Part Number: TIDA-01606
What kind of test path and procedure should be applied for TIDA-01606 inverter design? Is there a standard procedure to follow for testing?
you will need to follow the design guideline.
There are seven labs you can follow during the tests. Look in page 44.
Best Regards
Riccardo
Are the laboratories specified in the design guideline sufficient for the performance testing of the inverter? Are there any tests I need to perform to get better results?
there are multiple tests which can be executed outside the design guideline. The tests we proposed in the reference design guideline are ones that if you follow from 1 to 7 should give you a better understanding on how the reference design works. There are multiple different topics covered into these labs:
C2000 digital control, PLL, sensing of the current, dq transformation etc.
Best Regards
Riccardo
