ Problem
#10264 CLB2LOGICCTRL memory range overlaps existing memory range CLB2LOGICCTRL F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 27 C/C++ Problem
#10264 CLB3DATAEXCH memory range overlaps existing memory range CLB3DATAEXCH F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 20 C/C++ Problem
#10264 CLB3LOGICCFG memory range overlaps existing memory range CLB3LOGICCFG F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 24 C/C++ Problem
#10264 CLB3LOGICCTRL memory range overlaps existing memory range CLB3LOGICCTRL F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 28 C/C++ Problem
#10264 CLB4DATAEXCH memory range overlaps existing memory range CLB4DATAEXCH F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 21 C/C++ Problem
#10264 CLB4LOGICCFG memory range overlaps existing memory range CLB4LOGICCFG F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 25 C/C++ Problem
#10264 CLB4LOGICCTRL memory range overlaps existing memory range CLB4LOGICCTRL F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 29 C/C++ Problem
#10264 CLBXBAR memory range overlaps existing memory range CLBXBAR F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 30 C/C++ Problem
#10264 CLKCFG memory range overlaps existing memory range CLKCFG F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 31 C/C++ Problem
#10264 CMPSS1 memory range overlaps existing memory range CMPSS1 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 32 C/C++ Problem
#10264 CMPSS2 memory range overlaps existing memory range CMPSS2 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 33 C/C++ Problem
#10264 CMPSS3 memory range overlaps existing memory range CMPSS3 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 34 C/C++ Problem
#10264 CMPSS4 memory range overlaps existing memory range CMPSS4 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 35 C/C++ Problem
#10264 CMPSS5 memory range overlaps existing memory range CMPSS5 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 36 C/C++ Problem
#10264 CMPSS6 memory range overlaps existing memory range CMPSS6 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 37 C/C++ Problem
#10264 CMPSS7 memory range overlaps existing memory range CMPSS7 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 38 C/C++ Problem
#10264 CMPSS8 memory range overlaps existing memory range CMPSS8 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 39 C/C++ Problem
#10264 CPUSYS memory range overlaps existing memory range CPUSYS F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 43 C/C++ Problem
#10264 CPUTIMER0 memory range overlaps existing memory range CPUTIMER0 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 40 C/C++ Problem
#10264 CPUTIMER1 memory range overlaps existing memory range CPUTIMER1 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 41 C/C++ Problem
#10264 CPUTIMER2 memory range overlaps existing memory range CPUTIMER2 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 42 C/C++ Problem
#10264 DACA memory range overlaps existing memory range DACA F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 44 C/C++ Problem
#10264 DACB memory range overlaps existing memory range DACB F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 45 C/C++ Problem
#10264 DACC memory range overlaps existing memory range DACC F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 46 C/C++ Problem
#10264 DCSMCOMMON memory range overlaps existing memory range DCSMCOMMON F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 47 C/C++ Problem
#10264 DCSMZ1 memory range overlaps existing memory range DCSMZ1 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 48 C/C++ Problem
#10264 DCSMZ2 memory range overlaps existing memory range DCSMZ2 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 49 C/C++ Problem
#10264 DEVCFG memory range overlaps existing memory range DEVCFG F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 50 C/C++ Problem
#10264 DMACLASRCSEL memory range overlaps existing memory range DMACLASRCSEL F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 51 C/C++ Problem
#10264 DMA memory range overlaps existing memory range DMA F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 52 C/C++ Problem
#10264 ECAP1 memory range overlaps existing memory range ECAP1 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 53 C/C++ Problem
#10264 ECAP2 memory range overlaps existing memory range ECAP2 F2837xD_Headers_nonBIOS_cpu1.cmd /PLL line 54 C/C++ Problem
#99900 error limit reached; 100 errors detected PLL C/C++ Problem
gmake: *** [all] Error 2 PLL C/C++ Problem
gmake[1]: *** [PLL.out] Error 1 PLL C/C++ Problem
I'm not understanding why this is happening whereas the same snippet from the example "adc_ex11_multiple_soc_epwm" is running finely.
Please can someone assist me.
