Part Number: TMS320F28386D
I'm testing the same example used here: https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1306409/tms320f280025c-ds3231n
so I'm trying to read from RTC but I'm unable to read the data:
I'm using different C2000microcontroller (TMS320F28386D), RTC (ISL12022M) and from Datasheet I have not clear what is the address to use: I supposed that the correct address is 0x6F:
Device Addressing
Following a start condition, the master must output a Slave Address Byte. The 7 MSBs are the device identifiers. These bits are “1101111” for the RTC registers and “1010111” for the User SRAM.
The last bit of the Slave Address Byte defines a read or write operation to be performed. When this R/W bit is a “1”, a read operation is selected. A “0” selects a write operation
But I'm not clear how to set the Read/Write bit in the code. In my case, I have to set 1 for read operation, but where have I to set this value?
// FILE: i2cLib_FIFO_polling.c
// TITLE: C28x-I2C Library source file for FIFO using polling
//! <h1> C28x-I2C Library source file for FIFO using polling </h1>
// $Copyright:
// Copyright (C) 2022 Texas Instruments Incorporated - http://www.ti.com
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "i2cLib_FIFO_polling.h"
uint16_t I2CBusScan(uint32_t base, uint16_t *pAvailableI2C_targets)
uint16_t probeTargetAddress, i;
//Disable interrupts on Stop condition, NACK and arbitration lost condition
I2C_disableInterrupt(base, (I2C_INT_ADDR_TARGET|I2C_INT_STOP_CONDITION | I2C_INT_ARB_LOST | I2C_INT_NO_ACK));
i = 0;
for(probeTargetAddress=1;probeTargetAddress<=MAX_10_BIT_ADDRESS;probeTargetAddress++)
//Check I2C bus status
status = checkBusStatus(base);
if(status)
ESTOP0;
return status;
I2C_setConfig(base, (I2C_CONTROLLER_SEND_MODE | I2C_REPEAT_MODE));
//Enable 10-bit addressing if probeTargetAddress is greater than 127U
if(probeTargetAddress > MAX_7_BIT_ADDRESS)
//10-bit addressing
I2C_setAddressMode(base, I2C_ADDR_MODE_10BITS);
// Setup target address
I2C_setTargetAddress(base, probeTargetAddress);
I2C_sendStartCondition(base);
//Wait for the target address to be transmitted
while(!(I2C_getStatus(base) & I2C_STS_REG_ACCESS_RDY));
//Generate STOP condition
I2C_sendStopCondition(base);
//Wait for the I2CMDR.STP to be cleared
while(I2C_getStopConditionStatus(base));
//Wait for the Bus busy bit to be cleared
while(I2C_isBusBusy(base));
uint16_t I2CStatus = I2C_getStatus(base);
//If target address is acknowledged, store target address
//in pAvailableI2C_targets
if(!(I2CStatus & I2C_STS_NO_ACK))
pAvailableI2C_targets[i++] = probeTargetAddress;
//Clear NACK bit in I2CSTR
I2C_clearStatus(base,I2C_STS_NO_ACK|I2C_STS_ARB_LOST|I2C_STS_REG_ACCESS_RDY|I2C_STS_STOP_CONDITION);
I2C_setConfig(base, (I2C_CONTROLLER_SEND_MODE));
I2C_setAddressMode(base, I2C_ADDR_MODE_7BITS); //7-bit addressing
I2C_enableInterrupt(base, (I2C_INT_ADDR_TARGET|I2C_INT_STOP_CONDITION | I2C_INT_ARB_LOST | I2C_INT_NO_ACK));
return SUCCESS;
uint16_t I2C_TransmittargetAddress_ControlBytes(struct I2CHandle *I2C_Params)
uint16_t status, attemptCount=1;
uint32_t base = I2C_Params->base;
status = 1;
while(status & (attemptCount <= I2C_Params->NumOfAttempts))
attemptCount++;
DEVICE_DELAY_US(I2C_Params->Delay_us);
if(status)
return status;
I2C_setConfig(base, (I2C_CONTROLLER_SEND_MODE|I2C_REPEAT_MODE));
if((I2C_Params->TargetAddr) > MAX_7_BIT_ADDRESS)
//10-bit addressing
I2C_setTargetAddress(base, I2C_Params->TargetAddr);
int16_t i;
uint32_t temp = *(I2C_Params->pControlAddr);
for(i=I2C_Params->NumOfAddrBytes-1;i>=0;i--)
I2C_putData(base, (temp >> (i*8U)) & 0xFF);
DEVICE_DELAY_US(150U);
status = handleNACK(base);
if(status)
if(attemptCount <= (I2C_Params->NumOfAttempts))
attemptCount++;
else
return status;
attemptCount = 1;
while(I2C_getTxFIFOStatus(base) && attemptCount <= 9 * (I2C_Params->NumOfAddrBytes + 2U))
if(status)
return status;
attemptCount++;
return SUCCESS;
uint16_t I2C_ControllerTransmitter(struct I2CHandle *I2C_Params)
uint16_t status, attemptCount;
I2C_disableFIFO(base);
I2C_enableFIFO(base);
status = I2C_TransmittargetAddress_ControlBytes(I2C_Params);
if(status)
return status;
I2C_setDataCount(base, (I2C_Params->NumOfAddrBytes + I2C_Params->NumOfDataBytes));
I2C_setFIFOInterruptLevel(base, I2C_FIFO_TXEMPTY, I2C_FIFO_RXFULL);
I2C_enableInterrupt(base, I2C_INT_TXFF);
uint16_t numofSixteenByte = (I2C_Params->NumOfDataBytes) / I2C_FIFO_LEVEL;
uint16_t remainingBytes = (I2C_Params->NumOfDataBytes) % I2C_FIFO_LEVEL;
uint16_t i,count = 0,buff_pos=0;
while(count < numofSixteenByte)
for(i=1;i<=I2C_FIFO_LEVEL;i++)
I2C_putData(base, I2C_Params->pTX_MsgBuffer[buff_pos++]);
attemptCount = 1;
while(I2C_getTxFIFOStatus(base) && attemptCount <= 9 * (I2C_FIFO_LEVEL + 2U))
if(status)
return status;
attemptCount++;
count++;
for (i=0; i < remainingBytes; i++)
attemptCount = 1;
while(I2C_getTxFIFOStatus(base) && attemptCount <= 9 * (remainingBytes + 2U))
if(status)
return status;
attemptCount++;
attemptCount = 1;
while(I2C_getStopConditionStatus(base) && attemptCount <= 3U)
attemptCount++;
return SUCCESS;
uint16_t I2C_ControllerReceiver(struct I2CHandle *I2C_Params)
uint16_t status;
uint16_t attemptCount;
if(status)
return status;
I2C_setConfig(base, (I2C_CONTROLLER_RECEIVE_MODE|I2C_REPEAT_MODE));
if(status)
return status;
count++;
attemptCount = 1;
while(!(I2C_getRxFIFOStatus(base) == I2C_FIFO_RXFULL) && attemptCount <= 9 * (I2C_FIFO_RXFULL + 2U))
attemptCount++;
for(i=0; i<I2C_FIFO_LEVEL; i++)
I2C_Params->pRX_MsgBuffer[buff_pos++] = I2C_getData(base);
attemptCount = 1;
while(!(I2C_getRxFIFOStatus(base) == remainingBytes) && attemptCount <= 9 * (remainingBytes + 2U))
attemptCount++;
for(i=0; i<remainingBytes; i++)
if(status)
return status;
attemptCount = 1;
while(I2C_getStopConditionStatus(base) && attemptCount <= 3U);
attemptCount++;
return SUCCESS;
uint16_t checkBusStatus(uint32_t base)
if(I2C_isBusBusy(base))
return ERROR_BUS_BUSY;
if(I2C_getStopConditionStatus(base))
return ERROR_STOP_NOT_READY;
return SUCCESS;
uint16_t handleNACK(uint32_t base)
if(I2C_getStatus(base) & I2C_STS_NO_ACK)
I2C_clearStatus(base, I2C_STS_NO_ACK);
return ERROR_NACK_RECEIVED;
return SUCCESS;
The code is stuck here:
status = I2C_ControllerReceiver(&RTC); in this function and stucked at this function: while(I2C_getStopConditionStatus(base) && attemptCount <= 3U);
//! Get stop condition status.
//! \param base is the base address of the I2C instance used.
//! This function reads and returns the stop condition bit status.
//! \return Returns \b true if the STP bit has been set by the device to
//! generate a stop condition when the internal data counter of the I2C module
//! has reached 0. Returns \b false when the STP bit is zero. This bit is
//! automatically cleared after the stop condition has been generated.
static inline bool
I2C_getStopConditionStatus(uint32_t base)
// Check the arguments.
ASSERT(I2C_isBaseValid(base));
// Check the stop condition bit and return appropriately.
return((HWREGH(base + I2C_O_MDR) & I2C_MDR_STP) != 0U);
Some helpful hints would truly be appreciated!
